Question about ATN Optics
I was putting the micro sd card in the ATN X-Sight 4K pro and somehow the sd card went all the way inside the scope.
Posted by Mario Sanchez on
Paul Woodward
    Sergeant:
  • 198 Answers
Yer its happened to me in button hole camera, cctvs etc it misses the metal guide so goes into casing and not card slot. need to open it to get it out
Posted on May 04, 2018
5 Related Answers
Anonymous
  • 15 Answers
SOURCE: problem with my atn 390 nv scope
Observe the IR illuminator with a digital camera and see if it if fluctuating in output brightness. If that is OK, the problem may be in the HV circuit. They are both easy to fix if the person has some experience.
Posted on Nov 29, 2008
SOURCE: can't get music from itunes onto micro sd card
Basically, when you buy music from online stores such as iTunes, RealRhapsody.... they are actually DRM protected content and you will not be able to play them on mp3 players which do not support their formats. In such case, the option is to Burn those tracks to a CD and then rip them once again to the HD wherein the DRM will be removed and you will get the tracks in (DRM free) MP3 format. After this you will be able to transfer them to a memory card or to most mp3 players or mobile phones or PDAs...
In case you have purchased a great amount of music from these stores, you can go ahead and use TuneClone which acts as a Virtual CD-ROM drive on your PC, and lets you remove the DRM element without having to waste actual CD's.
You can check out the same at their website: http://www.tuneclone.com  Click Here to know the exact steps as well
Posted on Jan 26, 2009
Hammid Disu
  • 821 Answers
SOURCE: Micro SD Slot in My LG Rumor 2 isn't reading Micro SD Card
hello,kindly check if it is inserted properly,you will see a directive arrow on the memory card to show you how it is to be inserted,if after you have inserted it correctly and it still does not sees it,i would suggest you suspect your memory card is corrupt if their is any message displaying on your mobile phone screen,and if it does not show any message like memory card corrupted,then you will have to visit a mobile phone repair expert to help you change the memory card slot,after this your mobile phone will now read your memory card.
kindly rate this solution if it's helpful,
take care.
Posted on Apr 16, 2010
teknikgurun
Teknikgurun
  • 450 Answers
SOURCE: memory card not supported
THIS WILL MAKE YOU LOOSE ALL FILES!!!
(even password)
Take the memorycard out of the phone and,
put it in a computer.Use filesystem FAT-32
to reformat your memorycard.
Now the card will work again!
No password, No files will be left after a
complete reformat
This is your solution! Please vote!
Posted on May 12, 2010
SOURCE: I put my memory card inside th PNY Micro SD Card
en.kioskea.net/guide/703990-pny-micro-sd-1gb
Posted on Aug 02, 2010
Black specks or chips are collecting on the optics inside of the scope. The scope won't hold zero. Scope is mounted on a 50 BMG.
Hey, the a good probility that it dust. I don't know how ATN seals it NV scopes. But the 50 will shake it to the extreme that it will loosen everything in the scope. Did ATN say it can be used on a BMG 50. How is your nut and screw working hey. stewbison
Jun 29, 2011 | ATN (16X65Z)
Power light turns on, Infra red illuminator works, cant see anything in scope. Reticule doesnt light up and no vision through optics. New battery etc.
Hello, bad image intensifier tube and possible ccfl with it coil. Major repair on MK238 scope. I think they make a generation 2 tube for this scope like 350,360,390, and 410. Call AT ATN. stewbison
Mar 04, 2011 | AMT Datasouth Aries MK238 Weapon Sight
When turn ATN 410 on - nothing shows , dark .
Are the batteries OK. There are just so many thing that can go wrong with these units. ATN uses a 1st generation image tube that manufactured in Russian and along with ccfl inverter, and voltage multiplier. Call ATN and ask them to give you estimate on fixing your MK410. You can send to me, but you will to contact on facebook under Richard Morris. I will fix a few every now and the.
But first contact ATN. Now listen the might tell you it to expensive to fix and you can trade in you existing MK410 on a new model (they still manufacture MK350, MK390 abd MK410) All I know is that I can't new parts for scopes, monocular to fit the. ATN calls it: "Proprieatary"-----it's a scret for a cheap Russia tube. stewbison
Feb 24, 2011 | ATN Aries 410 Weapon Sight
When is best time to sight in ATN 390?
At night. You can sight in the 390 during the day in simi-darkness with a day light lens cover over the front of the scope. (the snap cover has a small hole in the center for look see during the day) 50 foot room with a target, bench rest and a rifle vise. You'll also need laser bore sight Figure you rifle ammunition ballistic and how many yards before it starts to drop. Set the 390 reticle to the red do on the target one or two inch above. Dead center set up will give you about two hundred yards on center... approx. Now you know this is a static test or sight in. During night because of some distortion and noise from the scope. stewbison
Feb 17, 2011 | ATN Aries 390 Paladin Weapon Sight
My atn mk-258 fell 3 feet to the ground. Now, power light works, all three ajustment lights work. But no green scope or white weapons site. What is needed for repairs and who would do the repairs?
Sorry, You probly disloged the micro plate in the image intensifier tube or brok it. Very thing in scope MK258 is manufactured in Russia. I have two or three of these Russian image tube, they are all generation 1 and cheap. About the only thing they use of scope shock is a thin rubber colar around the image tube. There is a good possibly it destroyed the image tube, sorry. stewbison
I am on face book Richard with a picture of one ugly dude.
Feb 06, 2011 | ATN Aries MK-258 Weapon Sight
I would like to obtain a instruction manual for Aries MK6600 Night scope Prefer PDF Please advise
Contact custom service for ATN for a manual. I don't think they have a pdf download but you ash them. I wish you lots of luck here. GB...stewbison
Nov 06, 2010 | ATN Aries MK6600 Weapon Sight
Nite Vision scope
Unscrew front lens front of intensifier tube should have an even bronze tinted coating on glass if it is grey and blotchy the tube is degassed. common fault with this model nightvision
wayn
May 12, 2008 | ATN Aries 390 Paladin Weapon Sight
Problem with my atn 390 nv scope
Oct 30, 2007 | ATN Aries 390 Paladin Weapon Sight
Nv sight dead
No more lights steady type: Aries 390 Paladin, light guide only focus.
Mar 27, 2007 | ATN Aries 390 Paladin Weapon Sight
Optics Logo
1,013 people viewed this question
Top ATN Optics Experts
john h
Tom Chichester
Bill Boyd
Are you an ATN Optic Expert? Answer questions, earn points and help others
