Question about The Health & Beauty
I have charged the battery overnight. The scooter was working fine and the next minute not at all. What could this be?
Posted by Debbie Hope on
john h
    Top Expert:
  • The Master
  • 23,515 Answers
To many determinations from not hooked up correctly to be charged to battery failure -to circuit failure --start with test batteries --could be failure -if good will need to test the circuit and components like the switches motor connections etc
Posted on May 02, 2018
5 Related Answers
Anonymous
SOURCE: SIGNAL LIHGTS SCOOTER 50CC QINGQI
i want to but a 50 cc scooter from qunigqi what mods do i have to get the most speed out of it
Posted on Jun 18, 2009
Anonymous
SOURCE: On an E 100 Razor scooter, the battery charger shows charged
We had the same problem that I found to have a very simple fix. It seems all that needed to be done was hold in the reset button a few seconds while the battery charger was plugged in and the light on the charger turned to red and the battery charged again. Seems like too easy of a fix but it worked for my kids scooter.
Posted on Jul 19, 2009
steve
  • 440 Answers
SOURCE: battery not charging and causing scooter to shut down
This is probably due to a faulty wiring, regulator/rectifier or, less likely faulty alternator
1st check the wiring & connections from the alternator to the reg/rect (3 yellows) then check wiring to the battery (thick red)
You should get 13.5 volts (with a fully charged battery) across the battery terminals rising with the engine revs to no more than 15.5 volts, if its over then the regulator is at fault
check the alternator for continuity between the 3 yellow wires (3 pairs) at the reg/rect plug after disconnecting it. the 3 pairs should have a similar reading & none should go to earth
To check the rectifier part you need a diode drop setting on your multimeter. there should be a reading 1 way only between the red & any yellow and between the black & any yellow if not it will need renewing
Hope this helps
Please mark as helpful if it has been
Ride safe
Bike-doc
Posted on Oct 28, 2009
william bennett
  • 945 Answers
SOURCE: shoprider cadiz scooter, batteries show full
I think your batteries haven`t been charged properly,or they have been left standing so the charge has leaked out.At a minimum your batteries need to be charged for 12 hrs a day for the first month if not they will not build the capacity and will dwindle and die for example it is at only 25% capacity,but looks like a fullcharge, it says it fully charged but will die
quickly this happens because it is charged to its full capacity but that is only 25% of the batteries true potential
resulting in short battery life.
Unfortunately majority of scooter batteries like this have to be newly replaced.
Posted on Nov 06, 2009
Neil Wood
  • 177 Answers
SOURCE: Scooter stops intermittenly
Hi. Does the machine stop suddenly, or does it slowly stop as it normally would? Does this happen on hills or slopes?
A lot of scooters have a self-resetting circuit breaker connected to the battery leads. If the machine draws to much current ( amps ) then the circuit breaker trips out. After a few minutes the circuit breaker will reset and you can continue.
This could mean that the circuit breaker is faulty or that the motor is drawing to much current, or is burnt out.
Some machines have a very light duty circuit breaker, and these can trip out often. I have changed many of these circuit breakers for this reason.
Check all your battery leads are secure and tight.
If it is still a problem, get a serviceman to check the motor current is what it should be.
Good luck. Neil.
Posted on Jun 07, 2010
How to change batteries in a Rascal
The Rascal 600/300, remove the seat, lift off the cover, unplug a battery, replace the old battery with a new one, putting the cable connections on the same way, red is +, black is -. Do the same with the next battery, reconnect the anderson plugs,reinstall the cover and seat and plug in the charger with the key on watch to see the needle raises up toward the full mark, allow to charge fully, overnight is good. keep the bats charged up not allowing them to drop below half way for the first 20 charges to break in the batteries. as a rule charge the scooter after every use!
Scooter Doctor App
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
Jun 29, 2014 | Rascal 300 Electric Scooter - Used...
I have a e100 razor scooter.I charge my scooter overnight. Then I get on it the next morning it charges for about 10 hous. It moves fast but after about 6 seconds it will start moving really slow but it...
