Question about Grilling
There's a metal screen and a grill with louvers don't know what to do with them.
Sure, I'd be happy to help. Can you provide more information about the specific model of the Comfort Aire air conditioner you have and what part of the installation process you are finding confusing? Additionally, do you have the installation manual? It may have helpful information and illustrations.
Posted on Jan 21, 2023
SOURCE: Installation of down-draft exhaust duct for Jenn-Aire cook top
Minimal 6" duct no more than 20 feet long and 90's count as 5 feet. 90's must not be closer than 18" this will meet local codes regarding the venting also an approved exhaust hood. (not a dryer vent)
Posted on May 22, 2008
SOURCE: What is the proper humidity control % setting?
It is recommended that your settings stay at 35%. The ideal level of humidity in your house is anywhere between 30% to 60% depending on the weather outside.. I hope that this works for you. Have a good day
Posted on Feb 09, 2009
SOURCE: Comfort Aire PAC-121 problem
E4 shows up on the screen on my PAC-121 when the water reservoir on the right-hand-side is not pushed in all the way. If it is in all the way the switch that it engages may be bad or out of place.
Posted on Mar 23, 2009
SOURCE: dripping into the house
Is this unit flush with the wall? And if there is ANY build-up around the hosedrain, make sure to remove it all.
Posted on Aug 23, 2009
SOURCE: Need a manual
looking 4 manual 4 comfort aire a.c. model#pe-121a serial# 070301060
Posted on Jul 24, 2010
Hi Joan Beck, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
Rear grill? need fore info. Unit is removed from case and reinstalled in case.
Comfort Aire through the wall air conditioner. I do not know how to install rear grill on unit or on sleeve. Can you help?
