Source : https://sumppumpguides.net/best-sump-pump-alarm-reviews /
if your basement run out with the basement flood! and you backup sump pump alarm not working the while the flood overflow we have the compared many sump pump alarm here but the watchdog sump pump is the perfect one works efficiently while flooding in basement.
Does it have power to the charger?
SOURCE: sump pump drain
Storm sewer or rain water run off area. In other words , almost anywhere where it won't come back in.
SOURCE: Little Giant Sump Pump Backup System Alarm Keeps Screeching
is there water? sensor maybe bad, or pump failing to cycle
SOURCE: I have a broken sump pump, Flotec model # FPOF360AC
Same pump, same problem. H/D sells the pumps, but no parts. Here's a link to a vendor of Flotec parts. http://www.pumpvendor.com/Flotec_Parts_List.html
SOURCE: why is my basement sump pump Model Wayne PTU33 humming?
well is it pumping first, if not sounds like its stopped, if its still going sounds like its warn, like the bearings are about to go, turn it off and check its not hot.. sure sign theres a problem!!!! if it is....
SOURCE: watchdog sump pump want stop beeping
if you have a home entertainment system just turn it on and up kidding the sump pump for our home is always running i have never heard in beep just whines constantly Is the pump still working? I have had pumps go bad before but they never beeped they didn't do anything after burning up the motor i wonder if its a battery maybe 9v
