Question about Soyo Computers & Internet
Soyo inc GVLK3278AB pc vga screen reads no signal what's the problem
Posted by Jolly Mortum on
Joseph Wright
  • Soyo Master
  • 1,728 Answers
Either the cord isn't hooked up, a pin is bent, or the computer isn't sending a signal. In the last case, you may need a new graphics card.
Posted on May 11, 2018
I have a Samsung SensR470 laptop and i have linked up the VGA, audio, and power cables but the monitor is not showing anything. when i turn it on, it just goes into sleep mode or otherwise shows the...
its because you failed to read the Samsung manual on your PC
go there and read, it has HOT key , all laptops have a hot key
Fn key that turns on the external display VGA jack.
on rear of this SAMSUNG.
SLEEP MEANS THE PC IS NOT SENDING THE HORZ AND VERTICAL, SYNC SIGNALS. AT ALL.
THAT MEANS WHAT>?
It means the PC, VGA jack is turned off.
bad cable
bad monitor.
The PC can also be bad VGA chips, or worse,.
your first failing here is not saying why you are using VGA jack
is the Laptop screen dead too> (my other shoe falls off)
dang that be nice to know , no?
or like we do run that VGA to a projector? for say doing power point presentations, (done many before retired)
RTM, the manual is free to read any time of day, 24/7
each PC maker uses there own rules here, its there call
there design and their rules.
my HP its, Fn+F4, (toggle:, internal, external ,both or auto)
but yours is Samsung, ask them. or learn to use google?
Jun 10, 2017 | HP w1907 LCD Monitor
The monotor works on one of our computers but we can only get a message that reads "no signal" the computer is working and everything looks fine with the hockup we can not even get a menu...
sounds like the monitor is fine...it's the computer that has the issue. Does the computer that reads "no signal" work with a different monitor? If not, then it's def. the computer that is bad or some sort of hardware has gone bad. Could be onboard video that is bad, may need to get a cheap vga card. Let me know more details.
Mar 25, 2011 | Soyo DYLM1998 Monitor
My monitor screen stays black when i turn my pc on and it reads no signal on the screen but periodically the desk top screen will pop on is this asoftware problem
Sounds to me like a connector problem. Unplug and plug in again the VGA cable and check the VGA board is seated properly on the motherboard, if it has a separate Video board.
Hope you get it sorted out quickly and cheaply.
Nov 22, 2010 | Computers & Internet
When I connect my magnavox blu ray player to my soyo 32" lcd hdtv with audio video jacks my tv screen reads no source. how do I resolve this proble
Purchase an HDMI cable for excellent quality sound and pictures. I suspect the A/V leads will work if you set the TV to the AV channel that is assigned to the AV sockets otherwise you will get a blue screen and no signals.
Hope that clears your problem.
Nov 07, 2010 | Soyo DYLTO32C 32 in. LCD HDTV
Where do I get a cable to connect my laptop pc to the DVI input jack on the Soyo 32" LCD TV?
You will need either a DVI-I to DVI-I cable or a DVI-I to HDMI cable. Your computer should have a DVI-I output or HDMI. You can not directly connect a VGA output to the TV. If needed, you can purchase a VGA to component (Y/Pb/Pr) converter.
Mar 15, 2010 | Soyo DYLT032C 32 in. LCD Television
My 19" flatscreen monitor flashes on a blank screen and the power button light flashes on and off blue, no picture.
Problem in Your monitor VGA cable no horizental or Vertical signal.So it is not active standby mode.Check signal or VGA cable on not adjust properly CPU.or any other device.May be VGA cable was broken.Replace it.If you are not replace the part so you can get help any service technician.
Dec 27, 2009 | Soyo 19" LCD Flat Panel Monitor
Connecting Pc to Soyo the screen displays Not Support!
you will need a card for your tv which is quite impossible for the average jo to fit in as has to go on the inside to allow you to use VGA? really sorry but nothing governing wether tv makers tell you about it or not?
Jun 29, 2009 | Soyo 19" LCD Flat Panel Monitor
VGA Compatible
this is the download link for the drivers
http://www.soyo.com/product/Intel_Pentium_4/27/SY-P4X400_DRAGON_Lite/148
Jan 07, 2009 | PC Chips Computers & Internet
Monitor went black no picture no cable problem
remove the vga cable and see any display is coming up in your laptop like no connection or no signal
If not assume your monitor is gone so far from you, catch a new one and let it go
Thanks Hothawk
Jul 19, 2008 | Soyo Computers & Internet
Computers & Internet Logo
Top Soyo Computers & Internet Experts
Roy May
Jax Planet
Jax Planet
Are you a Soyo Computer and Internet Expert? Answer questions, earn points and help others
