Question about Mercury Boating
Mercury 50 hp outboard motor fuel filter location
Posted by Keith Gjesvold on
5 Related Answers
bunnydawg
Roberta Smith
  • 5158 Answers
SOURCE: mercury 50 hp outboard
I actually thought it was down by the prop... i was wrong....
Pretty good diagram here.... look at part number 1
http://www.sterndrive.info/mercury-outboard-parts/60hp_to_125hp_component_layout.html
scroll down for the part cost and description.
Robert
Please take a moment to rate this solution.. thanks
Posted on Jan 23, 2009
Anonymous
  • 207 Answers
SOURCE: 1999 Mercury Mariner 9.9hp outboard motor
should be on the side with a lever but could you give me more info please
Posted on Jun 27, 2009
Mark Chapman
SOURCE: Free wiring diagram for 1978 Mercury Outboard 115 HP boat motor
I have a maintainance manual for this engine (I have the same one) with pages of wiring diagrams. What specific system/area are you interested in, I could scan in the page(s) and email them to you.
Mark
Posted on Sep 20, 2009
Donald B Stoll
  • 597 Answers
SOURCE: How do I winterize my Mercury outboard 115 HP
Just need to lower the motor all the way down. This will drain all the water out of the motor. That should do it. They recommend changing the motor oil at the end of the year or the start of the next boating season. You should also add some Sta-Bil or Pri-G gasoline additive. Think it's available at Wal-Marts or part stores. Probably a good idea to keep the fuel tank full to prevent air inside tank from condensing and forming water. Add a couple of cans of HEAT to fuel to help keep water out.
Posted on Nov 05, 2009
Anonymous
SOURCE: I have a 1990 90 HP mercury outboard. It is rough idling and surg
I have a 90 hp force ob. when i run it with the ears she runs fine lets me bring the throttle all the way up. when i but it in the water thru the wake area i can do 4 mph once i'am out of the wake area and give it the gas she dies, any ideas
Posted on May 20, 2010
Where might I find a working fuel pump for a 1966 Mercury 3.9 hp outboard motor?
there is a pump for sale on e-bay --seller is western furniture (1918) used condition for $25.00 us 2 people watching it but it has a buy now tab
I found this by going google and typing in --fuel pump for mercury outboard motor 3.9 hp-- and the site is www.ebay.tv>sch>ebay-motors-
mariner is also a part of the mercury range so check for mariner 3.9 or 4 hp parts
Sep 11, 2016 | Boating
I have a 1978 merc 85 hp outboard with a bad pump i purchased a used one that works mine has 4 hoses
Mercury Outboard Fuel Pump - Mercury Outboard Forums
forums.iboats.com/Mercury-Outboards/Fuel-Pump
5, 2004 Mercury 225 four-stroke EFI no power to Low Pressure fuel pump. Why please help · Mercury & Mariner Outboards. 13, Mercury 850 (85hp) - Gas pumps through the top carb - Failed fuel pump? ... 1, 1969 7.5 H.P. Mercury (Bad fuel Pump)? ... 1971 · 1972 · 1973 · 1974 · 1975 · 1976 · 1977 · 1978 · 1979 · 1980 · 1981 ...
Fuel Pump Diaphragm replacement Mercury outboard 110 ...
? 4:18
https://www.youtube.com/watch?v=vufekxTVZd8
Jun 22, 2012 - Uploaded by Brad Clark
My last test run of this motor lead me to believe I had fuel pumpissues...so in ... Mercury 9.8 h.p. 110 Outboard Motor WaterPump Repair and ...
How to remove the lower unit on a Mercury outboard motor ...
Dec 01, 2015 | Boating
Why wont my 50 hp mariner start ?
renew spark plugs,mix up some fresh fuel,put choke on,throttle set at just above idle,pump up fuel bulb by hand till tight,put outboard in a water drum,try pulling or turning on starter till it fires,then push choke in and restart
Jul 25, 2014 | Mercury Gear Set, Complete, Mariner, Force...
Fuel ratio for 1968 mercury 9.8 outboard
The fuel ratio is 50/1. Eg.50 gallons of fuel to 1 gallon of oil.
On an older motor and newer cleaner burning oils,you may bring that down to 45/1.Hope this helps
May 28, 2010 | Boating
Fuel oil mixture for 1986 mercury 115
I own a small Mercury outboard so I did alittle reading in the manual and the ratio for your 86' 115 HP is 50-1. Hope it helps. Coach Theune
Oct 25, 2009 | Boating
Boating Logo
1,490 people viewed this question
Top Mercury Boating Experts
Colin Stickland
Colin Stickland
Mike
ray gallant
Are you a Mercury Boating Expert? Answer questions, earn points and help others
