SOURCE: dtv
I followed your suggestion and it works! You certainly do push the
info
menu
mute
power buttons but I cannot remember the exact order.
I may have pressed them altogether, or in a quick sequence and it may have been in standby mode or switched on.
Fiddle with it, because it does work.
What will happen is that you will get a set of commands on the screen. Use the remote to get to RESET. At first I coudn't get this to work as I kept pressing the "enter" button in an attempt to select this option, but actually you just need to press the right arrow button to select it.
Reset comes into place. Wait a while and press a channel number, then just re-tune. You will have to re-tune anologue and digital. This works - please share with others. Eamonn
SOURCE: ORION TV 1926A
I have an Orion Model TV2521. How do I turn on "closed caption" without the original remote? It broke and the tv is now using a universal remote. I tried the onscreen menu on the TV,but did not see an option to perform this task.
SOURCE: Sanyo TV stuck on video channel
sanyo ds35590 no remote, tried universial remote still cannot select menu on uvm. What remote do I need? Or can I get into the menu without remote. I am trying to watch a dvd.
Check if the remote is in TV position, that is, because most of the remote controllers have the feature that you can program them for use with another devices. Make shure that one button that says "TV" in pressed and released once before you try to change any function on the TV.
SOURCE: Insignia IS-LCDTV32 32" Wont let me change channels or go to menu
there is a problwm wit hyour mainboard you can buy one on ebay for about $80 and to remove just take off back panel and unplug about 5 wires and remove 2-3 screws on the left side / the same side that your power ch+/- ect is on. and swap out.
please rate my answer it is much apreceated
