Dehumidifiers Logo
Question about LG Dehumidifiers
Deshumificador : LG mod. DHB1660 PL . Ficha tecnica por favor.
Posted by Jose Javier Gomez... on
Haier Mod HPE09XC6 in AC Mode is putting out water like it is a dehumidifier. model
the purpose of an ac unit is to remove water from the atmosphere so water will be collected and needs to be drained
In effect that removal of the water from the atmosphere is what makes you feel cool as you are allowing the skin to perspire more easily
Home has 57% humidity have one on the furnace do I also need a stan alone? my standalone is mod # 853203
An integrated de-humidifier is normally a cycling Air Conditioner. If the one on the furnace has a water line running to it, shut the water off and see what happens.
Delonghi dtc95e
http://www.4domex.co.uk/cgi-bin/search.pl?parts_search=s&brand=Delonghi&model=dtc95e&part=instruction+booklet Instruction book for oven costs pounds sterling. Incorrect listing under 'dehumidifiers'.
Replacement fan motor for ebac homedry 880 dehumidifier. fan motor Mod No aa2c6235
Hi, If you are in new Zealand and your 880 model is the NZ 870 model, the fan motor can be got at Carrier Air Conditioning, part # SP-W3035766, for around $105.00.
Noel
1helpful
My Maytag dehumidifier smells modly when running. What can I do?
Clean the filters. Also clean the coils and bucket with a mild bleach solution.
LG dehumidifier
I Have an LG Dehumidifier and water has leaked out to the basement floor, it has a hose that drains into the floor
2helpful
Dehumidifier -- LG LHD45EL
If everything is clean on the coils and the filter is clean it should work. I would contact LG because they have a 5 year warranty on these dehumidifiers. Make sure that you have your reciept. Usually what they will do is locate a shop near you and it can be serviced there. LG will pay the bill. Or if there is no local shop they will send you a service tag for your old unit and ship you a replacement unit. Contact LG and explain this problem to you. Everything should be covered under warranty still.
Good luck - Tech101
Top LG Dehumidifiers Experts
Gil Shultz
Jay Finke
Jay Finke
Are you a LG Dehumidifier Expert? Answer questions, earn points and help others