The charger you are using might have a default in it because it is not working you can also try another charger or let it charge for a few days. I this does not work then there is probably something wrong with your scooter.
Feb 22, 2018 | Toys
I have a golden companion II 3 wheel scooter with new batteries, the problem isafter a complete charge the scooter starts off fine but gradually loses power as indicated by meter in 5 to 10 minutes. A
hi ,there are two parts to batteries holding power and preforming well, firstly how good are the batteries, secondly how good is the charger ?, good batteries and a bad charger will make the batteries appear bad...
Regards
Rob
www.gewizrepairs.co.uk
Feb 22, 2014 | Golden Technologies Golden CompanioN II -...
Phantom battery won't charge
Hello
Are you sure your battery charger is working correctly. Have you tried it on another battery? Possibly, there is a wiring problem, or your battery is the type that needs distilled water - Try another known good and charged battery with your scooter before purchasing a new one to ensure that the wiring is not faulty.
ilona
Aug 02, 2017 | Drive Medical Mini Phantom Three Wheel...
How to charge my panterra transport scooter,do i leave switch on or off and for how long?
tony you can charge it either way with switch on or off and if you have used the scooter alot during the day and the battery level lights are in the red charge overnight. The charger light will turn from yellow to green when the batteries are fully charged It really is a good idea to get into the habit of charging overnight wehn you have used the scooter all day. It helps the batteries to recycle them thru a charge cycle when they run down. Now if the scooter is used rarely then make sure it is fully charged when it stored and charge once a week when idle. Hope this helps you
Sep 09, 2010 | Health & Beauty
Replace batteries
Hi. To remove the batteries, it is neccessary to remove the seat first. Turn the seat a bit and then lift it straight up. Next remove the cover under the seat, it will probably be held on with velcro. Under the cover you will see the batteries. They will be held in place by fabric straps, which you will have to loosen. Make sure that the machine is turned off, unplub the batteries and remove them.
You will be the best judge of the condition of your batteries.
Can you travel as far as you used to, without the battery gauge falling further than it used to?
It is important to recharge your batteries after each trip, and to charge them overnight at least.If you haven't used the machine for a few weeks, give it a charge overnight.
Some chargers can be left on for weeks at a time, and some chargers should only be used overnight only. The reason for this is that some chargers, such as the Invacare 8 amp charger, will drop down to a float charge after charging the batteries. Most of the smaller 4 amp chargers do not drop down to a float charge, but maintain the full voltage untill they are turned of.
Good luck. Neil.
May 31, 2010 | Pride Mobility Products Celebrity X - 3...
Battery won't hold a charge - go-go elite travellor scooter battery charged overnight but won't hold charge.
We have had problems with scooter batteries from time to time and the repair man said to take apart the battery case and disconnect the batteries and use a car charger. I put the two battery in parallel and used a amp battery charger. This worked fine.
Don't run your scooter batteries all the way down when using the Go Go as the scooter charger won't always bring them up to full charge and you may have repeat this. Also running the batteries all the way down shortens there life.
Mar 19, 2010 | Pride Mobility Products Go-Go Elite...
Help! My laptop is dead with a new battery
  • The battery you were sold was generic ( not genuine ) and does not work with this PC. Although the specs may be the same, the generic battery is either faulty ( warranty ) or does not fully suit your PC.
  • Best to take the battery to the supplier and explain what has unfolded since you put in the battery, presuming the unit worked fine before hand, and now does not work ( even with an overnight charge ) - you could safely presume the problem stems from the battery itself in one way or another.
  • Some devices ( Laptops, Video Cameras and so forth ) behave badly or simply will not work at all without the genuine makers battery.
Jan 23, 2008 | Dell Inspiron B130 Notebook
Health & Beauty Logo
26 people viewed this question
Top The Health & Beauty Experts
Robert
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a The Health and Beauty Expert? Answer questions, earn points and help others
