Question about Sylvania Televison & Video
I tried to auto scan my sylvania LC195SLX tv but since I dont have a remote to finish programming, my tv is stuck with no channels at all now. What do I do?
Posted by Melissa S on
etudelashes
    Master:
  • 246 Answers
Http://www.rollslashes.com/wholesale-mink-lashes/wholesale mink lashes WHOLESALE MINK LASHES MANUFACTURER-ROLLS LASHES 2018 New styles best wholesale mink lashes with customized packaging eyelash box.Natural Handcrafted wholesale mink lashes sets you apart,To make you as graceful as a swan.Natural Handcrafted best wholesale mink lashes,Your best selection.Worldwide shipping and Free shipping on orders.
http://www.rollslashes.com/wholesale-mink-lashes
Posted on May 08, 2018
5 Related Answers
Anonymous
SOURCE: AUTO PROGRAMMING T.V.
Your TV is in Showroom Mode - to change:
Menu>Picture>Mode>Power up>Home
Then go back and autosearch channels.
Posted on Feb 09, 2008
Anonymous
  • 541 Answers
SOURCE: Magnavox tv has cable channels 2-13 only. Lost
The set needs to be switched from antenna to cable in the setup menu. It is capable of either antenna reception or cable reception. Ch 2-14 are the same frequency for antenna and cable but above 14 they are different. That is why the picture is stoping at 14. After you switch it to cable auto program again. Thanks for using fixya.
Posted on Nov 13, 2009
Anonymous
  • 5 Answers
SOURCE: i need code for att uverse remote for sylvania
Sylvania Television 1004, 1007, 1018, 1027, 1153, 1056, 1057, 1059, 1060, 1124, 1150, 1145, 1279, 1296, 1387
Also try these. These are codes that may work with that type of tv with the att remote.
Posted on Dec 19, 2009
gopakumarg43
  • 76466 Answers
SOURCE: tv remote code for sylvania
Hello
Three digit setup codes for Sylavania TV are:
004/ 008/ 009/ 062/ 068/ 069/ 074/ 075/ 076/ 077/ 133/ 161/ 163
Four digit codes are:
0062 0004 0009 0135 0189 0183 0227 0456 0008 0068 0075 0141 0161
Codes for Sylvania TV with RCA RCR311B are:
1003, 1004, 1014, 1046, 1051, 1060, 1061, 1062, 1066, 1067, 1072, 1073, 1074, 1075, 1076, 1077, 1078, 1082, 1150, 1151, 1165, 1192, 1199, 1206
OK.
Posted on Jul 31, 2011
NicK Hale
  • 12 Answers
SOURCE: Lost remote for vr-2218. Trying to do auto channel scan--says to hit ENTER, but without remote, can't do ENTER. I have FIOS, but Verizon remote won't program TV. Any idea what code may be?
Codes listed in my manual for White Westinghouse are 0169 or 0003 or 0014 or 0043. Are yousure though there isn't a flip down panel somewhere which gives you the option to access "enter"
Posted on Oct 07, 2012
I pushed auto scan on my sylvania LC195SLX and I dont have a remote so I couldnt do anything and now the tv is just stuck. Help I get no chann3ls at all
http://www.avonlashes.com/private-label-mink-lashes/private label mink lashes PRIVATE LABEL MINK LASHES MANUFACTURER-AVON LASHES Real Mink Fur Special Natural Best private label mink lashes With Private Label Strips.Special Natural Best private label mink lashes to make you as graceful as a swan.Special Natural Best private label mink lashes,Worldwide shipping and Free shipping on orders,Free Samples Available!Welcome you send message to me
May 08, 2018 | Sylvania Televison & Video
I just recieved the Sylvania LC195SLX from my grandfather, it has no remote, but we are using dish network remote anyway, the channel is stuck on 5, and i can't change any channel or get a signal from...
Hello! I hope that you have gotten this resolved, but if not, here are some steps to do so. You can program the remote to the TV first and then use that for this, or you can use the buttons on the TV itself.
Remote to TV Steps:
1. Hold down the clear TV button until all lights light up at the top of the remote
2. Punch in a 3 digit code (provided below)
3. Press the # (POUND) button
4. Try powering the tv on/off, and the volume. If one or more of these functions do not work, start over from step 1 with a different code
527
733
632
Satellite picture back:
If you are at TV1, where the receiver box is located, the tv needs to be on channel 3 or 4.
If you are using a coax cable, the TV needs to be on 3 or 4.
Depending on the cable that is running between the receiver and the tv, the tv may need to be on an input, such as video 1 or 2. If you are at the TV2 location, where there is no receiver, then the tv needs to be on channel 60 or 73.
If you are using an HDMI cable, then the TV will need to be on an HDMI input
If you are using Component cables, your TV will need to be on a component input. (Usually Comp 1 or 2)
If you are using RCA cables, then the TV will need to be on a VIDEO input (Usually Video 1 or 2)
Becki Barned
DISH Network Customer Service
[email protected]
Jul 13, 2011 | Sylvania LC195SLX LCD TV
I have a Curtis 24 inch Full HD LCD TV 2425A never used Trying to set it up and their was no book in the box it says to run Channel Auto scan .it is hooked up to Dish satelite ant. .to run the auto...
Used the tv remote go into tv Menu goto SETUP go down Ch. enter pick CABLE and enter again.Tv now will go into auto scanning for CABLE channels.After the auto scan done for the CABLE channels are finish.After this u will able to go to channel 60 to used the dish remote.
Apr 24, 2011 | Curtis Televison & Video
What are codes for remote controller
What make and model remote do you have? Is this remote for the Sylvania LC195SLX?
Nov 05, 2010 | Sylvania LC195SLX LCD TV
Problem for Sylvania LC195SLX LCD TV Channels will not program in tv.check with different tv it works
It looks like your TV doesn't have a digital tuner in it. Without that you won't be able to receive any broadcast television stations. The spec sheet is here: LC195SLX the tuner is listed as just ATSC/NTSC - not digital. You will need a cable or satellite box to receive stations.
Jun 14, 2010 | Sylvania LC195SLX LCD TV
when turning on the tv I get a screen states no channel is registered. and press hold enter key on the remote control for 3 seconds.. one problem is I dont have a remote to the tv only an ge unversal remote which can the get programed
Mar 13, 2010 | Sylvania LC195SLX LCD TV
Need code for sylvania lc195slx
hi! i have a couple of codes here for your sylvania tv just try them 0062 0004 0009 0135 0189 0183 0227 0456 0008 0068 0075 0141 0161 hope it would help! goodluck!!!!
Sep 02, 2009 | Vizio Gallevia GV42LF 42 in. LCD...
Sylvania TV stuck in Game mode remote no longer works
go up to your TV and go into the menu. Go to the channel selection and run the auto select for channels. This will take some time but the TV will end off the first channel found, the only thing is you cannot get back into video mode without the remote
Mar 26, 2008 | Sylvania 6413TC 13" TV
Televison & Video Logo
192 people viewed this question
Top Sylvania Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
