Question about Measuring Tools & Sensors
My Smart Gear STG-5939-KB, Weather Station does not indicate the correct day. Instructions say it will adjust to the date. The date is 5/4 but the dat says TUE. Any ideas?
Posted by John Loy on
Tom Chichester
    Top Expert:
  • Measuring To... Master
  • 55,703 Answers
Your Smart Gear Weather Station may be defective. I have an atomic lock that indicate DST all year round but changes time correctly. One other thought: your weather station may be set for the wrong year.
Posted on May 04, 2018
3 Related Answers
escapement
Arturs Kalnins
  • 2338 Answers
SOURCE: SETTING (DIGITAL) DAY/DATE ON THE FOSSIL JR9387
Follow this link and download proper instructions:
http://www.fossil.com/webapp/wcs/stores/servlet/StaticView?langId=-1&storeId=12052&catalogId=10052&page=Instructions&nav=custCareNav
Rate me, please.
Posted on Mar 24, 2009
lpfaff1
L Pfaff
  • 11573 Answers
SOURCE: Smart Gear Weather Station. How can I adjust time?
George, RE POST make model # and your complete question, so we at Fixya can answer your question effectively.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Posted on Mar 20, 2016
Tom Chichester
  • 55703 Answers
SOURCE: My Smart Gear STG-6007-BB weather station won't pick up the outdoor temperature from the remote sensor. I changed the batteries and reset the unit, but it still doesn't work. Any suggestions?
  • Remove all batteries
  • Install batteries in remote sensor. Allow time for it to begin sending temperature information
  • Install batteries in indoor unit. You should see temperature displayed
Cold weather can cause loss of temperature information
Posted on Dec 17, 2016
How do I set the clock to 12 hr not 24 hour time on the Smart Gear 6083 indoor outdoor thermometer? I lost the directions. Thank you so much! It's driving me nuts!
Scroll through the menu to find 12/24 format, press and release the +/- button, then the c*\f* button will change the value and then hit the set button.
Jan 13, 2018 | Smart Computers & Internet
Outdoor sensor won't connect and read on monitor, model stg-5939-kb.
Check with ohm eternal the sensor may be is defective
Dec 30, 2016 | Heating & Cooling
Dec 17, 2016 | Measuring Tools & Sensors
Mar 20, 2016 | Measuring Tools & Sensors
Incorrect Date
open shortcut on pc..it will show correct date, time, etc tho unit does not as it hasn't changed days..on the shortcut, click on Update settings then Send to receiver..then punch in button on back of Station..says "pc search"..transmitter on unit will start steady flashing..unit will go black..gradually everything comes back..don't touch until all back..everything will now match the stuff on the shortcut and the day and date will have changed to the correct one..I do this process every day.
Jun 01, 2012 | Sharper Image 5 Day Internet Weather...
Setting the time zone
I actually have the same problem with an older model Brookstone weather station with remote temperature gauge. The time/date settings do not allow you to set time zone and eventually the clock syncs to PST.... ANY HELP HERE?
Mar 19, 2009 | First Alert FWS-101 Wireless RF Weather...
Wrong date on the radio.
RESETTING THE CLOCK AFTER A TOTAL MEMORY LOSS
If you do not change the built in lithium battery within a reasonable period of time after you see the ‘flashing’ LOW BATT. warning indicator, the lithium battery may become exhausted and will no longer be able to supply back up power to the SmartSet internal computer.
If the unit is disconnected from the AC outlet after the battery is exhausted, or if a power interruption occurs, the SmartSet memory will be lost and the clock will need to be reset when the power is restored. Be sure to install a fresh lithium battery before you reset the clock, otherwise the clock will need to be reset each time the power is interrupted.
If the lithium battery is exhausted and you experience an interruption in the AC power supply, the clock will reset itself to its initial default setting when the power is restored.
The initial default setting is “12:00 AM, Saturday, January 1
(1 1), 2005”.
If you notice that the time on your SmartSet clock radio is completely incorrect, and the day indicator is also wrong, press the MONTH/DATE button to see the date. If the date display is showing “1 1” (January 1 ), you probably experienced
a total memory loss. To reset the clock after a total memory loss, proceed as follows:
1.) Install a new CR2430 lithium battery in the battery compartment.
2.) Connect the radio to your AC outlet and let the clock set itself.
3.) Depress the MONTH/DATE and TIME buttons together. The display will change from ‘time’ to ‘year’. While holding the MONTH/DATE and TIME buttons, press the UP button to
set the display to the correct year, then release the buttons.
4.) Depress the MONTH/DATE button. The display will change from ‘time’ to 'month/date’ (mm/dd). While holding the MONTH/DATE button, press the UP button to set the display
to the correct month and date. The Day indicator will change automatically as you adjust the month/date settings. When the correct month and date appear on the display, release the buttons.
5.) Depress the TIME button and the UP button to set the display to the correct time. Be sure to confirm that you have set the time correctly to ‘AM’ or ‘PM’ by observing the AM indicator.
6.) After you set the time, reconfirm that the Day, and Month/Date displays are still correct. Make final adjustments if necessary.
The SmartSet clock memory is now reset and the new lithium battery will maintain it for the next 5 to 8 years, depending on the number and duration of the power outages you experience.
IMPORTANT NOTE:
After resetting the clock, don’t forget to reset your wake up times, and alarm mode settings, and sleep timer settings as well.
Oct 22, 2007 | Emerson SmartSet CKS1850 Clock Radio
Measuring Tools & Sensors Logo
1,201 people viewed this question
Top Measuring Tools & Sensors Experts
Marvin
Marvin
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
