Question about Kwikset Locks & Locksmithing
Kwikset door knobs - Kwikset Locks & Locksmithing
Posted by bob walker on
5 Related Answers
Steve Archer
  • 148 Answers
SOURCE: changing doors would like to know how to take off kwikset door
remove the two screws on each side of the door knob from the inside of the door use medium size phillips head screw driver
pull the door handle off
remove the handle from exterior door side
remove two phillips screws from the side door that hold the door bolt pull the door bolt assembly out
reinstall on new door
insert bolt assembly
insert knob for exterior side(a lign it up
insert knob from interior side and align screws and tighten ligtly
check door for easy turning of knob and actuating latch
good luck
remove that assembly
take screw driver and remove the two scres that remove the plate on the side of the door and
Posted on Jan 06, 2009
agent91
Ned White
  • 2100 Answers
SOURCE: How to install kwikset door knob with lock
Are the holes in the door? Are you replacing the old lock? Need to know these things, or I will be typing a bunch of stuff you don't need. Most doors come pre-bored. If not, you need 2 bits, One is 2 1/8 inch cup bit, the forstner type is a lot more expensive, and a 1 inch paddle bit, again, the forstner bit is expensive. Measure up the door app 39 inches, unless there is a lock rail on/in the door, then measure to the center of that. Then on the inside of the door, measure back 2 3/8, most locksets now are adj for 2 3/8 or 2 3/4, you can use either one. You can drill either hole first, To drill your one inch hole in the edge of the door sighting along both sides of the door with your eyes crossed so you can make sure you are going straight, you don't want to bust through the side of the door. Then get the big bit out and drill from the mark till you just come through the other side, then back it out and drill from the other side so you don't tear out the hole. Your 1 inch hole should be all the way into the big hole.Then get you chisels, the sharp ones, put the plunger in the one inch hole, nice and straight, then mark the outside with a sharp pencil, cut the line with the chisel then cut out the waste about 1/8 to 3/16 deep, make sure it fits nice and tight, Predrill the two screw holes, or you will split the door.Get the lockset out, the key to the outside, and the button on the inside of what you are locking. Line up the holes, you might have to spin the button to get them to line up, then put in the 2 long screws. Mark the jamb with the striker, To get it right, put the striker on the door, hooked into the latch, mark the edge of the door with a pencil,then put the striker on the jamb, backwards, to the line you just marked, then out line it, use your 1 inch bit to hog out the middle nice and neat, cut the rest out the same way with the chisels, predrill the holes, you should be all set. OH the deadbolt? You didn't mention that, it goes the same way as the lockset, only the hole is smaller, 1 1/2, I think, you will have to check that. Now you know why people call carpenters.
Posted on Feb 17, 2010
dcramer531
Dcramer531
  • 1654 Answers
SOURCE: My exterior door lock (Kwikset)
Get a big scredriver and put it in the square in the middle of the mechanism and turn it till it opens, or you will just have to pry it out with the scredriver.
Posted on Apr 05, 2011
Adam
  • 207 Answers
SOURCE: The inside door knob came off of the Kwikset keyed
There is probably a small set screw (hex head) on the bottom of the knob. If that doesn't work try just pushing it back on.
Posted on Jun 06, 2011
vr24cod
  • 107 Answers
SOURCE: how do you retract a kwikset lever signature series exterior door tounge manually, lever moves up/down but tounge doesnt move out off latch
Check out the manufacturer info. How To Center Tips Advice DIY Repair Troubleshooting
Posted on May 25, 2014
Kwikset lockset does not lock
The shaft for the lock fits in the knob. The lock on the knob might be 90 or 180 degrees out of rotation. Please remove the know and twist the lock 1/4 turn and put it back together. Also you may need to reset the location with a key and when the lock knob is off, turn the lock set with the key, then turn it and replace the knob.
Mar 01, 2018 | Kwikset Locks & Locksmithing
Exterior door stuck closed manually retract ****** remove knobs KWIKSET
You will probably need to replace the latch assembly. There is a small rivet that holds part of the latch together, and it also acts as a pivot point for a small piece that retracts the latch. If it gets bent, the latch won't retract fully, but you might be able to push it back and get the door open.
May 24, 2014 | Kwikset 740ll 3 Smt Lido Keyed Entry Lever...
Door knob replacement
On the inside side of the door knob you should be able to use a screwdriver to remove the finish covering against the door. This should get you to a point where you can release everything.
Nov 14, 2013 | Kwikset Locks & Locksmithing
Re-assemble a kwikset front door lever and knob type latch
Since the exterior side of the lock only has a keypad and no lever, I'm not sure what you mean by the "outside lever". Here is a clear, easy to follow video of the installation. Please carefully review each aspect of your installation against it to see if you can spot an installation mistake:
http://www.kwikset.com/Videos/Vitro/smartcode.aspx
Sep 03, 2012 | Kwikset 909 909-L03 Lifetime Polished...
My exterior door lock (Kwikset) is stuck shut. The knob will not turn. I removed the knobs and tried to pull the mechanism back - but unable to. The door is therefore stuck shut.
Apr 05, 2011 | Kwikset Locks & Locksmithing
The inside door knob came off of the Kwikset keyed door lock. How do I re-attach the knob?
Feb 24, 2011 | Hardware & Accessories
I am replacing my door knob and replacing it with similar lock door knob by Kwikset. I measured from the end of the door to the middle of the hole where the knob goes into which is 2 3/8". The problem...
Most kwikset locksets will work on either 2 3/8 or 2 3/4 inch setback. There should be two holes on the latch where door knobs fit thru the door. If yours does not have this option I would suggest that you get one that will match your setback.Hope this helps.Thanks.
Nov 16, 2010 | Garden
Door knob will not stay set. Keeps slipping out.
i would say the only fix for it is a replacement.sounds like its wore out, sorry
Jul 11, 2009 | Kwikset Sheridan Handle Set
Changing doors would like to know how to take off kwikset door
good luck
Dec 29, 2008 | Kwikset Professional Door Lock...
Locks & Locksmithing Logo
294 people viewed this question
Top Kwikset Locks & Locksmithing Experts
Marvin
Marvin
john h
Are you a Kwikset Lock and Locksmithing Expert? Answer questions, earn points and help others
