Ovens Logo
Question about Viking Ovens
Viking professional French door double ovens not heating properly
The top French Door ovens. The top with thermometer at 350 heats correctly. The bottom oven set at 350, heats to 400 degrees with thermometer. How to we adjust this?
Posted by Lisa Easley on
5 Related Answers
Anonymous
SOURCE: bottom oven of dacor double oven
I found the lower circuit breaker had been tripped. That didn't fix the problem but upon further inspection whoever had worked on the unit years ago had dropped a screwdriver that had lodged between the oven wall and the rear casing and shorted out the lower heating element. I removed the screwdriver and oven works fine now. I don't think that will solve the cmmclow problem but maybee the curcuit breaker is tripped.
Posted on Mar 12, 2008
aborcass
Ron Coons
  • 2651 Answers
SOURCE: Oven temperature only gets to within 20-25 degrees of temp. set
next to last page in your manual
Adjusting Oven Temperature
Oven temperature has been factory calibrated and tested. If
oven consistently over or under cooks food, adjust thermostat.
Oven temperature can be increased or decreased 35°F. To
avoid over adjusting oven, move temperature 5°F each time.
1. Push BAKE pad.
2. Press + pad until an oven temperature greater than 500°F
shows in display.
3. Immediately push and hold, approximately 5 seconds,
BAKE button until “00” appears.
4. Press + or - arrow pad to adjust oven temperature.
• To increase oven temperature (for a hotter oven), Press
pad until a positive number appears in display.
• To decrease oven temperature (for a cooler oven),
Press pad until a negative number appears in display.
5. Press OVEN CANCEL pad to save adjustment.
• Setting is saved if power fails or is disconnected.
heres a link to the entire manual if needed
http://shop.amana.com/assets/pdfs/literature/32103601.PDF
Posted on Nov 27, 2008
Anonymous
  • 8197 Answers
SOURCE: magic chef manual
You can download it here but you need the right model #.
http://shared.whirlpoolcorp.com/product_literature/search.jsp?siteCd=MCF
As for the temp adjust it is best if you get an repair man out to do that.
Good Luck
Posted on Dec 18, 2008
barkencoa
Barry Coates
  • 3463 Answers
SOURCE: Oven door isn't closed tightly on both sides.
If it is a door that lifts up and down, then the only solution is to replace both door hinges, as they are not normally adjustable, it is the springs that are weak.
Plz rate my solution.
Thanks.
Posted on Jan 06, 2009
Anonymous
  • 5 Answers
SOURCE: I have electric double oven VEDO275SS by Viking
you need to have a new thermostat fitted or the old one re callibrated if possible
Posted on May 29, 2009
Viking oven VESO107CSS, tried to start cleaning mode, it would not start. Now the oven will not heat and the cleaning light is flashing
If your Viking oven VESO107CSS will not heat and the cleaning light is flashing, it's possible that the oven control board is experiencing a fault or malfunction. Here are some steps you can take to troubleshoot the issue:
  1. Turn off the power to the oven: Before attempting any repairs or troubleshooting, make sure the power to the oven is turned off at the circuit breaker.
  2. Check the door lock: If the oven door is not properly locked, the cleaning cycle will not start. Check to make sure the door is securely locked.
  3. Check the oven control board: The control board may be experiencing a fault or malfunction. Try resetting the control board by turning off the power to the oven for a few minutes, and then turning it back on. If this does not work, the control board may need to be replaced.
  4. Check the thermal fuse: The thermal fuse is a safety device that protects the oven from overheating. If the fuse is blown, the oven will not heat. Use a multimeter to check the continuity of the fuse, and replace it if necessary.
  5. Check the heating element: If the heating element is damaged or burnt out, the oven will not heat. Use a multimeter to check the continuity of the element, and replace it if necessary.
If none of these steps solve the issue, it's recommended to contact a qualified technician or the manufacturer's customer support for further assistance.
1helpful
Oven doesn't seem to heat up enough
There is a cooling fan In a STOVES 720 to keep the fabric of the oven cool. If this fails the overheat thermostats will cut in and shut the heating elements off. The cooling fan does in fact blow air out of various places in and around the doors. The top oven has a small element and takes a long time to warm up. If you are not confident that the thermostats are working correctly, then I suggest you purchase an oven thermometer from someone like Lakeland and see how that relate to what you are actually setting on the cooker dial. As I said the top oven leave a lot to be desired!
Double wall oven: Model JKP26GOP13G. The upper oven heats but not up to the setting input. If setting is 350 F, for example, the stove only gets to around 200F.
I trust the door is sealed correctly. If heat is escaping this could be the problem. If the seal is okay the only thing it could be is the oven thermostat controller. It sounds like it is faulty and needs replacing.
Feb 12, 2011 • GE Ovens
3helpful
How long to run self clean on viking professional
The "Self Clean" will run for quite a while up to 4 hours I believe, during this time, the stove heats up to about 900 degrees!! and during this time the Door is automatically closed via special locks. It will allow you to open once it is finished, it should "Signal" this event.
2helpful
Heat escaping, uneven baking, longer cooking times
Either the seals need to be replaced, or you may have weak oven door hinges, and the door is not closing properly.
Only solution would be to replace both hinges if this is the case.
Please rate my solution.
Thankyou.
Doesn't get as hot as it should
the range has two thermostats one for each oven located under the oven knobs. put a meat thermometer in the oven and adjust the thermostat screw with a small flat screwdriver untill the oven turns off at the correct knob temp.
registered on the thermometer.
then adjust the knob screw on the back of the knob to match that temp setting.
clockwise is hotter counterclockwise is cooler
Apr 21, 2009 • Ovens
1helpful
Uneven cooking in fan oven
There are many reasons for uneven cooking in any oven
These are just a few possibilities.
Not pre- heating oven
Putting too much in the oven, thereby restricting air circulation.
Not putting on correct shelf level.
Use of foil in the oven which can reflect heat.
Badly fitting door.
Perished door seal.
Thermostat not controlling temp properly. Check with oven thermometer.
There plenty of other resons besides these, but these are some of the more important ones.
So do check these points..
If you are still experiencing problems, then you will probably have to call an oven expert in too look at it.
.Thanks.
2helpful
Viking Double Electric Oven VEDO127T
Probably a faulty heater element, some ovens have more than one element in the compartment, so it is possible you only have part heat.
Top Viking Ovens Experts
Angel Joseph Jr.
Angel Joseph Jr.
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you a Viking Oven Expert? Answer questions, earn points and help others
