Computers & Internet Logo
Question about Medion Computers & Internet
My medion 4503 continually closes down - Medion Computers & Internet
Posted by Raymond Scott on
Www fixa com
Maybe you have a faulty fan? Try replacing the fan.
1helpful
2answers
My medion home computer was switched off but not logged off and is now not starting up. It starting up but is then closing down... Can you help me?
Try this if using windows vista or 7:
1)when you switch on the computer press F8 key on keyboard,
a menu should come up,
2) Select repair computer and press enter
3) Chose startup repair
My Medion MT6 desktop has developed a problem. When I power it up, the fans power up then shut down immediately. They then power up for a couple of seconds longer, then shut down. The process continues...
take it into a computer repair shop for a proper diagnosis
could be a faulty power supply or failing mother board
check that the power lead is properly connected top the pc
My cisco 4503 keeps losing it's configuration file.. any ideas why this is happening? thx.
The case gives me hints towards the configuration register value which is not set to proper value, so the switch is not checking the the saved configuration in the config file.
Please do the below steps.
1. Log into the switch
2. Come to enable prompt
3. Typein the below commands
config t
config-register 0x2142
end
write memory
The find an example of the prompt and the commands below
Switch# config t
Enter configuration commands, one per line. End with CNTRL/Z.
Switch(config)#config-register 0x2142
Switch(config)#end
Switch#write memory
After this you can configure your switch as per your requirement and then save the config by typing write memory
Now you can reboot your switch and the switch will come up with the configuration as you set.
Best Regards
Medion md1768 has been reformatted, recovered several times, but it continues to power down and restart at anytime. There doesn't seem to be any rhyme nor reason. I believed it to be infected so had the...
I think you need to shut off reboot on error
Here is some info on this
then it should show you the error screen instead of just rebooting
could be some hardware problem
1helpful
3answers
Can't turn on wireless
Hi there.
Hold down Fn and hit F1 or F2, with some medion models the wireless activation is next to the power button.
Good luck and thanks for using Fixya!!!
Medion laptop
was it shut down correctly?
Top Medion Computers & Internet Experts
 Mike M
Mike M
Marvin
Marvin
Are you a Medion Computer and Internet Expert? Answer questions, earn points and help others
