SOURCE: No video throught HDMI output
press set up go option number 1 then go hdmi monitor and input yes. then press set up again
SOURCE: No HDMI Output
My configuration:
ZONE 1 (living room)
DishNetwork Dual Tuner DVR Tuner 1 [S-Video out] -> [S-Video in] ONKYO TX-SR875 [HDMI out] -> [HDMI in] Sony KDS-60A3000 rear projection TV
ZONE 2 (living room)
DishNetwork Dual Tuner DVR Tuner 2 [Composite Video out] -> [Composite Video in] ONKYO TX-SR875 [Composite Video out] -> [Composite Video in] Samsung AQUOS LCD TV
Problem:
ONKYO receiver stops sending video signal to my ZONE 1 Sony TV through the HDMI connection. ZONE 2 may still receive video. (NOTE: the issue might be related to the upconverter circuitry?)
Symptom:
I couldn't see any video, but I could hear the Tuner 1 audio through my ONKYO. An important clue is that I couldn't see ONKYO's on-screen display menu on my TV when hitting the [Setup] button on my remote. But, I could see my TV's Sony-based menus and display options.
Solution:
1. Put all ZONES in Standby mode using the remote. Hit these buttons on remote: [Receiver], then [Standby]. [Receiver], [ZONE2], then [Standby], [Receiver], [ZONE3], then [Standby]. You should NOT see any lights on the ONKYO except maybe one red led near the power button.
2. Pull the power plug out of the back of the ONKYO, and leave unplugged for 20-30 seconds. Turning off any power center it is connected to isn't enough. You MUST unplug the power from the back of the ONKYO for 20-30 seconds.
3. Reconnect the power cord to the ONKYO.
4. Using the remote, set ZONE1 to a video source known to be working. If you don't see video, try leaving the power cord off for a longer period.
I know it sounds too simple to work, but that's what brought the video back for me the few times the video stopped displaying. Hope it works for you.
SOURCE: HDMI cable between TV and Lifestyle 28
Did you set up your bravia TV to receive pictures throuh HDMI ?
SOURCE: right cables for connecting devices
You have connected from PC to TV right???
1.To get the video you have to connect to TV
2.Please take a separate cables for to listen audio and to watch video,
for audio connect cables from DVD Player to Home Theater you can listen the audio
for video please connect the HDMI video to TV Where You can enjoy both.
SOURCE: Apple TV and Bose Home Theater
I had the same problem.
I could not get HDMI to HDMI to work.
i fixed it (work around), by connecting ATV HDMI to DVD HDMI port on V30, i then connect L&R to AUX. I set the Bose remote for controlling ATV to AUX.
so to use ATV with Bose remote i know press DVD, this gives me the correct display but not audio, i then press AUX and this gives me ATV control and audio.
interesting, when i first set this up (trial and error), it didn't work. I was doing some cable management clean up, when i got a fright and the thing started working...but i have a ghost in my house so that is probably a more plausible reason why its working now.
it feels like this product is only 90% finished
