Ovens Logo
Question about Viking Ovens
Viking veso digital clock not working after power outage
Posted by Barbara roensch on
1 Related Answer
Anonymous
  • 725 Answers
SOURCE: the digital and analog timer do not work
No, there is not a fuse on this model. You will need to repalce the clock assembly for this unit. Call us asap and we'll ship the correct part out to you asap so you can start cooking again. We look forward to working with you!
Posted on Oct 19, 2009
When we reset the clock after a power outage, the clock runs fast now almost a minute in 30 seconds. Bosch HBL5750
Advise manufacturer; may give you a warranty on this part even after it has expired because of nature of the problem.
2answers
My clock does not work on my stove
Hi Jason. Have you performed the following actions?
Electronic Timing Center (Analog Clock w/Digital Display)
Synchronizing the analog and digital clocks
1. Press the "timer" and "start time" buttons simultaneously.
2. Turn the set knob to move the hands on the analog clock to any time setting.
3. After five seconds the display will go blank. Press the timer button and using the set knob, set the digital time to the exact time on the analog clock. This will synchronize the two clocks. You can now set the time of day.
Setting the Time-of-Day
The time-of-day must be set before any other program can be used. When your oven is first connected to the power in your home, the digital display will show 00:00. To program the time-of-day:
1. Push and hold the "timer" and "bake hours" button at the same time.
2. Turn the "Set" knob until correct time is displayed on the digital clock.
3. Release "timer" and "bake hours" button
The analog clock will automatically set after the digital time is set
Let me know so that I may follow up if need be.
1helpful
What does pf on digital display mean? Oven will not work
PF means power failure.
This has caused a power outage to the oven.
This error can be removed by resetting the clock.
Hope this helps.
Thanks for using Fixya.
The digital and analog timer do not work
F7 code on maytag cwb3100aab 24" wall oven.
Hi, The Function key is shorted or stuck.
Replace touch pad or if touch pad is part of the clock, replace the clock (ERC).
5helpful
3answers
Lost manual for eaton/viking model # RS3025W-1.
set both knobs the temperature and the bake broil to the lock mode, set the time such as 3 to 4 hrs I think and hit start. You should then here the oven begin to lock.
2helpful
3answers
Viking oven won't turn on
I had same problem (twice) with my Viking dual fuel range. In my case a relay that supplies power to the oven heating elements failed. The convection fan would run. The elements were warm to the touch. If you have a free standing range, it may be that relay (part number PM010026) which is located in the front of the stove. Remove a long narrow stainless steel panel (1 screw each side) located under where the door hinges. You can hear the relay click when you turn up the oven thermostat. That will help you locate the relay.
Note: Viking does not sell parts. You have to find their parts distributor for your part of the country.
Top Viking Ovens Experts
Angel Joseph Jr.
Angel Joseph Jr.
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you a Viking Oven Expert? Answer questions, earn points and help others
