SOURCE: Microwave runs, but not heating. Whirlpool Gold
There should also be a "mini-manual" hidden inside the unit behind the control
panel or hidden on the left side behind the grille, which is very
helpful when troubleshooting, & testing.
At
our Web site, we have a video available showing how to remove a typical
over the range control panel assembly in under 5 minutes.
You
can download Whirlpool owner's manuals and installation instructions (very handy when removing the oven form the wall for parts replacement) here.
You can find
helpful exploded view diagrams and order parts here.
We're
happy to help you with free advice and we'd appreciate your
thoughtful rating of our answer.
SOURCE: whirlpool gold microwave gt4175sps - problem: will
It sounds like there may be a diode or relay on the control that has failed. This could cause both symptoms you are explaining here. In either case the control board/keymembrane would need replaced. The cost of these would be about $173.00 for parts. Unfortunatly this repair would most likely cost more than the value of the product. Sorry for the bad news.
SOURCE: how to change bulb in whirlpool gold microwave
If your owner's manual does not address it, it's not meant to be user-accessed, so you will need to remove the outer cover to access and change the bulb.
If it's an over the range model, you may have to remove it from the wall.
You can find
helpful exploded view diagrams and order parts by entering your full
model number from the tag on the oven here.
We're
happy
to help you with free advice and we'd appreciate your thoughtful rating
of our answer.
possible a bad connection to the display
take it in for a proper diagnosis and quote
