SOURCE: Monitor not receiving signal
Basic network troubleshooting
A network may not work because of any of the below reasons. ... card is not connected properly, or that the card is not receiving a signal from the network.
Good Luck...Please dont for get to Vote..Thank You.
SOURCE: garmin gps 12 wont turn on.
Sorry to hear of the dead units. Are you using the correct power cable with a small hole in the centre of the plug? The GPS 12 is strictly limited to 7 volts only. The accessory cigarette lighter cable for this model has a circuit inside to drop the voltage from 12 to 7. Cannot be fixed. There would have been a plastic peg in the back of the GPS socket to prevent anything but the correct voltage Garmin cable being plugged in. Unfortunately these pegs are easily broken off. Yes, they are a good little unit even though well on in years. The next model up - the 12XL - can accept a wide voltage range and does not have the plastic peg.
All the best, Tony at KiwiGPS.
SOURCE: New car cd receiver will not power up, power is
if you didnt use a wire adapter and wired it yourself check that you have both powers to it. one power is on all the time and the other is power to power up your receiver.
SOURCE: Pin Name Color Description
Yes this is a good list of the voltages to be expected from a newer power supply on just the main header
