I love these plants for their ease of growing and spectacular colours!
The answer to your question partially depends on what colours you have or want. Other than that they pretty much grow anywhere in a good sunny spot, and unless your soil is terrible, they dont need fertilising, just plenty of water. If you do fertilise then everyday fertiliser is fine but depending on its composition it may change the colour of the flowers.
This excerpt is from a web page listed below:
"Hydrangeas are amazingly versatile in that you can actually alter the flower colours to suit your needs. The flower colour in most forms relates to the acidity or alkalinity of the soil. In acid soil (pH 5 or less) hydrangeas are usually always
blue. As the soil pH climbs towards the neutral and alkaline end of the scale (pH 7 or more) hydrangeas turn
mauve, pink and red. A blueing tonic (containing aluminium and iron) will turn pink or mauve hydrangeas blue. It should be applied once a month in March and April and again in August, September and October, following the directions on the pack. A cup of lime (calcium carbonate) added to the soil in spring will cause blue or mauve hydrangeas to turn pink. White flowering hydrangeas will remain white regardless of soil pH."
http://www.burkesbackyard.com.au/fact-sheets/in-the-garden/flowering-plants-shrubs/hydrangeas/#.WAWfKzJg3cM
If you suspect root rot is taking hold poke a dowel into the soil to the bottom of the container and pull It out to allow air in the hole for ventilation
Thanks I pokes a few holes yesterday to be sure
