Question about Kodak Office Equipment & Supplies
Kodak 3250 aio shows error code 3830 what does this mean
Posted by richard monette on
5 Related Answers
Anonymous
  • 295 Answers
SOURCE: I have a kodak esp9 on win xp wireless connection.
  1. From your computer, access Device Manager.
    • For WINDOWS XP OS:
    • Right-click My Computer, then select Properties.
      • Select the Hardware tab, then Device Manager.
  2. Select View > Show hidden devices.
  3. Select Printers.
  4. Select Action > Uninstall.
  5. Select Action > Scan for hardware changes.
  6. Double-click the KODAK AiO Home Center icon. If the error occurs again, go to the next step.
  7. Set administrator rights for the Home Center application:
        • Right-click on the Home Center icon.
        • Click Properties.
        • Click the Compatibility tab.
        • Clear all the check boxes.
        • Click Apply and OK.
    1. Double-click the KODAK AiO Home Center icon. If the error occurs again, go to the next step.
      IMPORTANT: In the next step, before you install the Home Center Software, make sure you disconnect the USB cable. Then, connect the USB cable when the software installation instructions tell you to do so.
    2. Upgrade the software and firmware for your printer:
Posted on Jul 28, 2009
Anonymous
  • 214 Answers
SOURCE: just bought Kodak ESP 3, all in one printer I'm
Try turning off the printer then restart the computer then try again
Posted on Dec 29, 2009
Anonymous
  • 64 Answers
SOURCE: errors on my Kodak ESP 3250
error 3501: STATUS_ERROR_UNIT_OPENED_WHEN_IDLE. You probably had it open when you inserted your cartridges.
Error 3502: STATUS_ERROR_MAIN_PAPER_TRAY_EMPTY. You must have inserted some shortly after you turned the printer on for the first time so don't worry.
Error 3609: STATUS_ERROR_UNIT_OPEN_WHILE_PRINTING. This is also another basic function on the printer.
I would recommend not looking at the errors on a printer test page as they show all errors that come up on the printer, even if they are not important.
Posted on May 13, 2010
Kandi Cook
  • 823 Answers
SOURCE: Kodak ESP5 AiO
Please clarify a few things for me so I can help you solve this issue.
Are you trying to scan from the printer to the computer? (pushing the scan command on the printers keypad to send the signal to the computer)
OR
Are you trying to scan from the computer to the printer? (Using the scan options in your software by choosing "start" and then "programs" and opening your printers software to choose the scan option)
If your scanning from printer to computer (using the printers scan option on the keypad) and your getting an error code, chances are the problem is you have not set up your defaults in the printers menu yet. To scan from printer to computer, the printer needs to know which program you want your document to scan to in your computer. If its a text document, some people choose "Microsoft Word" and the scan fuction sends your item to that program and opens it for viewing on your computer screen.
There are different programs to use for each type of fax that need to be set up in advance in your printer to be able to scan from printer to computer. Send pictures to a photo editing software and choose the size and resolution you want as "default". Do the same for setting up text documents before you try and use this feature to eliminate the error code.
To configure your options to scan from printer to pc, push the "menu" button on your printer and use the up and down arrows on the printers keypad to move through the choices. Find the command similar to "scan options" and follow the prompts to set the defaults on handling text documents and pictures and then save your choices by pushing the "ok" button on the printers keypad.
Try scanning again with your computer turned on and open to the desktop. Push the scan button on the printer and see if it sends the image or document to your computer screen. It should warm up, then scan and show a preview on your screen for you to accept or reject. If this does not happen, please asnwer my questions as listed above and clarify what you see so I can help solve this issue right now.
Posted on Sep 27, 2010
Anonymous
SOURCE: I CANT OPEN KODAK AIO HOME CENTRE SOFTWARE FROM MY
I want to print passport photos on my EasyShare 3250 All-in-One Inkjet Printer, how do I do it?
Posted on Jan 22, 2011
My kodak esp 6100 keeps on showing error code 3806?
Disconnect power cord, let it set 30 sec, reinstall cord. If problem still there pull out the printheads and reinstall, may have to do this a few times, if problem still there may need printheads.
