Cameras Logo
Question about Nikon Cameras
How do I turn my Nikon Coolpix S3000 to auto mode. I need a manual
Posted by Maureen Libera on
Steve Alexander
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Scholar:
  • Nikon Expert
  • 165 Answers
You can Download a PDF manual from Nikon for FREE. Even if I have a paper manual I like the PDF because I can search it, and that can save LOTS of time.
Posted on Jun 02, 2018
5 Related Answers
Anonymous
SOURCE: Nikon CoolPix Flash Problem
This happened to me too!
Turn the dial to setup, push the menu button & select reset all. This will restore the defaults & let you use the flash again.
Posted on Mar 21, 2008
Anonymous
  • 11967 Answers
SOURCE: my nikon coolpix s3000 won't connect to the
Use a card reader instead of the camera.
Posted on May 17, 2010
Anonymous
  • 11967 Answers
SOURCE: My Nikon Coolpix S3000 has
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Aug 07, 2010
caroldon
  • 17130 Answers
SOURCE: nikon coolpix s3000 lens error
Remove battery replace and switch on as you tap on the lens hood, repeat to see if the lens jamming is released. If not you will require the help of Nikon service for the estimation and spare.
Posted on Sep 28, 2010
Anonymous
  • 88 Answers
SOURCE: how do you charge a nikon coolpix s3000?
It comes with a wall jack that powers the included USB cable. Plug the USB cable into the wall jack and into the camera to charge. You can also charge from a PC if you connect the USB cable to the PC instead of the wall jack.
Posted on Jan 04, 2011
WHY MY NIKON COOLPIX S3000 FLASH NOT WORKING?
okay let mi think....
you cant charge a nikon camera via usb port the usb port is data only
please reply and try to use a nikon coolpix s3000 charger
Nikon coolpix lens error
This camera needs to be sent away forrepairs. Just like a motor vehicle, some repairs to your camera require atechnical specialist to fix your problem.
I can turn the camera on but it buzzers and then when i click the shutter it comes up with a f5.3 message please help
It sounds like maybe you have your camera in manual focus mode, or you have the micro feature activated. Make the change in the menu to put it in 'auto' mode, and the micro key is downward on the round 4 direction selection wheel under the
"OK" button. This was my fix when I got that same message. Good luck. I continue to have issues with this camera and it's less than a year old. Nikon may have made a stinker with this model.
1helpful
New to photography. Coolpix s3000. shooting in auto mode. When taking a photo of someone and they move just a little bit, say their hand it blurs. Is this normal for this camera. I have an older Nikon and...
Hi, With auto mode on that camera that is normal I've found. Auto mode on that camera seems to leave the shutter open just long enough to capture the tiniest bit of motion. If you're looking to shoot in a mode where that doesn't happen I suggest shooting in sports mode or kids mode.
1helpful
2answers
Manual for Nikon Coolpix S3000
You can download the user manual for this camera from this link, just click HERE.
1helpful
Nikon s3000 Coolpix digital camera user's guide
You can download the instruction manual in PDF format by clicking this link.
Adobe PDF Reader is required to view this manual. Click here to download the latest version of Adobe Reader.
Thanks for using FixYa.
I have a brand new nikon coolpix s3000. it's on full-time auto focus. Any ideas?
You can change this in the menu while in shooting mode. This is from page 48 of the manual:
Choose how the camera focuses.
A (auto) M d (Shooting menu) M I Autofocus mode
A Single AF (default setting)
The camera focuses when the shutter-release button is pressed halfway.
B Full-time AF
The camera focuses continuously until the shutter-release button is pressed down
halfway. Use with moving subjects. The sound of lens drive movement will be heard
while the camera focuses.
1helpful
How can i see the battery status ???
The camera won't show a battery status until the level drops below some threshold. See the "Step 1: Turn the Camera On and Select Auto Mode" section of the manual (page 22 in my copy) for what the indicators look like.
Why can't I connect my Coolpix s3000 to my Vista
Try using a separate card reader to download your pics.
My Nikon Coolpix S3000 will not take a charge. It
You shouldn't have to try to fix a new camera. Take advantage of the warranty.
Top Nikon Cameras Experts
Steve
David Shaub
Are you a Nikon Camera Expert? Answer questions, earn points and help others
