Question about Leviton Electrical Supplies
I have an old easyset E-600VA dimmer connected on single pole to a ceiling light. I want to replace that with a new Leviton toggle switch with dimming slide.
Currently the easyset has three wires (excluding green ground) White, Red, Black. White connect to White in wall, Red connects to black, and Black connects to black. How can I replace that with a Leviton dimmer with just a black and red screw (excluding other two-way red screw for multiple poles).
Posted by Sidney Shelton on
Cliff Crowther
    New Friend:
  • 3 Answers
Bill Boyd is wrong red can connect black. As it can be a switch leg for a ceiling fans light kit. Or it could be a traveler"I
Posted on May 01, 2018
Bill Boyd
    Top Expert:
  • Leviton Master
  • 53,813 Answers
Red never connects to black as that is power to neutral if wired correctly
get in a qualified electrician to check the wiring and help you install the unit
Posted on Apr 30, 2018
5 Related Answers
Anonymous
  • 102 Answers
SOURCE: Need help hooking up a single pole Leviton dimmer switch
hook up the red to red
black to black
green to bare wire
tie white wire to other whites in back of switch box in the wall.
If no whites in there cap it off with a wire connector.
Posted on Nov 03, 2008
Anonymous
  • 75 Answers
SOURCE: Dimmer Switch Installation issue
ALL you really need to worry about is the white and black wire that you hooked up before. The green ground screw is not needed. If you have a bare wire completely bare all the way, you can hook it to the green, but it is not required to work.
The other 2 screws are for the switch. It does not matter which wire goes where, as the switch just puts them together, and takes them apart.
Posted on Dec 21, 2008
Anonymous
  • 360 Answers
SOURCE: Install a single pole light dimmer
House wires are for a 3 way switch, you will need a different switch
Posted on Jan 31, 2009
Anonymous
  • 44 Answers
SOURCE: Single Pole Dimmer Installation
I'm not sure if this is going to work in your case, but I'm pretty sure it will...
Green to ground (probably bare)
Black to black
White to the red that's not labeled 3-way
wire nut on the red labeled 3-way
That should fixya!
Posted on May 30, 2009
bschilz
Bill Schilz
  • 2049 Answers
SOURCE: Have a Leviton dimmer with red, black and green
You are correct in assuming green is the ground and connects to bare copper wire. Black is always the HOT wire and should be attached to the black wire. Red wire connects to white wire.
Posted on Sep 13, 2009
How to replace a doubble lightswitch
Easy way.. TURN OF POWER. pull the switch with the wires still attached from the electrical box. Take off one wire at a time from the old switch and place it on the new one.
Jul 12, 2014 | Leviton COMBINATION SINGLE POLE TOGGLE...
How to wire a leviton 5634 for agarbage disposal
If you are replacing an existing switch, either replace one wire at a time, or write down the wire colors from the old switch.
or look here: http://www.leviton.com/OA_HTML/LevitonSearchResults.jsp?kw=5634+wiring+diagram&tbon=D
May 16, 2014 | Leviton R03-5634-A Two Single-pole...
Replacing old switch, existing leviton dimmer has two black wires coming out of it....can't firgure out which is which? Power, load, grounnd
Hook one of the wires that was connected to the black wire to the silver screw, one to the brass screw. Does not matter which. If there is no ground (bare or green) then you can hook one from the green screw on the switch to the box where the other grounds are connected.
Feb 13, 2011 | Leviton COMBINATION SINGLE POLE TOGGLE...
I have the unit wired and it does not wotk.I have black to black,red to red green to ground and white to white,any thoughts? Thank you
Electrician test wiring before connecting anything.
First of all, you don't mention what type of switch was replaced.
1) Leviton 6230 countdown timer is made to replace single-pole light switch only.
Single pole is where 1 switch controls the Load (light fan motor)
Your wiring sounds like 3-way switch.
3-way is where 2 switches control same Load.
For example a hallway usually has 3-way switches.
