Question about Kenmore Dryers
My Kenmore washer/dryer Mod# 2661532210 dryer keeps stopping. Will restart when I push the button. Any idea why?
Posted by Annette Slenski on
5 Related Answers
Anonymous
  • 290 Answers
SOURCE: GE dryer starts but..... stops
What you describe is either a failed evenheat board or a failed motor relay.
Please post the complete model number from the machine and I can help you narrow it down. There should be a wiring diagram inside the console with voltage checks also.
Thanks/Mike
Posted on Nov 25, 2007
reg501
Richard
  • 413 Answers
SOURCE: Kenmore dryer mod. no.110.64972301
Before replacing the motor, check under the console for a motor relay. If a motor relay is present replace it. On some models the relay is part of the start switch. The relay will be a black,square device with 3 to 4 wires on it. There may also be a relay for the heater. If so, replace it too as it may be ready to fail soon.
Posted on May 29, 2008
Anonymous
SOURCE: Kenmore Dryer
I had this same problem a couple of years ago. I replaced the circuit board located in the top part of the dryer and it has been fine since. The part cost $95 over the internet.
Posted on Jan 12, 2009
James Chandler
  • 686 Answers
SOURCE: Kenmore gas dryer doesn't stay running have to hold button down.
POST MODEL NUMBER, BUT IT MAY BE THE MOTOR START SWITCH.
Posted on Apr 18, 2009
Anonymous
SOURCE: Kenmore dryer start button not working
when I push the start button on my kenmore dryer it will not start and the drum will not turn.
Posted on Dec 21, 2009
How to reset a Kenmore model 2661532210 washing machine
try this.if it does not work then go to this link and see if it helps you out...... Programmable Washing Machine Certain programmable washers have a reset function. This function clears an unintentional "Delay Start" command and resets controls in the case of a program error when the machine won't start. The method of resetting varies by make and model. In certain models, turn the knob to reset with the power button "Off." Select the desired program. Press the power button to restart the washer. In other cases, if the machine has a "Cancel" button, push it to clear the error and then push the "Pause" or "Stop" button to reset it. Consult the handbook for the washing machine for the correct procedure that applies to your model. You can often find washing machine handbooks or troubleshooting instructions on the manufacturer's website............
Reset Buttons for Washing Machines
Dec 08, 2016 | Kenmore Washing Machines
Manual for Kenmore stackable washer & dryer 2661532210
Hello, this is Ava with Think Crucial.
You may find the User's Manual for your Kenmore model by clicking the link below.
https://www.searspartsdirect.com/partsdirect/user-manuals/2661532210-kenmore-parts-manual
You can purchase a wide variety of high quality appliances replacement parts direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/collections/appliances
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Sep 15, 2013 | Kenmore 98702 Stacked Washer/Dryer
Kenmore mod 110 87870110 gas dryer- at first push
the vent could be plugged and unit is going into thermal overheat if it works in timed dry properly then the moistier sensor is faulty.
Dec 01, 2009 | Kenmore Dryers
Kenmore Evenheat MOD# 110 62056100
okay, kenmore elite have had these problems so often, you need to replaced the touchpad, not the board, jjust the touchpad, it cost around $150.00.
Sep 10, 2009 | Kenmore Dryers
Kenmore dryer keeps on going and going
The timer is bad. It is located behind the knobs and can be replaced really easily. The price for a new timer is about 35 dollars. If this helped please rate
Feb 12, 2009 | Kenmore 64902 Electric Dryer
Kenmore Dryer stop running when release the start button
I have whirlpool dryer, when i push the start button it will start but only stay on for part of the drying time. no the start button make noise when push and after keep trying it stop.
Dec 30, 2008 | Whirlpool LEQ9858P Electric Dryer
Nov 09, 2008 | Dryers
Kenmore 90 plus series dryer won't work
Sounds like the belt has broken. You could probably also use new drum support rollers. Check out this site which shows how to change a dryer belt:
http://repair2000.com/wpoolbelt.htm
It's not a difficult job if you're comfortable working with hand tools.
Oct 17, 2008 | Kenmore 62872 Electric Dryer
Kenmore series 70 mod#110.62722100
check the door switch first if it is ok ..(doors not popping open) then the PTS (push to Start) switch is most likely bad as it wont hold in after it was pressed
Jan 25, 2008 | Dryers
Kenmore dyer
sounds like the timer, unless it has a Evenheat contol board and a seperate motor relay, in which case its most likely the relay, or could be the computer
Sep 29, 2007 | Kenmore 64892 Electric Dryer
Dryers Logo
179 people viewed this question
Top Kenmore Dryers Experts
Marvin
Marvin
Michael Thomas
Michael Thomas
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
