But I press this the Go Button the shaver starts to go down but stops almost immediately and never enters the cleaning solution
SOURCE: Norelco shaver won't turn off
You should check the switch behind the batteries. You likely dislodged the piece of plastic that presses on the switch. It's simple to place back properly--if that's what the problem is.
SOURCE: Norelco Electric Razor problem: Jet Clean System won't work
You need to fill the based to the max solution line. There is not enough solution in the container.
SOURCE: Norelco shaver 6866XL won't charge, light glowsred
The battery is probably one with multiple cells and one (or more) of them has shorted preventing the total from reaching a voltage that appears as fully charged.
If the cells are Ni-Cads, this is a common problem with them and when a battery-operated item of mine fails, I replace those older types with NiMH cells if the battery compartment can accept them.
I have 'restored' countless NiCads over the years by 'zapping' them with a fairly high current for a second or two; voltage isn't important as long as it is in excess of 2-3 volts but the source should have a few amps capacity.
This type of cell grows 'whiskers' that will cause them to short completely or develop a path that causes them to self-discharge faster than normal.
SOURCE: Using Norelco 3801XL shaver in Europe
hello. In order to use these devices in Europe you need a power adapter. Go to this link to learn all about it
http://goeurope.about.com/od/electricityineurope/tp/power_adapters.htm
Joe. Please rate my answer as very helpful. thank you
SOURCE: Philips Norelco Arcitec electric shaver:
This is a travel lock feature. The lock is activated by pressing the on/off button and holding it for 3 seconds. This will lock the razor in case it is turned on during travel.
