Refrigerators Logo
Libby Borg Posted on May 02, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to stop my hotpoint temperature control lights from flashing after defrosting the freezer section behind the panel.
I have read of people having the same problem, where my fridge part of fridge freezer wasnt as cold as it should of been, then as mentioned we defrosted the freezer section behind the panel. even though the fridge seems to be colder now, the temp control lights are flashing. we have tried to turn both controls off and then press the super cool and super freeze buttons for 15 seconds but nothing :-(. tried a few times but still flashing. any other suggestions please
Andy
Level 3:
Loyalty:
Visited the website for 30 consecutive days.
  • Master 572 Answers
  • Posted on May 02, 2018
Andy
Master
Level 3:
Loyalty:
Answers
572
Questions
0
Helped
209720
Points
1498
Try cleaning your condenser coil at the back of the refrigerator. If there is constant ice built at the evaporator coil which you have to defrost manually then you have a defrost timer issue
5 Related Answers
Anonymous
  • 290 Answers
  • Posted on Oct 03, 2007
SOURCE: Food is defrosting in my hotpoint frost free fridge/freezer
Can you hear the compressor running? Is the fan inside the freezer running? It could be that a wire connection has come loose during the move. Was the fridge laid on it's side during the move? If so you probably have compressor oil restricting the refrigerant system. If compressor and fan are running you will probably need a qualified refrigeration tech to check it out.
Anonymous
  • 828 Answers
  • Posted on May 18, 2008
SOURCE: ffa70 hotpoint fridge freezer
Adjust the temperature control for the freezer to a normal setting. Fast freeze is only for when new products are put in that need to be frozen. This locks the system into a continuous run mode and could be responsible for the freezing condition in the refrigerator section. Check the temperatures with a thermometer as the sensor for the freezer temperature could be bad causing the light to come on.
Anonymous
  • Posted on Aug 01, 2008
SOURCE: Bosch Classixx Frost Free KGU34640GB/06
the freezer is not defrosting at all .How to defrost it ?
Anonymous
  • Posted on Dec 27, 2008
SOURCE: Hotpoint Mistral Frost Free Fridge freezer - fridge not getting cold
We have just had to call out an engineer to get our 1 1/2 year old Hotpoint Graphite Frost Free Fridge Freezer repaired. The fridge had almost entitely stopped cooling even when on high. I was amazed at how easily the problem was sorted. The engineer removed all the basktes from the freezer to access the screws on the inside backpanel of the freezer. Once this panel was removed it was clear that the so called Frost Free doesn't really mean what it says. The ice need to be melted with a bit of simple care. It is obvious that with a bit of care it is easliy a diy job BUT PLEASE BE CAREFUL AND READ THE NEXT PART BEFORE YOU BEGIN TO REMOVE THE ICE> The ice forms around variouys pipes etc and he usecd a screwdriver to help release the ice quicker than waiting for it to defrost and he also used a simple hairdryer to help speed up the process. He had a ntowel and a basin to take care of the water. Next time I would have no problem doing this myself but I would need to leave it a little while to defrost and NOT USE A SCREWDRIVER as I am sure somehow I would puncture a pipe or the wall of the freezer itself and I am quite used to doing the odd bit of DIY. On a difficulkty scale of 1 to 10 with 10 being difficult I would rate the job as about a 3. Hope this helps anyone who reads this about £70.
Anonymous
  • Posted on Oct 13, 2009
SOURCE: Accidental defrost
I did the same thing. I know it's a little late now but for anyone that does this again here's what to do. There's a thermostat in your actual freezer you might not be able to see it, because it might be covered in ice. It looks like a tiny tube, To stop the defrosting all you have to do is warm up the thermostat either pressing a hot towel agaisnt it or meltling the ice with a dryer (but be careful)! After a minute or so the red button should pop out again and the refrigerator will start humming again. Unplugging the refrigerator will not reset anything and don't try to pop the red button out of your own!
