Question about Kenwood Computers & Internet
Bonjour je dispose d un autoradio kenwood kdc 5021 probl?me je n ais plus le code pour le d?bloqu?
Posted by funkyz on
5 Related Answers
Anonymous
SOURCE: mon recepteur fta viewsat ultra est bloque
As-tu le cable db9? Et qu'est ce qui apparait sur la fenetre de ton ultra quand tu l'allumes?
Posted on Feb 06, 2008
Anonymous
SOURCE: ou je peux trouver le driver pour mon cell
my friend is informatien and he solved this for me i don t know how
thx a lot
Posted on Jun 03, 2008
jerryg50
Jerry Greenberg
  • 1691 Answers
SOURCE: disque cod?
To have answers in these types of groups it is best to translate in to English.
The question in English:
Hello, I have a problem with a laptop which called for a password bios. Well, I removed the battery for a moment and that is installed. I launched the boot on the disc cd then it did the restart, it asks me a password hard disk. I then passes through several means even SKY_FOX I tried but nothing.C 'is a brand Fujitsu Siemens Lifebook and I do even more started on the system' exploitation. I really need help, if you could do something without needing expensive experts. Thank you. __ Have you contacted the former owner to get the password? If the hard disk is pass-word protected and you do not have the password, the fix would be to un-install the partition, and re-make it. Then do the full re-installation of the operating system, and the re-registration for ownership. In some cases where the hard disk is password locked, there may be no possible way to be allowed to undo and re-make the partition to do a full re-install. If this is the case, changing the hard disk will fix it. The old hard disk would be scrapped unless you can have its password. BIOS Level Password Procedure: With some models of computers, you can remove the BIOS battery and wait until the BIOS setup is depleted. Then you should then be able to have access to re-set up the BIOS. You will have the choice to put in a new password or simply not to. If the computer hardware is pass-worded at the BIOS level and it does not deplete with the battery removal, you will have to send the computer back to the manufacture to have the computer un-locked. You will have to pay the shipping and the service fee. When sending the computer back to the manufacture for the unlock, you will be asked for proof of ownership of the computer with proof of identification. With most computer companies, a copy of the purchase invoice, and a copy of your driver's permit or citizenship card should be acceptable. ________________________________
Google Translated, Answer in French: Avez-vous contacté l'ancien propriétaire pour obtenir le mot de passe?
Si le disque dur est mot de passe protégé et vous n'avez pas le mot de passe, le correctif serait d'installer un-la partition, et re-faire. Ensuite, faites le plein de nouveau l'installation du système d'exploitation, et le ré-enregistrement de la propriété.
Dans certains cas où le disque dur mot de passe est verrouillé, mai il ne peut être moyen d'être autorisé à annuler et re-faites une partition de faire une re-installer. Si tel est le cas, changer le disque dur fixe. L'ancien disque dur serait supprimé à moins que vous ne peut avoir son mot de passe.
Mot de passe BIOS niveau procédure:
Avec certains modèles d'ordinateurs, vous pouvez supprimer le BIOS batterie et attendez jusqu'à ce que le BIOS est épuisé. Ensuite, vous devez alors être en mesure d'avoir accès à re-configurer le BIOS. Vous aurez le choix de mettre en un nouveau mot de passe ou tout simplement ne pas le faire.
Si le matériel est libellée au passage à niveau le BIOS et ne pas épuiser la batterie avec le déménagement, vous aurez à envoyer l'ordinateur à la fabrication d'avoir un ordinateur sans littoral. Vous devrez payer les frais de livraison et les frais de service. Lors de l'envoi de l'ordinateur à la fabrication pour la déverrouiller, il vous sera demandé une preuve de propriété de l'ordinateur avec la preuve d'identification. Avec la plupart des sociétés informatiques, une copie de la facture d'achat, et une copie de votre permis de conduire ou carte de citoyenneté devrait être acceptable.
Jerry G.
Posted on Sep 13, 2008
Anonymous
SOURCE: je voudrais un manuel en français pour le
can I have a free manual guide for my xthinn- 8061 svp
Posted on Dec 18, 2009
fish8037
Roger Pierceall
  • 121 Answers
SOURCE: Bonjour j'ai un routeur wireless-g 2.4ghz il n'est
Essayer ce lien, il vous prendra ? la page de soutien de Linksys en fran?ais
http://www.linksysbycisco.com/EU/fr/support/WRT54G/download
Posted on Sep 18, 2010
Bonjour mes amis ofait j'ai un probleme avec mon blackberry 8520. ;j'ai besoin de connaitre mon MEP et et MEP2 si vous pouvez m'aider en ce moment je n'ai pas un autre phone pour dire
You have not menti0oned what is the problem with your Blackberry mobile. About the MEP andMEP2 codes, I dont know about MEP code. But MEP2 code is used to unlock mobiles. Hope you too know that. I know a good website to get the MEP2 code. You can check out ClassicUnlocking.com . You can select all the mobile information from the list of models provided and buy the code. Hope this will solve your problem of MEP2 code. Sorry i couldn't help you with MEP code.
