Question about Locks & Locksmithing
I have reset the code but now it wont lock is this cause its locked by key if so i have lost this to
The key has been lost and have gotten in to the safe but it wont lock due to the locking bars being stuck out how do I sort this out please
Posted by brian evans on
5 Related Answers
keemo68
Ronald Mueller
  • 1263 Answers
SOURCE: 2002 oldmobile bravada ignition key is stuck in lock position
try and turn your steering wheel a little bit left or right and and the same time try and turn the key when it turns toward the dash then try and turn the key back. try and repeat this several times if neccessary. this should work. please rate this solution. thanks
Posted on Aug 30, 2008
Anonymous
SOURCE: my sentry brand safe is
my bars are engaged my key pad fell in aand i lost keys who should i talk to?
Posted on Nov 24, 2008
tmburke
  • 76 Answers
SOURCE: lost key
To order replacement keys, for small chests and files, you will need to know the key numbers which can be found right around where the key goes in. It should be a stamped number, letters, or both located around the keyhole. For Personal, Home and Home/Office Safes, you will need the model number and serial number. I think that the most economical place to buy keys is from www.SentrySafeShop.com. You can do a search for "lost keys" and it will give you a screen where you can enter your model number and key number. (It is a very easy screen to use. They just need 1.)Model # and 2.)Serial or Key #.)
In Summary:
For Small Chests or Files: A lock reference number is required. It will be a letter, a number, a letter and number, or "blank" (no letter or number), engraved/located on the silver cylinder of the lock. These are model numbers 0500, 1100, 1170, etc...
For Personal, Home and Home/Office Safes: (model numbers will begin with: S0, S3, S4, S5; I0, I3, I4, I5; A3, A4, A5; J3, J4, J5; L0, L3, ,CS,CSW,DA,DS,KS,KSW,MS,MSW,OA,OS,and SC): Indicate your model number and the safe serial number found on the front right-hand side of the door, between the hinges.
Here is the direct link to the key replacement screen: http://www.sentrysafeshop.com/Keys-Sentry-Safe-Replacement-Keys-p/keys.htm
Posted on Apr 28, 2009
Anonymous
SOURCE: lost code for keyless unican lock
I just performed this on my lock and it's quite simple. The instructions are in the attached manual.
http://www.kaba-ilco.com/access_control/access_download.aspx?File=simplex_1000_installation_instructions_d8_pkg_2280.pdf&Attachment=True
Cheers.
Posted on Jun 26, 2009
Anonymous
SOURCE: gordon item#45891 digital safe, lost code the door is open
there is red button on the inside of the door (hinge side) press this , then key in a new code
Posted on Oct 10, 2009
Lost key to reset code
if it just for your kid you could duct tape it closed
Mar 23, 2014 | Brinks 4-Dial Combination Padlock
Security code for gotten.
hi its highly impossible to reset the phone settings if you had forgot the lock code !!!! only way u can reset the settings is you have update a new software to mobile and so everything gets reset
Jul 30, 2009 | Samsung D880 Cellular Phone
I have lost my pin and backup keys + battery dead!
i got the same problem i lost my key and cant open now
any idea what to do
May 28, 2009 | Safe International Digital Electronic Safe...
2004 holden rodeo, remote control key wont lock/unlock doors
try putting key in ignition turn to on position
then press lock & unlock several times slowly if door locks cycle up & down after 1st press it lost code and is now resynconised.
now try remote with all doors closed and key out of ignition
if this dont work need to register key(program)back into system which dealer must do with Tech2 if round heart shapped remote
Apr 09, 2009 | 2004 Isuzu Rodeo
Lock code
I have a Sanyo Katana II and have reset my lock code while enebriated and now I cannot remember the new lock code; I have gotten in with the ##3282# but need the other number
Oct 20, 2008 | Sanyo Katana SCP-6600 Cellular Phone
Locks & Locksmithing Logo
250 people viewed this question
Top Locks & Locksmithing Experts
ray gallant
Andrew Taylor
Andrew Taylor
Tom Chichester
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
