Question about Ice Kitchen Appliances - Others
Line clr60b wont stop making ice
Uline clr60b won’t stop making ice. I have replaced bin thermostat and still won’t stop making ice. To install you install probe all the way to end(that is in ice maker)? Or did I install incorrect ? Ice thickness is not set to thick. I installed bin thermostat probe all the way to end of bar that is inside ice maker. Help!
Posted by Todd kerch on
etudelashes
    Master:
  • 246 Answers
Http://www.aramislashes.com/wholesale-mink-eyelashes/wholesale mink eyelashes WHOLESALE MINK EYELASHES MANUFACTURER-ARAMIS LASHES Our wholesale mink eyelashes is more lighter,softer and more Flexible, our 10 year's experience in wholesale mink eyelashes can bring you more hot fashionable mink lashes, you can get top quality from our lashes factory with fast delivery. Most luxury package wholesale mink eyelashes box is available.
http://www.aramislashes.com/wholesale-mink-eyelashes
Posted on May 08, 2018
5 Related Answers
Anonymous
  • 10 Answers
SOURCE: Uline ice maker not cool enough to make/keep ice
one of two things
1. fan under unit stopped up or quit
2. small freon leak usually in freeze plate
Posted on Dec 19, 2008
carldc3
carl carpenter
  • 82 Answers
SOURCE: Ice maker won't make ice after emptying ice bin manually.
make sure you push the ice lever back down
Posted on Jan 05, 2009
rylee_smith
Rylee Smith
  • 8619 Answers
SOURCE: Thin Ice on Whirpool Ice Maker
Hi
If  The ice maker has completely stopped producing ice Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
The ice maker is producing ice poorly When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
Please do rate the solution as "FixYa" if found useful and revert for further assistance.
Thanks
Rylee
Posted on Apr 05, 2009
Rich Wright
  • 286 Answers
SOURCE: Ice maker (Uline) just stopped working, not freezing, no noise.
U-line does make compressors as long as its not a r12 system. As far as the icemachine turn breaker off for a couple of min then try it. If same results then it could be a board.
Posted on May 15, 2009
Rich Wright
  • 286 Answers
SOURCE: uline clr2060 produces little ice
First thing is to remove the water from the trough. Pull out the grey standpipe in the back of water trough. Then see if the grid has a good frost pattern.If the frost pattern is NOT even then you need a service call to check the sealed system. If you do have a frost pattern check to see if the water is splashing over or make sure the drain is in the bin drain hole.If water is getting in the bin then the ice can melt as fast as it makes it.Make sure your cleaning with U-line cleaner.
Posted on May 28, 2009
Uline Echelon Ice Maker P1 error code
P1 is a indicator of a slow or clogged drain check to make sure that every thing is draining good if line is clear make sure pump is coming on to pump the water out of the bin. once all is clear unplug the unit for an hour then plug back in this will clear code unless you still have a drain issue.
Jan 17, 2014 | U-Line Icemaker
Uline bi98 ice maker
follow this test. and fix it. use the multimeter.God bless you
If the ice cubes have watery or hollow centers, the icemaker is getting too little water. Alternately, excess water or ice in the bin is caused by too much water. Turn the water supply screw to adjust. If adjustment does not remedy the problem, you may need to service the water inlet valve (see below).
If you suspect trouble with the motor or switcy in an icemaker, use a multimeter to test the component. If the motor or switches test faulty, replace either the bad components or the entire module. If not, you may only need to replace the thermostat (see below)
Oct 28, 2013 | Kitchen Appliances - Others
Ice maker keeps making ice, does not stop when bin is full
the ice maker should have what is called a bail arm that is what measures the ice in bin if there is one it should only move up and down if it moves any other direction the bail arm post could be broken
Oct 30, 2012 | U-Line Uline Origins Series...
Makes one batch of ice and stops
Check the postion of the ice bin thermostat. make sure the first batch ain't contacting the probe or the machine will simply shut down. SERVICE MANUAL
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jun 30, 2010 | U-Line Icemaker
Small refrigerator stopped working 75r
You have 2 wires. Unplug and put wires together. Plug unit back in and check to see if everything is running. Doesnt matter where the wires go with a 2 wire thermostat
Oct 09, 2009 | U-Line Uline Origins Series...
The bin arm on my Uline Model 402 ice maker broke off. I have a replacement bin arm. I took off the front plate of the ice maker unit, but am unable to thread the bin arm all the way through the bin arm...
1st remove the icemaker from the unit. Then take the faceplate off.You might find that the support housing is fighting you.You should be able to move the arm into place as long as the icemaker is out.
Jul 19, 2009 | U-Line Uline Origins Series...
Uline ice maker clr2060- makes ice continuously, would overflow and ice build up on condenser.
This is a problem when the thermistor in your icebin is not being satisfied.Now there is a break in the serial number to find out if you have a thermistor or a mechanical thermostat. If the serial number is before 03 (first 2 digits is the year)and the 2 digits between the dashes is 11(the month) the replace the bin thermostat. If newer then you need to replace board and thermistors.
May 04, 2009 | U-Line Icemaker
Ice maker runs continueously
I don't have the details on you machine but if I were going to trouble shoot this problem, assuming its a temperature probe I would power off the machine, remove the access panel and remove the temperature probe and check it with an Ohm meter or continuity checker for proper functioning by putting the probe in ice and see if it opens electrically. Sometimes the probe is not a simple thermostat type. The bin control on some machines is optical. The ice pile breaks a light beam to turn off ice making. Sometimes the probe is a thermistor. These latter two kinds of probes have electronics connected to them. A simple ohm check will not work for these cases. You can tell what kind you have by looking at it carefully. The thermostat kind that can be checked with a continuity checker or ohm meter is a sealed metal tube. The optical type has a light source and a separate pick up sensor. The thermistor type is a very small device on the end of a pair of wires. For the optical type or the thermistor type write back for more details.
Nov 30, 2008 | Hoshizaki Freezer Commercial Ice Machines...
AM-50BAE won't stop making ice
There should be a copper bulb located in the ice bin. This is the probe for the thermostat. If you follow the copper line connected to this bulb it will bring you to the thermostat, and you may can adjust it. Please let me know if you need any more help.
Nov 23, 2008 | Hoshizaki AM-50BAE Drain Pump Kit
Kitchen Appliances - Others Logo
100 people viewed this question
Top Ice Kitchen Appliances - Others Experts
jasbo
jasbo
NOEL
NOEL
Are you an Ice Kitchen Appliances - Other Expert? Answer questions, earn points and help others
