Question about Sony Audio Players & Recorders
Hi, my sony mhc stereo system will not come on. it just has a blinking light on the power button. help please!!??
Posted by Karen Randall on
KelvinWatts
Same issue. Anyo help?
Posted on Aug 27, 2022
5 Related Answers
Anonymous
SOURCE: Sony Mini Hi-Fi Component System (MHC-RG660)
I understand the problem. It should be the relay which is not responding, technically not able to connect the system power supply, you will have to replace the relay. The STK chip should be working fine.
Posted on Oct 24, 2008
Anonymous
SOURCE: my sony MHC-GX450 has power but does not function,
Mine did the same thing. I unpluged , and carfully took top off where I found a CD stuck. I carefully rermoved CD and put back together. When I plugged it back in I heard a click and the display lit up and I was good to go. I might have just lucked out.
Posted on Jun 18, 2009
Anonymous
SOURCE: Sony MHC-57AV - System shuts down "Push power protect button"
this problem is audeio out put is sort .pls ching out put STK .Any Q - My ID [email protected]
any sony music system problem
Posted on Nov 07, 2009
Zlobomir
Zlobomir
  • 225 Answers
SOURCE: my sony mini hi fi system.model mhc-nx1.reads ;
Lucky guess: you have an auto-fuse somewhere on the back of the unit.
Posted on Nov 08, 2009
tbreeze47
Tom Carson
  • 3083 Answers
SOURCE: why do my sony mhc-gx450 cd shelf system power
This usually indicates faulty wiring, or miswiring. Disconnect the wires, one set and turn the unit off and on to see if that elimates your problem. If it does, the wiring or component is at fault. If you disconnect everything and have the same problem, it's an internal fault with the unit and will have to be troubleshot. Get and estimate first, to evaluate whether or not it's economical to keep, or replace with a new one. Good luck, hope this helps.
Posted on Mar 25, 2010
2helpful
"Protect" Blinking on Sony Stereo
may i see a diagram showing where the ic goes?
Sony MHC-AV9900 When i press power button, system start and blink power light
There must be some problem with the power button which helps you the start the system so need to change that button may be it can help you.
Mhc-rg222 red light blinks power button wont turn on unit
Check the back of the unit for speaker wire shorts, if everything looks fine suspect the output ic's in the stereo.
My stereo just cut off while i was listing to it. and now it wont turn back on. and the power button is blinking red.
Try resetting the system to factory defaults
  • Disconnect the power cord
  • Reconnect the power cord
  • Press Stop (Square button), Play Mode/Tuning Mode, AND Disc 1 at the same time
  • Press I/O(power button) on the system
You will lose your clock and tuner presets.
You can find the full PDF manual here for reference:
http://www.docs.sony.com/release/MHCGX450.pdf
I hope this helps,
magoo
1helpful
The CD Tray won't open on my Sony MHC-GX250
te same thing happened to me know i juat turn the stereo off to where the red light is blinking then turn it back on after the standby message disappears and then i quickly pree the eject button......tr it! and let me know!
My stereo system blinks PROTECT on the screen
one of the out put tran is short ,
there normaly 4 to 8 of them
screw to a big heat sink ,
easy to get to.
check with a volt meter
then google the part
they cost 8.00-12.00
Stereo won't play
only use original speaker, check cable circuits..
Hello
Un Plug It for like 10 to 20 seconds and plug it in it should work it happens to me all the time if it contionuls check the speaker wires and see if the wires are toching together that will be the problem to
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Morne Olivier
Morne Olivier
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
