Question about Summer Infant Baby Gear
I’m about to freak out ?? I have a summer infant dual view monitor. It’s been amazing for almost 4 years. Now the thing keeps saying no signal. Unless I’m literally standing next to the camera with the monitor. Soon as I even turn around the signal is gone. It was working fine a week ago. Then went in and out. And now it’s just not working. Unless I’m right there. I did the whole syncing thing. Took the battery out. I want to go to bed! And I can’t bc I have no way of hearing my 5 month old. Ahhh
Posted by Tiffany pronovost on
john h
    Top Expert:
  • Summer Infant Master
  • 23,438 Answers
Either problem with antenna receiver circuit
Posted on May 09, 2018
5 Related Answers
Anonymous
SOURCE: Longines watch problem
Some longines watch has built-in battery gauge. When battery is low, the second hand jumps every four seconds. If you have new battery installed and the problem persists then there is a short circuit somewhere that drinks a lot of battery juice.
Posted on Mar 28, 2008
Anonymous
SOURCE: turn signals
replaced turn signal flashers and muti switch turn signal still won't work Why?
Posted on Nov 11, 2008
Anonymous
SOURCE: My 37'' Vizio Flat Screen TV keeps shutting it's self off
I had a problem with mine shutting off randomly and (luckily under warantee still) the guy came out and replaced the mother board. If you're under warantee still just call vizio.
Posted on Feb 21, 2009
kdm56
  • 48 Answers
SOURCE: Battery on BMW 740i keeps dieing
you need to disconnect one side of the battery, put one lead from an ampmeter on the battery post you have disconnected and the other ampmeter lead on the cable you took off the battery. with nothing turned on on the car , all doors closed the reading on the ampmeter should be no higher than 0.17 amp, if it reads a lot hgher go to the fusebox and remove one by one all the permanent supply fuses looking at the reading every time until you find the circuit that is causing the high reading, this will be the drain. alot of the time it can be central locking system playing up, boot light, glove box light not switching off, stereo wired wrong. hope this helps.
Posted on Apr 30, 2009
Anonymous
SOURCE: the ac adaptor no longer works the summer infant
Did you findout were to get one?? I am having the same problem.
Posted on Jun 01, 2010
Summer infant video monitor beeps frequently that it has lost signal...it does this episodically throught out the night. Is there a solution for this problem? Or is this monitor a lemon?
If the sending and receiving units are going through walls or one is upstairs and the other is downstairs it may not have the range you need as walls will knock down the signal. Sounds like your right on the edge of the range maybe try to move the units closer together if possible and see what happens.
Apr 22, 2017 | Summer Infant Baby Gear
Why does it keep "saying" out of range?
if camera and base are within a few feet of one another does it have a problem obtaining a signal (syncing ) ?? as if it works ok then there might be a object that is getting in the way of the signal , radio waves move from its transmitter (camera) towards its receiver (monitor) in a straight line , if there is too large a mass in the way then the radio wave can't penetrate it and will be "lost" also ck both the camera's and bases battery levels (if they have one) for proper peak power level , as it takes energy to drive the radio signal towards its receiver .
Feb 09, 2016 | Summer Infant Secure Sight Handheld Color...
Summer infant baby monitor has frozen screen
My monitor was stuck on one of my cameras and when I turned it off and on again it was stuck in the hello screen. I took the battery out and put it in again. Then I pressed the button on the left (I have a best view) and pressed the right arrow key until I got to the view can screen. It turns out something was wrong with just one of my cameras as I could view the other one. I unplugged and replugged that camera and that solved my problem!
May 01, 2012 | Summer Infant Best View Handheld Color...
My monitor has lost its pitcher and is saying no camera
The camera is not transmitting an RF signal to the tv, check to make sure the camera is receiving power, if okay! the camera must be dismantled to see if any wires or plugs have come loose.
Feb 06, 2011 | Summer Infant Best View 25" Color Video...
My Summer Infant Best View Handheld Color Video Monitor with 2.5" Screen shut off while I was using it. I thought the battery died so I plugged it in and nothing happened. I left it charging all night and...
I'm having the same problem with the view. I have sound but no picture... I charged it over night and started to use it, But the video keeps turning off and all i get is the sound, i have to keep pressing video on. I have read a lot of peoples problems and this is a major one.... I'm taking it back to babies r us ! so much for 140.00 bucks !!!!!!!
Sep 25, 2010 | Summer Infant Best View Handheld Color...
My brand new summer infant slim and secure baby monitor parent unit will not hold a charge. It only works when plugged in. Customer support sent a replacement battery but the same thing happens. Does...
Keeping the LED monitor portion on the entire time sucks the battery pretty quickly on mine. It has an automatic shut off button but if you're like me, you probably check it constantly. I found that when I'm not turning on the LED portion and also turning it off when he's awake and with me, it keeps the charge MUCH better.
Aug 03, 2010 | Summer Infant Slim Secure Handheld Video...
Baby Gear Logo
495 people viewed this question
Top Summer Infant Baby Gear Experts
Falling star
Colin Stickland
Colin Stickland
Paul Bade
Are you a Summer Infant Baby Gear Expert? Answer questions, earn points and help others
