Question about Kwikset Locks & Locksmithing
Would like to remove kwikset door handle in order to repaint door. no screws involved,
Posted by bob walker on
5 Related Answers
Anonymous
  • 104 Answers
SOURCE: I can't remove the door handle.
thanks
Posted on Feb 14, 2008
Anonymous
  • 3 Answers
SOURCE: hyundai accent '02 inside door handle & Lock removal
Removing the door is very tricky, trust me on this. I ended up breaking it the first time, so please learn from my mistake.
1. Remove all visible screws: 2 at bottom of door, 3 on front near hinge, 1 on inside the door lever. You will need an average size phillips screwdriver to do this.
2. On the door handle itself, you will see two circles. Pop the front one out. You will need a LARGE size phillips screwdriver to do this.
3. Once screws are removed, take a (standard) flat-head screwdriver, preferable one with a large face, and pry the triangular piece of plastic (that covers the outside SIDE mirror) off. This will aide in puting the door panel back on...TRUST ME!!!
4. Take the same flat-head screwdriver, and pry behind the door lock (at the same time, push forward toward the door hinge). The assembly should pop out.
5. Gently pry the door panel from the door, making sure not to break any unnecessary pieces along the way. The door panel should be hanging by the window sill opening.
6. This is where it will get tricky. It is advised that you use help with this part: Angle the door panel at a 45 degree angle. AT THE SAME TIME, slightly bend and twist the door lock handle until it fits through the hole. You will see the 3 pegs the held it in the door from before. Also note: Be careful not to break the 2 poles that are attached to the lock.
7. After popping the lock through the hole, you should be able to lift the door upward, and off the sill. Repeat these steps in reverse order to re-attach door panel.
Be careful not to rip sound-deadening paper found on inside of door unless you intend to remove or replace it! Not only does it prevent dirt and moisture from entering your door (and possible rusting it from the inside out), but it makes your speakers sound better too!
-SportTunerFreak
**It is also recommended to put a tiny bead of silicone on the inside of the door panel to help suppress any rattling, and prevent moisture and dust from entering. It also helps your screws obtain a tighter fit. Hope this helps!
Posted on Mar 24, 2009
Anonymous
SOURCE: The handle on the door of my bottom freezer Amana
Push the handle in and slide it to the side. It should come off and you can tighten the screws and re-attach the same way. I just about destroyed my door before i figured this out.
Posted on Aug 14, 2009
Joseph Howard
  • 753 Answers
SOURCE: Removing the door panel from a 97 Chevy S-10 pu truck
The center section does come out it has little tabs front and rear you have to bend it very carfully.GOOD LUCK
Posted on Sep 16, 2009
Testimonial: "Guru thanks, that worked. Panel off but can't access the back side of the exterior door handle to replace the screws that hold it on? Any ideas? "
milten1
milten1
  • 1304 Answers
SOURCE: Problem: How can I replace the door handle on a
ok start over
you need to be looking at the inside of the door
the frame around the glass the choke
will pop off,,
take a small flat head place it between the choke and the frame down by the hinge. pry ever so carefully it will pop out slide the screwdriver around the edge until the whole choke is dislodged
once the choke is off
you will see the two screws for the handle
you may need to lift the latch mechinism to get to the bottom one
once your done you can simply push the choke back it place you will here it snap
be careful the choke is very brittle
and will break if bent
Posted on Oct 10, 2009
How do i attach the door lever?
http://s7d5.scene7.com/is/content/BDHHI/24910-04
Kwikset lever handles are held on with hex set screws. A wrench is included in the package. It's either a 3/32" or 2.5 mm. Note that the lock must be unlocked to remove or install the outside handle.
Sep 06, 2014 | Kwikset Brooklane Venetian Bronze Entry...
Have a kwikset bathroom door handle. Want to put on a new one. I took screws off but handle won't come off. How do I release the handles?
Wiggle the backset a few times while pulling on one side or the other. Certain brans have a catch and will opnly release when this is done.
Feb 02, 2011 | Kwikset Locks & Locksmithing
Can't remove the disk that covers the screws to tighten door handle with lock
Hi, W/D here.
Kwikset has basically two styles of cover plates.
If you are on the locking side of the door and facing the knob you'll either see two screw heads (one on either side of the knob), or you see only the cover plate.
It sounds like you have the cover plate type. Here's how to get to the screws:
1. Feel the underside of the knob, and you'll feel a slot with a tab sticking through it.
2. With a fine bladed screwdriver, press the tab up into the slot, and pull the knob towards you.
3. With the door knob off, look around the edge of the trim ring for a screw driver slot. Insert the screw driver and gently pry the trim ring up.
4. You're there!
5. Re-assembly is in the reverse order. When you go to put the knob back on, you'll probably have to use the screw driver to push in the tab as you slide the knob back on.
Best regards, --W/D--
Jan 30, 2011 | Kwikset Professional Door Lock...
Replacing door handles and the "eschosions?" are not screwed on how do you remove
Installation instructions:
http://s7d5.scene7.com/is/content/BDHHI/kwikset-smartcode
A note about PDF files: If you cannot view a given file, you need to first install Adobe Reader. You can get the free download here:
http://get.adobe.com/reader/
Kwikset has a one year warranty protecting the electronics and covers mechanical function and finish for the lifetime of the lock.
This link includes the info and contact information:
http://www.kwikset.com/Customer-Support/Warranty-Information.aspx
Oct 07, 2010 | Kwikset 909 909-L03 Lifetime Polished...
How do i remove exterior handle kwikset titan?
You need to insert the key and turn it clockwise, then insert a stiff metal tool like a straightened out heavy paper clip into the hole on the shaft of the lock by the circular flange next to the door. Push it in until you feel it give and pull out on the handle at the same time. If you need more help please contact me.
Best of Luck,
RSMITH972278
Nov 13, 2009 | Kwikset Professional Door Lock...
Change batteries on kwikset pushbotton lock.
If it's the lock I think it is, all you need to do is to remove the two screws on the inside of the door that holds the lock to the door. Pull straight out on the whole assembly. You should see the exposed battery once you have removed the outer case and handle.
Hope This Helps,
RSMITH972278
Nov 10, 2009 | Kwikset Professional Door Lock...
Problems changing a doorknob
If there are no visable screws on the inside of the door than there is a cover plate that can be removed by prying it off with a small screwdriver revealing the screws. Please remember to rate my answer
Jun 30, 2009 | Kwikset Professional Door Lock...
Cannot remove disk that covers screws to tighten my lock
The screws are located on the non locking side of the handle. To get the cover off most pop off by placing a small screwdriver behind the edge and gently prying. Paint/varnish will make this harder so you my have to take a razor and cut around it.
Please rate.
Jun 03, 2009 | Kwikset Professional Door Lock...
Changing doors would like to know how to take off kwikset door
remove the two screws on each side of the door knob from the inside of the door use medium size phillips head screw driver
pull the door handle off
remove the handle from exterior door side
remove two phillips screws from the side door that hold the door bolt pull the door bolt assembly out
reinstall on new door
insert bolt assembly
insert knob for exterior side(a lign it up
insert knob from interior side and align screws and tighten ligtly
check door for easy turning of knob and actuating latch
good luck
remove that assembly
take screw driver and remove the two scres that remove the plate on the side of the door and
Dec 29, 2008 | Kwikset Professional Door Lock...
Locks & Locksmithing Logo
316 people viewed this question
Top Kwikset Locks & Locksmithing Experts
Charles Tidwell
ray gallant
STEVE SPAM REMOVER
Are you a Kwikset Lock and Locksmithing Expert? Answer questions, earn points and help others
