SOURCE: car radio code for r770 rover radio
First make sure that the code has not been noted somewhere within the car (underneath the ash tray, glove box , rear of sun visor etc)
To see if your code is available here for free then the radio will have to be removed from the dashboard (and if you are lucky, someone may have written the code on the casing ) .
If not then POST ANOTHER QUESTION
quoting the radio MAKE+MODEL plus ALL the LETTERS+NUMBERS on ANY LABELS ,BARCODES or STAMPED IN THE METAL CASING
note: Unfortunately not all radios can be decoded using the Serial Number
If not then try your Main Dealer ...........or take it into a Decode Service who will plug in a laptop to read/recode the memory chip (EEPROM). This takes a few minutes and shouldn`t be too expensive
SOURCE: this is an update can anyone help with a rover r770 radio code
Your code is 6792
Testimonial: "thank you very much the code worked "
SOURCE: Hi I need a code for my Philips R770 Rover
If it is the standard stereo unit fitted to the car from the factory then you need to call the car manufacturer to get the code. If it is not then you need to call the manufacturer of the stereo to get the code.
