Cameras Logo
Question about Olympus Cameras
I have an Olympus SP-800UZ and am unable to select Time Lapse it is greyed out in the menu
Posted by Ken Robottom on
5 Related Answers
Anonymous
SOURCE: Olympus SP-350 USB Device Not Reconized
Hi
You have to take out the card before you switch on the camera. Switch on the camera and then put in the card. Then it works
Posted on Jul 18, 2008
Anonymous
  • 919 Answers
SOURCE: cannot select "camera menu" from the Top Menu
If the camera is in Auto mode those items cannot be selected because the camera is already using factory default settings and they cannot be changed, If you press the Ok button and change to P mode then you will be able to access all of those menu settings and make any changes you wish to the camera settings.
Posted on Dec 29, 2008
Anonymous
SOURCE: need the software for olympus
software for olympus SP 800UZ
Posted on Feb 01, 2011
willem52
Willem.
  • 359 Answers
SOURCE: Can you use a haze or UV filter on the Olympus
Yes it is possible with a lens adapter. Search for Kiwiphotos LA-67SP800 or LA-67SP800. Or look at: http://www.kiwifotos.com/Pro_show.asp?Proid=83
On Ebay they can be bought quite cheap. You can fit a filter onto the lens adapter.
Posted on May 02, 2011
willem52
Willem.
  • 359 Answers
SOURCE: Installed the Olympus sp-800uz to
If you have installed the [ib] software from the camera, this program seems to be very unstable and buggy. I would recommend to use the new Olympus Viewer 2 software instead. De-install the [ib] software and download and install the (free) Olympus Viewer 2 software. It supports the SP-800uz.
See: http://support.olympus-imaging.com/ov2download/index/?Lang=ENU
You need to put in your camera serialnumber to be able to download it.
Why can I not get cameras menu to review images
press the view or display button. t switch over from recording to viewing. Then try pressing the display button several times.
I bought an Olympus SP -800Uz in Las Vegas U.S.A. Should it have had seperate software in the box, Joan U.K.
No, the Olympus SP-800uz has the PC Software on its internal memory.
The quickstart guide does tell the procedure to follow: Initialize camera
and installing the ib software. If you did format the internal memory of the
camera, the software setup is lost. You can find alternative and better
Olympus software here. The ib software you can find here.
I lois cd for my software olympus sp-800uz
The Olympus SP-800uz digital camera does not come with a CD.
All PC software is delivered on the cameras internal memory (setup.exe).
When you need software, you can also use the better and free
Olympus Viewer 2 program for PC and Mac.
What is the best way to take photos of firework displays with the SP-800UZ?
1. See the Olympus SP-800uz user manual for explaining the different SCENES.
2. See manual page 22 is explaining the Firework scene.
Just got olympus sp-800uz but get 2 black lines down side screen can i make it full screen
Are you talking about the camera's LED screen, or your computer monitor screen?
Anyway, the Olympus SP-800uz camera has 4:3 image sizes and widescreen 16:9.
Just set your camera to the size you need to get your images shown fullscreen.
An alternative is to use a graphic (or tool) program that is able to crop your images.
How do I turn off the date imprint on my SP 800 uz ?
For what I can see, there is no standard date imprint on the pictures other than in the PRINT menu.
See the Olympus SP-800uz user manual on page 51, point 5.
How do I correct the time and date if I entered it incorrectly
You can edit the Date and Time in the Settings 3 menu. See the Olympus SP-800uz manual page 44.
You can download the manual at:
http://www.olympusamerica.com/cpg_section/cpg_support_manuals.asp?id=1499
or (English only):
http://www.olympusamerica.com/files/oima_cckb/SP-800UZ_Instruction_Manual_EN.pdf
Can I zoom when recording on the olympus sp 800
Zooming when recording video on the Olympus SP-800uz is only possible when the sound is set to off. Set the zoom to the setting you want before recording, after that start recording.
2answers
Olympus sp 800uz user guides
You can get the user manual for this unit from this link.<br /><br /><a href="http://www.olympusamerica.com/files/oima_cckb/SP-800UZ_Instruction_Manual_EN.pdf">http://www.olympusamerica.com/files/oima_cckb/SP-800UZ_Instruction_Manual_EN.pdf</a><br /><br />
Aug 25, 2010 • Cameras
Top Olympus Cameras Experts
Steven Wander
Steven Wander
David Shaub
Steve
Are you an Olympus Camera Expert? Answer questions, earn points and help others