To confirm. If old switch has 1 dark screw, 2 brass screws, and 1 green screw, then that is 3-way switch. Use Leviton LTB15, LTB30, LTB60, LTB02, LTB12 countdown timer for 3-way.
Smarthome sells product and shows .pdf manual
http://www.smarthome.com/4255/Leviton-LTB60-1LZ-4-Button-10-20-30-60-Minute-Countdown-Timer-Switch/p.aspx
2) If old switch has 2 brass screws and 1 green screw then that is single-pole switch.
3) If you are replacing single-pole switch, here are testing & wiring instructions for Leviton timer.
Remove device and separate wires for testing.
Use ordinary two wire tester.
Tape tester leads to wood sticks so hands are away from power.
Do not untwist wires that were twisted together before you started.
Turn on power.
Test each wire to bare ground wire.
Tester lights up on Hot wire. This wire will connect to timer black wire.
Now you know Hot wire.
Test Hot wire to each of the other wires, excluding bare ground wire.
Tester lights up on neutral. Timer white wire connects to Neutral wire.
If box does not contain Neutral wire, then timer white wire connects to bare ground.
Timer green wire connects to bare ground wire.
Timer red wire connects to wire going to Load.
Dec 26, 2010 | Leviton 6230M Decora Four Preset...
Using a #5224 Combination two switches to light two different fixtures (an exterior light) and it will only turn off and on by 2nd switch being switched on or off (the interior ceiling light) Hooked each...
I think you have your wires connected to wrong screw.
Wiring devices have screws that are color-coded as you noticed.
The Hot wire from breaker connects to dark colored screw(s).
The wires to Load (ceiling light-outdoor light) connect to brass screws.
If you need more help, add a comment at bottom and I will help further
Oct 26, 2010 | Leviton COMBINATION SINGLE POLE TOGGLE...
I have the power source in the ceiling. I want to run wire to a single pole switch to a ceiling light?
Disconnect 1 side of light. Wire nut 1 wire from switch to 1 side of wire from light. Wire nut other side from switch to light. You now have a switch inline.
Sep 09, 2010 | Leviton 104-05611-2WS 15A Decora Single...
How to install a dimmer switch
This is a 3-way switch, made to control a light fixture that is also controlled by another switch in a different location. A typical example is a ceiling light fixture installed in an upstairs hallway, which could be controlled by switches at both top and bottom of the staircase.
The green wire in your switch is the ground connection, and joins to the green insulated or bare copper ground wire in the switch box. The red wire is the common connection. It connects either to the incoming AC hot wire from the electric panel, or to the hot terminal of the light fixture, depending on the switch location. The two black wires are traveller connections. They connect to the traveller terminals of the other 3-way switch.
If you purchased this switch as a replacement for a regular single-pole toggle switch or dimmer switch - one that controls a light from a single location only - then this isn't what you need and you can't use it. You'll know if you have a single-pole switch because it will have only three wires or screw connections. Return it and get a single-pole.
To install this as a replacement for a 3-way toggle switch or dimmer, connect the red wire to the wire going to the common terminal of the original switch. This will be a black- or brass-colored screw on a toggle switch, or the different-colored (not green, that's ground) wire on a dimmer. The black wires connect to the wires that go to the traveller screws (copper-colored) on a toggle switch, or the same-colored wires on a dimmer. It doesn't matter which traveller wire connects to which.
Note that if you're using a 3-way dimmer, only one of the switches can be a dimmer. The other switch has to be a plain old 3-way toggle.
Apr 08, 2010 | Pass & Seymour / Legrand D703P Harmony...
Hooking up a combination switch with outlet and another switch
ok, i think what you mean is a 3-way switch- meaning two different switches that control one light and a single (pole) switch that only controls one light. you can't do that with the above switch. You need a combination 3-way and single pole switch.
Sep 30, 2009 | Leviton COMBINATION SINGLE POLE TOGGLE...
Electrical Supplies Logo
100 people viewed this question
Top Leviton Electrical Supplies Experts
jdthefixer
Gene Haynes
john h
Are you a Leviton Electrical Supply Expert? Answer questions, earn points and help others