May 20, 2012 | RIM BlackBerry Curve 8520 Smartphone
Je ne peux pas ouvrir mon email yahoo,
Tout d'abord, je tiens d'abord à m'excuser pour mon mauvais français, je suis en fait en utilisant un logiciel de traduction pour m'aider, et n'ont pas étudié le français pendant plus de deux ans.
N'étant pas en mesure d'accéder mail Yahoo pourrait être n'importe quel nombrede problèmes, un mot de passe oublié, une connexion internet défaillante,automatiquement vous déconnecter.
Je voudrais commencer par tenter de se reconnecter à Yahoo, le "signe dans"option vers le haut de la page est ce que vous voulez utiliser pour cela. Le reste se passe de commentaires.
Il pourrait également être connecté à internet afaulty de votre côté, la meilleurefaçon de résoudre ce serait de redémarrer votre ordinateur.
Si cela ne fonctionne toujours pas, fermez tous les programmes non-essentiels et tentera de vous connecter à nouveau.
Encore une fois, je tiens à m'excuser pour mon français, et j'espère que cela aide!
May 05, 2011 | Computers & Internet
Jai un probleme dans la tv daewoo lecran est toujours atteint mais le sens est bien et avec alimentation jai entendu un sens dans la blaque electronic je sais quoi exactemet et merci
Bonjour, Je ne suis pas sûr que le problème est parce que je ne parle pas de français, mais ai une fonction traduit sur mon navigateur. Voici un site Internet que je pense pourrait répondre votre question : s'il n'aide pas, vous pourriez demander à ce site: forum.hardware.fr/.../plasma-daewoo-42nesi-sujet_70005_1.htm
+ HaPlease placent un vote pour moi. Remerciements.
Apr 20, 2011 | Vacuums
Bonjour je viens d aquerir une imprimante ricoh gx 3000sf sur une vente aux enchere et le probleme que j ai actuellement c que quand j allume mon imprimante elle se met en securite et m indique sur l ecran...
Bonjour , latasca09
L' imprimante est sans doute bloqu?e par un objet ( morceau de papier ) coinc? dans les rouleaux . Je ne suis pas familiaris? avec ce mod?le mais il faudrait enlever le couvercle pour acc?der aux rouleaux et voir ce qui se passe . Un simple bout de papier ( souvent du collant ) suffit ? provoquer la panne .
La m?canique doit ?tre impeccablement propre .
Il faut aussi v?rifier si le pilote correct a ?t? valablement install? , notamment en fonction du syst?me d'exploitation .
Je d?brancherais l' imprimante pour commencer et desinstallerais le logiciel/pilote . Faire ensuite un red?marrage de l' ordi . R?installer le logiciel / pilote et rebrancher l' imprimante apr?s installation .
Attendre confirmation que le pilote a ?t? install? correctement .
Verifier aussi dans le gestionnaire des p?riph?riques s' il n' y pas un probl?me de pilote .
J' esp?re que ceci pourra t' aider .
Cordialement ,
fanaudi .
Mar 20, 2011 | Ricoh GX3000sf InkJet Printer
Bonjour g besoin de pilote scanner pour mon hp officejet 5600 g plus le cd
Bonjour. J'ai noté que personne n'a répondu à votre question encore. J'essaye d'utiliser un traducteur de langue de site Web pour vous aider. Je ne parle pas français. Quand vous allez à cette page Web vous trouverez l'aide de HP en français pour votre imprimeur. J'espère que ceci aide.
http://bit.ly/cuguZu
Feb 04, 2010 | HP Officejet 5610 All-In-One InkJet...
Pour l'enfilleuse PFAFF
Bonjour Claudette,
Je n'ai pas de réponse à votre problème mais je peux traduire votre question si vous le voulez...
Merci !
Sylvie à : [email protected]
Jan 30, 2009 | PfaFF Creative 7570
How to switch between tv and vcr dvd or wii?
bonjour j ai le meme remote que la photo ici Jensen ,,, avec le boutton orange, j ai perdu le code pour la television et celui du VCR,,,comment je fait pour le recuperer j ai pas mon livre non plus tout perdu en demenageant et le tout es encore neuf ma television es une Memorex mon VCR un Sanio pouvez vous m aider svp merci ,,,, mon adresse mail,( [email protected] )
Oct 25, 2008 | Jensen 143307 Remote Control
Carte son
Bonjour,
Je ne parle pas tres bien francais alors je m'excuse pour les fautes grammaire. Quelles drivers vous avez besoin? Driver pour connection d'internet? Ou le drivers de music? Etc.
Apr 13, 2008 | Computers & Internet
Mon recepteur fta viewsat ultra est bloque
Feb 06, 2008 | Audio Players & Recorders
Computers & Internet Logo
Top Kenwood Computers & Internet Experts
Mark Dischler
Mark Dischler
Level 1 Expert
Marvin
Marvin
Are you a Kenwood Computer and Internet Expert? Answer questions, earn points and help others
