Question about Ricoh Office Equipment & Supplies
Error code on ricoh mp c2500 error sc544 - Ricoh Aficio 2015 Copier
Posted by joseph muja lile on
OfficeServiceAjnc
  • Ricoh Expert
  • 215 Answers
This is a fusing unit error. sometimes is occur by not warm up on time, and sometimes is real problem and need some part in the fusing unit to be replaced. You can try to reset it in service mode and then if machine works its ok. But if it comes again, then a visit by technician is a must. To reset the sc561 you will need to do the following procedure. First of all you need to enter into service mode. To enter into service mode you need to press the following keys on order with no rush. Press the yellow key(clear); then press the blue keypad numbers: ( 1-0-7 ) ; then press and hold for 5 seconds the red key (stop). The touch screen will change into service mode. On the touch screen press [copy sp] ; then on the blue number key pad press the following numbers: ( 5-8-1-0 ) then press the blue key { # }. On the touch screen in the right side will appear a [EXECUTE] press on it and wait to write on the screen [COMPLETED] . After it write [COMPLETED] turn off the machine by the red switch located on the middle-front of the machine left side from the first paper tray. Turn it off and wait for 10 seconds and then turn it on again. Wait for it to get ready. If it get to ready mode, everything is its okey. But if the SC561 code appear again or some similar SC code appear like SC541-542-544 etc. then a visit from a technician must me made to replace some parts in the fusing unit that are wasted.
Posted on Jun 26, 2018
5 Related Answers
Anonymous
  • 14 Answers
SOURCE: Error code SC305 for copier ricoh aficio 1224c
This SC code relates to the charge corona cleaner not working or not working properly. the charge corona is located towards the bottom left of the machine after opening the front cover. It will have a screw you can undo by hand and a cable with an end like a telephone cable plug. toner may have fallen in to the unit or the motor that drives the cleaner along the wires has decided to jam up. remove the charge corona and blow it out with compressed air. You can also remove the end of the unit and check that the motor is not gummed up. Be very careful you do not break the hair thin corona wires! Hope this helps.
Dave T
Posted on Jun 22, 2008
Bubbabear64
Tim Babcock
  • 2794 Answers
SOURCE: RICOH 2015 error code sc 500
Main motor/ transport motor lock/ fusting motor error.
The only thing you can do is check for any obstructions in the machine.
That needs to be looked at by a service because the problem could be a motor, a pcb, or a power supply.
It can be a lot of troubleshooting to do.
Posted on Oct 19, 2008
Anonymous
SOURCE: Ricoh aficio 1232c error code sc 543
This is a fuser problem,possibly a dirty thermistor, but try resetting it first.....
Press yellow key
key in 1,0,7
then press and KEEP HELD DOWN the orange key until the screen alters into service mode. (about 5 seconds)
Then switch off the copier with the main orange on/off switch. Located just below the front cover....
Posted on Jan 22, 2009
Anonymous
SOURCE: ricoh aficio 2022 error code sc542
1. Mode(Yellow Button)
2. 107
3. Press STOP Button for 3 second (RED Button)
4. Copy Sp
5. 5810#
6. Excute
7. Power Off
8. Power On
Posted on Feb 24, 2009
Anonymous
  • 162 Answers
SOURCE: Error SC320 Ricoh Copier
Change the polygonal motor of the laser.
Posted on Dec 07, 2009
I have a Ricoh MP C2500 and it shows SC202 error How do I fix this
Replace your polygon mirror motor or complete laser unit if you have one available. Replace this a.s.a.p as it can cause your BICU to pop. If your machine is already dead and you picked the code up on the web browser you need to replace the BICU as well. Do not replace the BICU without replacing the polygon motor. If you do you will pop the BICU again.
Ricoh mp 1600 error 194 ricoh mp 1600 error code 194 how do I solve the problem
Having problems finding your error code. Here is a complete list of all codes for your printer: http://www.printcopy.info/?l=en&mod=free&chap=erc&brand=Ricoh&model=Aficio%20MP1600
I do find the error code for a different Ricoh model (Aficio 1018).
http://printcopy.info/?l=en&mod=free&chap=erc&brand=Ricoh&model=Aficio%201018
Please verify your model number and error code.
What is sc 532 on aficio mp c2500 and what if the machine shows your that your fuser settings error
"Fusing duplex motor locked" check the fusing duplex gear box or clean if not so you can change duplex motor.
1helpful
2answers
How to clear error code sc 541 on ricoh aficio 2015
i want to make my nashuatec mp 500 copier to be dip in printig
1helpful
2answers
Have an aficio 1018 copier with an error code SC544 any ideas ?
that's a fuser unit error do an Sc reset and restart the machine if not replace the fuser unit
What dose this code meen sc544 on a ricoh copper
your heating unit (fuser) is overheating, call for service to to check heat sensor (thermister) and reset the code
Ricoh Aficio 2015
Pressure roller warm up error. Usually means that the fuser roller isn't at the right temperature when you turn the copier on.
Try turning the copier completely off. Wait 30 seconds. Turn it back on again and see if it goes away.
If not a technician should look at the fuser section to see what the problem is.
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
Bernard D'Souza
Timothy Van Der...
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