May 07, 2014 | Kodak Office Equipment & Supplies
Ineed to reinstall kodak esp 3250 printer scanner but do not have disc tryed to use it but came up error 101 2015 how can iset it up again withuot disc thank you alan
From the Kodak website:
For error codes 101-3011 or greater, follow the instructions provided in the message text box. If the error persists:
  1. Uninstall any All-in-One Printer Software installed on your computer:
    Select Start > Control Panel > Add or Remove Programs > KODAK AiO Home Center Software.
  2. Select Change/Remove.
  3. Restart your computer, then log in as administrator.
  4. Close any programs that are open, including those that appear on your computer taskbar.
  5. Confirm that your computer is connected to the Internet.
    NOTE: If your connection to the Internet is wireless, verify that the signal strength is sufficient.
  6. Install the latest version of all-in-one printer software.
    1. Locate and select the software for your operating system.
    2. Follow the instructions to install the software.
      NOTE: If you don't have access to the Internet, install all-in-one printer software from the CD that was supplied with your printer.
Although your error message is different, the above is basically a good piece of advice. Do a clean reboot, and uninstall anything to do with the Kodak printer.
The driver you need can be downloaded here: KODAK DRIVER
Sep 21, 2011 | Kodak Esp 3250 Allinone Multifunction ( ...
I have lost my cd installer for kodak esp 3250 ?
You can download the software and drivers for the Kodak AiO ESP 3250 from Kodak . . .
http://support.en.kodak.com/app/answers/detail/a_id/36460/selected/true
Scroll down the page, click on the blue download button, then save the aio_install.exe file to your PC. The installation instructions are further down on the same page.
Hope this helps.
Regards, BElectric
May 26, 2011 | Computers & Internet
My p0rinter is not printing with good color quality. Blue doesn't pick up. I ran the troubleshooting and the error code 3502,3501,,3830, comes up. How may I fix this? I have new cartridges. thank you....
This is from the Kodak website.
How do I resolve the error message "Printer Access Door Open" (error code 3501 or 3609)? Published 08/25/2010 11:38 AM ' Updated 01/07/2011 08:40 AM ' Answer ID 1467 How do I resolve the error message "Printer Access Door Open" (error code 3501 or 3609)? To resolve this error, close the printer access door. The printer will not operate while the door/cover is open.
If the error continues even after you close the printer access door, power cycle the printer:
  1. Turn off the power (press the On/Off button on the printer).
  2. Unplug the printer power cord from the back of the printer.
  3. Wait approximately 30 seconds.
  4. Plug the printer power cord into the back of the printer.
  5. Turn on the power to the printer.
Feb 07, 2011 | Kodak ESP 5 Printer
Kodak ESP 3250 Printer shows message "Unable to detect edge of paper" and paper just goes straight through
I've had this problem with my esp 3250 that has become progressively worse over past year. I have tried every fix available online from driver, cleaning, power, etc. My printers default quality was set to 'draft' (just to save ink) which obviously speeds up the printing and I've found that if I use 'normal' or 'best' quality, it seems to help the printer detect paper edges, I think bc it slows down physical printing process? go figure but it's gotten me around a few times when I've needed hard copies immediately. Also, changing to heavier bond paper, 92 or better helped with edge detection. I'll finish current ink and not buy another one of these:(
Jan 16, 2011 | Office Equipment & Supplies
I CANT OPEN KODAK AIO HOME CENTRE SOFTWARE FROM MY WINDOW 7 MY PRINTER IS KODAK ESP 3250 PLESE HELP WHAT I DO?
Feb 15, 2010 | Kodak EASYSHARE 5300 All-In-One InkJet...
I have a kodak esp9 on win xp wireless connection. Constantly get the 1-2010 error code and kodak aio home center will not open and the printer will not connect any solutions?
  3. Select Printers.
        • Click Properties.
Jul 17, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Error code 1- 2036
I fixed my error code 1-2036 by going to the "Configure Settings" in the AiO Home Center then selected AiO Printer changed to "Print Quality" to Draft and clicked OK.... Then I was able to Scan with no errors. I think the config settings were corrupted some how and this resaved them properly.
if that doesnt help
Go to Control Panel
Double Click on Printers and Other Hardware
Double Click on Scanners and Cameras
Double Click on Kodak 5100 AiO
Click Next
Read and follow directions
if both the solutions doesnt help... its time to call kodak
Jul 10, 2009 | Office Equipment & Supplies
48 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Muntejaya Ginting
Muntejaya Ginting
efs_perpends
efs_perpends
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
