Cameras Logo
Mitch Proulx Posted on May 09, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How could I setup an external flash to my Canon rebel xs
My camera is not recognizing the flash
Paul Green
Level 2:
Prodigy:
An expert who has answered 500 questions.
  • Canon Expert 527 Answers
  • Posted on Jan 21, 2019
 Paul Green
Canon Expert
Level 2:
Prodigy:
Answers
527
Questions
Helped
232906
Points
686
You need to use triggers, one on the hotshoe and one on the flash gun. Unless you're using the most up to date compatable kit have a look at Younguo triggers on Amazon
5 Related Answers
A
Anonymous
  • Posted on Oct 29, 2008
SOURCE: Quantaray QDC 900WA no longer works on Camera Hot shoe
tengo un flash QDC 900WA PERO COMO HAGO PARA QUE TRABAJE ESTAVA TIENE FUNCION ESLAVA EL FLASH O TENGO QUE COMPRAR LA UNIDAD ESLAVA APARTE
Anonymous
  • 121 Answers
  • Posted on Dec 21, 2008
SOURCE: attaching my Canon Rebel XS to my Baush & Lomb telescope
You need an adapter ring that adapts the camera's lens mount to the telescope eyepiece. Most telescopes use the same size eyepiece, but you should ask the vendor before purchasing to make sure the ring will fit your particular telescope.
Anonymous
  • Posted on Jun 11, 2009
SOURCE: Internal flash not working because of non compatible flash installed
Solution:
Look at the external flash socket.
With the camera in "normal position", i.e., poiting away from you, you shoul see a very small (I realy mean very small) piece of plastic under the rigth inside of the flash shoe... it is the "external flash sensor". It probably is stuck. Work with the point of a knife to try and release it.
In more detail, if you look carefully at the external flash shoe, the are two metal pieces that will help create some pressure. So the flash holder (shoe) is made of two parts: a very rigid one and the metal blades that create the pressure. Look under the blade located nearest to the shuter button.
If you can locate the plastic piece (black in my camera, but can be white) try to have unstuck.
Worked with my camera.
regards
Mig
Anonymous
  • 11967 Answers
  • Posted on Dec 19, 2009
SOURCE: Canon Rebel XS displays busy signal after I take a
Is your card nearly full? Is your battery fully charged?
Anonymous
  • 2335 Answers
  • Posted on Apr 15, 2010
SOURCE: The metering screen inside the viewfinder keeps
I can help you fix the BUSY Error or Error 99 of your Canon EOS Rebel XS / Canon EOS 1000D.
Installation of this Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update will solve these problems:
  1. Some cameras may exhibit a phenomenon in which the LCD monitor does not display, the shutter does not release, and the BUSY indication remains lit in the viewfinder.
  2. The message, "Err 99 Shooting is not possible. Turn the power switch to<OFF> and <ON> again or re-install the battery", appears on the camera's LCD monitor, and after the above operation is carried out,the LCD monitor displays in a language that is different from the actual language setting.
See the firmware instructions and download the firmware upgrade by following these Fixya Tips :
  1. Follow this link to download a pdf version of the firmware installation instruction guide.
  2. Follow this link to download the Windows Version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
  3. Follow this link to download the MAC version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
  4. Follow this link to download the Canon EOS Rebel XS / Canon EOS 1000D Instruction Manual.
I hope that helps.
My flash wont pop up on my canon rebel xs. says err05 PLEASE HELP
canon rebel xs faces late display on lcd taking 8 minutes especially in cold weather solution please
tip
Canon Rebel XS Firmware Update PDF Models: Canon EOS Rebel XS / Canon EOS 1000D ...
Would you like a digital, searchable, pdf version of the Canon EOS Rebel XS / Canon EOS 1000D Firmware / Installation Guide?
I hope that helps.
______________________________
Follow this link to download the Windows version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
1helpful
2answers
'busy' message in view finder won't take a picture
how can you download and update firm ware when you cannot see anything on the screen?!!!!
3helpful
The metering screen inside the viewfinder keeps flashing BUSY, and the display screen will not show anything.(Canon Rebel XS Digital SLR)
I hope that helps.
Camera will come on but the lcd wont when i try to take a pic it flashes a busy signal in the veiwfinder
I hope that helps.
Canon 100 d screen is blank seems to be frozen when trying to take a pitcure flash will pop but will get busy sign battery fully charged
I hope that helps.
My 9 month old camera will power up, focus and flash however it will not take the picture. When looking through the view finder, "busy" flashes when trying to take the picture. The battery is fully charged...
I hope that helps.
1helpful
Canon Rebel XS says it's busy
I can help you fix the BUSY Error or Error 99 of your Canon EOS Rebel XS.
Installation of this Canon EOS Rebel XS firmware version 1.06 update will solve these problems:
I hope that helps.
7helpful
Solution:
regards
Mig
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
