Question about Panasonic Audio Players & Recorders
How do you turn off a Panasonic SA-PM12 COMPLEETLY?
Posted by John Engler on
Grubhead
  • Panasonic Master
  • 5,700 Answers
Because it has a clock built into it, you are not meant to turn it off completely. However if you wish to do so then you must switch it off at the mains or remove the plug from the socket. Doing so will probably loose the time settings though. As I suspect it has no back up supply for them. So if you want to use the clock again it will have to be set.
Posted on May 14, 2018
Panasonic SA-bt228 won't power on or open, just clicks
Im having the same problem, it turns on for a second and then immediately turns off. Any answers for this problem?
Jan 14, 2014 | Panasonic Sa-bt228 / Sc-bt228 Home Theater...
Got a Panasonic CD stereo system SA-AK410 When I turn it off after a few seconds it turns back on. Is this normal?
That's because you haven't set the clock on the system. I jumps to DEMO mode once you turn it off without the clock set. Clock can be set through your remote. Hope this helps. Cheers.
Oct 04, 2013 | Panasonic Remote Control Eur7710020...
I need owners manual for Panasonic CD Stereo system SA-PM12
The Panasonic website might have a free PDF of it.
Feb 02, 2012 | Audio Players & Recorders
I am looking to find an English version of the operators manual for the Panasonic CD-Stereo System SC-PMX2. Can you help? Thanks
I had some trouble finding a manual but the nearest match I could find was for model SC-PM12. Please take a look at the following link. If it looks like the right one then you can download a free copy from there. Fingers crossed... :o)
http://www2.panasonic.com/consumer-electronics/support/Audio/Home-Theater/Micro-Systems/model.SC-PM12
Mar 21, 2011 | Audio Players & Recorders
I hooked up the Panasonic sa-ht800V Home Theater Audio System SA-HT800V to an old tv the only hook up is the coaxial cable i turned TV to channel 3 and i get picture from the dvd is the a setting a need to...
Look at Page 12 if your TV only has RF coaxial antenna input...
http://www.retrevo.com/support/Panasonic-SA-HT800-Home-Theater-Systems-manual/id/312bh741/t/2/
Add in the Video cable (included) if the TV has an input for it and you'll be able to manage the SA-HT800 through the TV.
Make all the other necessary selections prescribed in the manual.
Jan 23, 2011 | Panasonic sa-ht800V Home Theater Audio...
Wher could I find mother board drivers for pm12 tl p4 atx I bought this mother board, got it to work, but the sound does not work
Possibly this link will help you, the driver is in the middle of the page.
http://www.bioticaindia.com/pm12-tl.html
For the correct soundcard driver you will need to know exactly what the chipset or sound device is called - there is a utility called driver magician http://www.drivermagician.com/ you can download that will tell you the maker and chipset number. Then do a google lookup for that exact driver. Driverguide usually has a good selection for nearly everything.
Oct 26, 2009 | DFI PM12-TL Motherboard
Error61 code
thats a "protect" mode..your audio outputs are stressed and overheating..will need to be replaced soon
Aug 26, 2008 | Panasonic sa-ht800V Home Theater Audio...
69 people viewed this question
Top Panasonic Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
John Wardlow
John Wardlow
Level 1 Expert
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
