SOURCE: Mitsubishi WD-C657 ,green led flashes
Just cliick below for how they repair there DLP TV and a picture guide how to replaced the lamp,fan and color wheel .It seems your lamps is defected...
http://www.jangro.com/a/2006/08/15/samsung-dlp-frequent-questions/
how to change your Samsung DLP Lamp.
http://www.jangro.com/a/2006/07/24/samsung-dlp-replace-color-wheel/
Hope this may help;
Regards,
VOTIT
SOURCE: I have a mitsubishi 60 inch model#wd-60735.The tv
Good Day,
It sounds like the TV has a bad COLOR WHEEL Part # 938P137010. 99.9% sure this will solve your noise.
Good Luck, Big Irish.
SOURCE: i have a mitsubishi wd-60735 tv when i turn the tv
Did you recently replace the lamp? If you did then it might be the new lamp. I mistakenly bought an aftermarket lamp to replace mine and it would not work consistently. Apparently if it is not an Mitsubishi original lamp it has issues, because after I replaced it with a Mitsubishi lamp it worked perfectly fine.
SOURCE: Mitsubishi wd-60735 no picture and red lamp light
you have a digitdl light processing (dlp) television, which uses a high-pressure mercury-vapor lamp. depending on the hours of usage,the lamp will last about 1-2 years. the red lamp most likely indicates the end of lamp life. the lamp will need to be replaced. the owners manual will have instructions on how to replace the lamp. you can order a lamp on line. i perfer a brand name lamp. follow the instruction carefullt. i found that the television needs to be unpluged for an extended amuont of time to completely reset the timers, at least an hour. i have an older model wd62525.
