Refrigerators Logo
Question about U-Line Refrigerators
Hi! We have a U-Line Echelon ice maker. It’s making a 5 beep alternateing 2 tone alarm. What can I do to fix.
Posted by Victoria Mills on
5 Related Answers
Anonymous
  • 3 Answers
SOURCE: water line to ice maker frozen
Check to make sure that the damper between the freezer and fridge is not broken or frozen open. Make sure that you shut off the water supply to the fridge until you get this fixed because the line could crack and then you could flood the house.
Posted on Jan 20, 2008
MARLON KELLER
  • 111 Answers
SOURCE: Ice Maker won't work...water line frozen?
HOLLOW ICE FOLLOWED BY FROZEN WATER CHUTE ARE THE FIRST SIGNS THAT THE WATER INLET VAVLE IS OR HAS FAILED, IT CAN ALSO CAUSE DAMAGE TO THE ICEMAKER BY BURNING OUT THEN TIMING GEAR DUE TO INSUFFIENT WATER OR FLOODING IN ICEMAKER WITH TOO MUCH WATER
If you need further help, reach me via phone at https://www.6ya.com/expert/marlon_56d9a24f02585258
Posted on May 30, 2008
Anonymous
  • 42 Answers
SOURCE: ice maker makes ice, but also drips water
cbscarter,
This may sound strange but you will find that the mold coating is peeling off of the aluminum mold. This causes the water to wick (climb) the loose coating and up over the top, leaking out making an ice clump on the ice maker and clumps ice in the container together. It would be easy enough for the average person to replace the ice make. Due to its age that would be smarter to replace than to repair the old one. It is a Whirlpool part #4317943 and comes with some instructions.
If this helped please rate me good, supertechks
Posted on Nov 25, 2008
Anonymous
  • 11 Answers
SOURCE: U-Line Echelon Model B12115
Whne you are on site, call 1-800-779-2547 for help. This is U-Line's tech support line,
http://www.u-lineservice.com
Posted on Dec 23, 2008
Anonymous
  • 56 Answers
SOURCE: Ice maker isnt making ice
Be patient.
See if you still have this problem tomorrow.
Posted on Mar 31, 2009
Uline Echelon Ice Maker P1 error code
P1 is a indicator of a slow or clogged drain check to make sure that every thing is draining good if line is clear make sure pump is coming on to pump the water out of the bin. once all is clear unplug the unit for an hour then plug back in this will clear code unless you still have a drain issue.
ULine CLR2160S00 was making ice then the icemaking started to slow then none at all had refrigerant replaced last year and everything else seems to be working fine,,, just no ice
Does the ice maker get water? Could the fill line be blocked? I found on my freezer ice had formed at the end of the tube and once I removed the ice it has worked fine since.
2helpful
After having the ice maker turned off then turning it back on, the line is frozen. My husband has thawed it several times right above the ice maker near the back and it works O.K. until we turn it off...
Sorry to hear about your problem. Sounds like you have a defrost issue. Hence your unit is not defrosting. All of this apply's if your freezer side has ice on it. If not. you have other issues, this does sound funny, but this is why your refrigerator side is warm, or not cooling.
Here is a list of some things that can go wrong.
1. Defective heat coil
2. Defective defrost timer
3. Defective defrost sensor
4. Defective Fan
5. Defective compartment inlet damper (on some models)
You should call a service company to resolve your issue.
Since I tried to help you, Please help me and Rate/Vote on the response. Thanks
Frigidaire alarm for fridge keeps beeping
I would try switching the breaker. That will probably work.
ICE MAKER FROST UP AT CHUTE
is this a u-line? Or a GE? If its a U-line make sure the freezer door is closing and sealing. If its a GE then check the gasket and make sure that is sealing.
3helpful
2answers
Ice maker shooting water along wall of freezer
Hi...
You need to check this
Regards
PCmania
1helpful
Leak out of the from of the ice machine - flashing p1
P1 means a problem with your drain. Most of the time its a kink in the line. Double check your drain line or it could even be a bad drain pump.
U-line model ulr-60b
hi,
periodical clean can smooth the operation of your ice maker.
at this link you can have the ice maker cleaning guidelines:
http://lib.store.yahoo.net/lib/usappliance/echelon-icemaker-manual.pdf
Top U-Line Refrigerators Experts
Marvin
Marvin
W.L.
Kardoc
Are you an U-Line Refrigerator Expert? Answer questions, earn points and help others
