Question about Kenwood Food Processors
How do I take apart my kenwood mini chopper to wash the bowl and the grinder?
Posted by Hilary Tucker on
Need bowl lid for toastmaster 1 1/2 cup mini food chopper model TM-61MC
fixya doesnt sell products try manufacturer or online search
Jul 17, 2018 | Toastmaster Food Processors
My 4 cup (cuisinart)chopper grinder's motor, which grinds is burnt while the chopper motor is in good condition.Can I get the motor? How much will it cost?Is there a shop in Mumbai India where I can g
Some times it is best to get the motor rewound from a reliable rewoinding shops that are found in most places. This can work out much cheaper as ordering the motor might cost you twice the money you spend on the full unit.Also confirm if this can be brush failure , take opinion and estimate.
Rewindings shops are seen everywhere in India but choose a reputed one who can do the winding for 230 volt mains voltage with accuracy.
Nov 21, 2011 | Food Processors
I need a replacement bowl for the HandyChopper Plus (HC3000).
Replacement parts for your Black & Decker HC3000 Handy Chopper 1.5 Cups Food Processor can be order online here:
http://www.directpartsandproducts.com/choppers-hc3000-c-1_156_408.html
Aug 02, 2011 | Black & Decker HC3000 Handy Chopper Food...
I Cuisanart mini prep and removed the bowl, lid,
Make sure the tab on the lid is making contact with the "tower" in the back and that the work bowl is locked properly into place so that the plastic tabs show on each side toward the bottom of the work bowl.
Aug 12, 2009 | Cuisinart DLC-2 Mini Prep Plus Food...
On the KitchenAid 3 cup Chef's Chopper, How do you lock the blade so I can turn on the chopper?
The Kitchenaid food choppers have a few safety features implimented. If the unit is not assembled properly, this may prevent the unit from turning on. Proper assembly is below:
If it isn't all ready, please disassemble the entire unit. This means removing work bowl, work bowl lid, and blade.
Start by placing the work bowl onto the motor base. The work bowl handle should be facing at 9 o'clock, which is out to your left. Rotate the handle downward until it locks in at the 6 o'clock position, which will lock over the center of the button panel.
Repeat the process with the work bowl lid. The blade does not need to be present for the motor to engage, if this is an assembly issue.
Dec 29, 2008 | KitchenAid KFC3100 Chef's Chopper Food...
Blade will not release
Our blade just came apart at the seam just above the blade, so we know what's inside. There is a small v-shaped piece of spring wire that is spread apart from the stem that is mounted to the machine. When the button is depressed (it's on a tiny spring, like a mattress spring, and that's what makes it bouncy), it spreads the v-spring wire and releases it. If you can get the seam apart, it will release the v wire and not damage the machine. Replacement blades are available on-line for $13.95, and whole machines are available on e-bay. Good luck.
Nov 16, 2007 | Ultimate Chopper Food Processor
Food Processors Logo
350 people viewed this question
Top Kenwood Food Processors Experts
ThaMp3Doctor
ThaMp3Doctor
Ross Keen
Are you a Kenwood Food Processor Expert? Answer questions, earn points and help others
