Raise mower off the ground so Wheels turn free start the mower with arms all the way out the wheel still turn on each arm is an adjustment just pull the pin and turn until the wheel stopped turning then replace the PIN you will probably have to replace the brakes on the transmission they're probably shared out
You need to adjust your clutch. Tighten up the play in the clutch cable.
SOURCE: gear stuck in park
Turn the key to the left as hard as you can, as you turn the keys see if that works.
