If you don't know how to look at a wiring diagram an test the electrical circuit for the blower motor ,do yourself a favor an take it to a qualified repair shop.
Blower Motor Problems Auto Repair Help
Free wiring diagrams here http://www.bbbind.com/free-tsb Enter vehicle info. year , make , model an engine size. Under system click on HVAC ,then under subsystem HVAC controls will pop up . Click the search button then the second blue link . Provided your vehicle has manual HVAC an not automatic . Automatic system doesn't have resistor , use blower motor control processor .
Blower Motor Resistor Function and Diagnostics
SOURCE: 1998 BMW 328i heater/AC blower is not running
You have clean the blower unit , may be its dirty then . and then check the blower resistor unit for malfunction.
SOURCE: 99 Buick Regal LS dual climate control. No heat passenger side.
the motor for the passenger side
blend door is shot
SOURCE: 2000 lincoln LS AC blowing hot air i've replaced t...
You need a scanner to diagnose,not a code reader.
The DATC Module ( Dual Automatic Temperature Control Module) is a possible
SOURCE: 1998 Ford Contour. The heater blower stopped
I dont know what these other guys are saying..I think they snif the glue!!! YOUR BLOWER FAN ASSEMBLY CAN EASILY BE REMOVED !!
1. Remove the wire
2.Find the "tab on the housing and pull it down while rotating the fan housing counter clockwise. This will remove the fan assembly. Plage 12 volts on the contacts to test the motor. If it works then the resister pack is blown. On the fan housing (near firewall ) you will see a plug going into a square looking box with a screw in it. Remove the wire then remove the screw to remove the resistor pack.. A new resistor pack is around 20 dollars at a ford dealer. Hope thie "FREE" info helps!
