Question about Riccar Sewing Machines
Remove bottom plate from riccar model 651 sewing machine to access inside
Posted by Bonnie Vann on
5 Related Answers
Anonymous
SOURCE: riccar sewing machine 8500
I don't know if this will help or not, but here is a website where you can download a manual for any of the Riccar products: http://www.riccar.com/help/manuals/
Posted on Sep 13, 2008
Anonymous
SOURCE: sewing machine thread nesting
I have fixed it now the bobbin case didn't seem to stay seated during sewing or tangling i should say!. I decided to change the needle and from then on everything worked fine.
Posted on May 09, 2009
Anonymous
SOURCE: Hello I have an old Riccar 6800 sewing machine
Hiya, the threading for this machine is pretty standard so you won't be going wrong there. Have you used a sewing machine before? The tension dial (on the extreme left) should be set at 5. The other dial to your left should be on blue zigzag with orange broken line. The dial on the right should be set at 0 and the bottom one on 2 - 3. I've been looking for a manual for this machine as I inherited this one. It took me ages to suss straight sewing out. Another thought is take it to a repairer and ask for a quote. Good luck.
Posted on Nov 23, 2009
Mary Dunn
  • 1788 Answers
SOURCE: Looking for Riccar sewing machine manual
you can get the manual by goggling Riccar 1570 manual for free. It will download, no problem
Posted on Jul 26, 2010
AYLI
SOURCE: I have a Riccar Reliant 53 sewing machine,
Oops, put my solution in the wrong place!! I replied that I have a Riccar 53 and still have the manual.
Posted on Aug 18, 2011
Is there a dressmaker sewing machine with the model no. 777?
In the 1960's, Riccar made a heavy duty 777 sewing machine. Riccar made machines into the 1970's. The headquarters appears to have been in Chicago before it moved offshore. Value of the machine? Maybe $100 if it worked. Parts might be found or salvaged from machines used for parts. However, here is a Riccar shop in South Carolina:
Riccar Sewing Machines Charleston SC
Riccar Home Sewing Machine Parts www drdanessmh com
The Riccar Sewing Machine Story
RICCAR 777 SEWING MACHINE CAMS CASEEXC
I would be doubtful regarding offers of a manual for sale for this online unless at minimum it was attached to a brick and mortar store in business (and even then might query the local Better Business Bureau).
Sep 14, 2017 | Sewing Machines
No model number on Riccar sewing machine
Riccar machines have model numbers placed in 1 of several places on their machines governed by, I suppose, the whims of the manufacturer and the most common places are on the back underneath the motor mount, on the right end bottom under the handwheel, and just under the bed of the machine, front. These numbers are going to be on a metal plate attached by 2 or more rivets. Should you see 2 or more small holes in the casting in any of these locations, it is possible that the plate has been removed. The number that you have supplied is the serial number, and it can be very difficult to determine the model number from this information as the machine is manufactured at a number of different plants/locations.
Apr 18, 2014 | Riccar Sewing Machines
Riccar 777 needle plate
http://sewingandvac.com/
if this link doesn't work the part is at
sewing-machine-parts-store.com
in your browser type in
riccar 777 needle plate
it should be the 2nd website from the top
Part No. R555
Riccar Needle Plates - Model(s): 210, 555SU, 777 - Zig zag needle plate; hinged, o.s., f.b (picture not actual size)
Bin:8G-H
Jun 07, 2012 | Sewing Machines
I purchased a new machine that did not have the Riccar R751 manual included because it was a display model. That business no longer carries the product. I need to find and instruction manual before I can...
in the search engine put riccar manuals
the search should bring up riccar product manuals-click on it
go to sewing machine owners manuals
your model number is ( 9 from the bottom)
Nov 27, 2010 | Riccar R751
Need to download manual for model 2925.
Hi you can download free manuals from the Riccar site.
I think this is the one you need:
http://www.riccar.com/ftp/whitepapers/2910-Owners-Manual.pdf
Hope this helps!
Nov 21, 2010 | Riccar Sewing Machines
Riccor model 939FA thread keeps breaking, not shure if it is threaded correctly, manual lost years ago, thread has been nesting on bottom of material, now just breaking.
Try looking for a manual for your machine here.
If your model number isn't listed try looking for a similar model or the number nearest to your machine.
Usually, sewing machines of the same brand thread in the same way. Hope this helps!
Sep 11, 2010 | Riccar R651 Mechanical Sewing Machine
I have a very old Riccar 440 model sewing machine which although is in very good condition, has not been used for many years!! We have lost the original manual and when we have tried to use it the thread...
Glancing through the manuals at Riccar's website I do not find a model 440, though there are models 404, 410 and 414. One of those manuals is likely close enough. While it could be a tension problem, breaking thread is usually a result of a damaged or incorrectly placed needle. Also, if you are using old thread, it may no longer have the strength necessary. The first thing to do is replace the needle with a fresh one, making sure that the flat side is to the rear of the machine, and that the needle is fully inserted. It's also a good idea to remove the feed dog cover plate and remove any buildup of lint. Also remove any lint that may be in the area around the bobbin case and hook. Here is a link to the Riccar site where manuals can be downloaded: http://www.riccar.com/help/manuals/
Please let me know how this goes, I think we can get you sewing without taking the machine in for service.
Jul 05, 2009 | Sewing Machines
Sewing Machines Logo
53 people viewed this question
Top Riccar Sewing Machines Experts
Chris Wetmore
yobo007
yobo007
Ngoro
Are you a Riccar Sewing Machine Expert? Answer questions, earn points and help others