Where can I get a repair manual for a Hotpoint Fridge
First of all, the model number you gave is not complete. But check you defrost system in the freezer, when the refer section stops cooling, your evaporator in the freezer is possibly full of ice and the fan won't move air through ice. When the refer sections fails to cool, check for a fan in the freezer. If it works, you have a defrost problem and is occurs every 3 - 5 days. The unit should defrost once or twice a day. Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
My fridge part of fridge/freezer doesn't work
Post the model number of the refrigerator. Defrost freezer behind where the cold air circulates with a hair drier. (unplug power first!) Most times when a refrigerator side stops cooling it is because the freezer evaporator behind the panel in the back of freezer (most times) has become blocked by frost=> SEE PHOTO Most times the panel before you see the frosted covering the evaporator will begin to show a layer of frost building=> SEE PHOTO (Click each photo to enlarge.) Sometimes the fresh food section of the refrigerator side will warm because ice or frost will block the damper from moving that regulates temperatures in the fresh food section. Sometimes the damper is defective and sometimes the sensor that controls the damper movement is defective. For these reasons it is important that you provide your model numbers so someone knows just what type refrigerator you have to cover all of the possibilities of what may be wrong causing the warming of the fresh food section and soon the freezer section will also begin to warm. The most likely cause are the defrost control, ADC Adaptive Defrost Control, defrost heater, defrost thermostat, air damper and air damper sensors in that order. Let me know what you have and I will try to identify just what may be happening, Thanks Sea Breeze
My Hotpoint Fridge Freezer 187P has Blinking Lights
Kindly upload pictures of the two lights flashing. What does the writing next to the two lights read?
Mr.
When the heater comes on for defrost behind the rear freezer panel , it gets red hot . The defrost thermostat ( bimetal ) , cuts the heater off , when it reaches 140 degrees for new (2000 - 2009 ) and 55 degrees for older refrigs . When this temp is reached at the top of the coils , the lower portion will be hotter due to being closer to the heater . The frozen food in the freezer , is what keeps the temp down in front of the rear freezer panel . No food in freezer , the hotter the freezer section will be .
1helpful
Food defrosted in freezer--turned to coldest setting--there is some cold air coming in but seems only small amount-refrigerator is only "cool"-fan seems to be working
I believe part number W10135899 Defrost Control Board is defective. The board is located inside the fresh food section and behind the control panel. Near the temperature controls. Look at the rear wall of the freezer. If a layer of ice is forming on the rear wall of your freezer then it also is forming behind the rear panel of the freezer and restricting air flow. The Defrost Control Board is the most likely reason then there are 2 more things to have a look at. That is the defrost heater and the defrost thermostat. Would not be a bad time to manually defrost your freezer so you can bring temperatures down and replace the part. Unplug refrigerator, remove the rear panel inside back of freezer and defrost the evaporator coils with a hair dryer Or you can leave a bucket of hat water setting inside the freezer compartment with door shut for a while. Let me know what you find, again most like problem is the Defrost Control Board, Thanks, Sea Breeze
Freezer and fresh food section are both at room temperature.
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
NOT COOLING
Most likely your defrost system has failed. Most times it's in the control area of the system and that part will depend on the model number. The control part would most likely be the defrost timer or Adaptive defrost control board most times you find the timer or ADC inside the fresh food section and behind the controls for the temperature. And sometimes it's the defrost heater and defrost thermostat located behind the rear panel in the back of your freezer. Fact is you may be able to open the freezer door and look at that back wall and see frost clinging to the rear wall. If yes the unplug remove the rear panel in freezer and defrost with a hair dryer and lets look over the defrost heater and defrost element or use a OHM meter to test the parts. Sometimes you will see the heater burned out. Get me your model number most times on the front of the refrigerator and down near floor and behind the fresh food section door. Let me know what you find, Sea Breeze
1helpful
2answers
The freezer is accumulating frost. i have
Some models like yours came with a defrost control board and others came with a defrost timer. They should be found inside the fresh food compartment and behind the temperature control panel. You will need to inspect and let me know which you have. Unplug first. If the control board looks or does not look burned it could be bad. The timer can be turned clockwise until compressor stops and should remain stopped for about 25 minutes. and then turn itself back on. If these look good then we need to remove the rear panel inside the freezer and test the defrost element with one wire disconnected to check for continuity. Just to be sure the element has not burned out. The defrost thermostat is connected to the defrost element and will have open contacts inside it above 50 degrees. Do these test with power unplugged and let me know what you find. Sea Breeze
127helpful
12answers
Hotpoint Fridge Freezer FF187e - 3 lights flashing
i have just fixed my fridge freezer by following the instruction from KarenBa and GWoman i have also managed to stop the lights (super cool and super freeze) from flashing by turning the temperature to zero on both fridge and freezer so they turn off then holding both super buttons down for about 15 seconds then turning the temperature back up. hope this helps
Ffa70 hotpoint fridge freezer
Top Hotpoint Refrigerators Experts
ZJ Limited
ZJ Limited
Jose Ramirez
Sean Wright
Sean Wright
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
