Question about Ultra Computers & Internet
Ultra 8 Speed Dome powers up and goes through booting set up then goes black and re-boots again and again?
Posted by Fritz Bergman on
5 Related Answers
Anonymous
SOURCE: Monitor goes black after windows boots up
this is probably your screen refresh rate is too high.try booting the computer in vga mode and lower your default screen refresh rate.if it fails try with a older driver. the problem might be due to overheating. try cleaning your cabinet and install a new heatsink and apply new thermal paste on your vram chips.
Posted on Mar 23, 2009
Anonymous
  • 30 Answers
SOURCE: Computer won't boot Windows Vista. Screen goes black with cursor arrow.
In this case you have to do the PC restore . you can do that in dell machines by shutting down the machine and when it is coming back on just HOLD DOWN THE CTRL ket and the START HITTING f11 key in this case you will lose the data which you have the on the c drive but this issue will get resolved .
Else you can try to restart in the safe mode with networking and then go to the system restore and then select the bold dates in which you have idea you system was working fine . selct the date and then do the system restore . In this case you will not lose the data but you will lose the updates which you have done after that date .
in both the cases system will work .
Posted on Mar 25, 2009
Geekman
Chris Hingee
  • 32281 Answers
SOURCE: hp dv2210us power goes on but just black screen, not booting up
You could have a defective screen - a defective inverter or a CCFL lamp, follow this to determine the fault.
To determine if you have a LCD screen problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Posted on Apr 20, 2009
jmgldsmth
Jim Goldsmith
  • 2005 Answers
SOURCE: on my laptop the vent fan starts then stop and the power goes out
These machines have a terrible overheating problem! You will have to clean the fan opening and, put sylicon grease on the heat pipe and, heatsink that covers the cpu
Posted on Apr 21, 2009
ikkenom
  • 10406 Answers
SOURCE: Dell Inspiron 1545 Booting Problem [Black Screen].
Insert the original Windows CD-ROM into the DVD-drive, and see if the computer will "boot" from that disk. If so, then it could be your 'C:' drive which is having the problem, and thus not "booting" your computer from it.
Posted on Jun 15, 2010
Samsung np530u4c error boot
Tap F2 while powering up, enter BIOS and check boot settings order. Maybe it's become set to boot from CDROM first. HDDs should be set to AHCI formats. Try booting from CDROM anyway if you have an operating system on disk.
Jan 13, 2016 | Samsung Series 5 Ultra 530U4C - Ultrabook...
When I try to load it on my pc it just goes to notebook. it is a 10 pack
HP Notebook PCs - Computer Does Not Start (Windows 8 ...
support.hp.com/us-en/document/c03515402
For Enterprise products please go to Hewlett Packard Enterprise. .... Perform a hard reset of your notebook computer before you try any other troubleshooting steps. ... Ifyour computer is not listed below, refer to the User Guide for your specific model for the proper .... Remove the AC adapter and boot on battery power only.
Computer Screen goes black after Windows [Solved] - CCM.net
ccm.net > Forum > Hardware > Monitor
Nov 3, 2012 - Well I was just about to go online to buy a new laptop because my ....After I boot up my laptop and log on, my screen is black and the only thing ... Laptop won't boot after bios upgrade
Dec 8, 2015
Toshiba Laptop doesn't start up. Black screen
Oct 24, 2012
My laptop won't start
Oct 19, 2012
My laptop Toshiba wont work (black screen)
Oct 19, 2012
More results from ccm.net
Dec 28, 2015 | Computers & Internet
How do I restore the BIOS settings on my Cyberpower Windows 8 64-Bit Gamer Ultra 2150. I installed a new graphics card and went into my BIOS to change the setting and after I saved new settings I have no...
You should remove the CMOS battery from motherboard for 10-15 second and than put it again. When you change the graphic card, you shouldn't go to BIOS, just install the Driver for your new grapic card. bed355b8-0e7a-4736-bf41-c4eb95ebe7a5.jpg
Jan 26, 2014 | CyberpowerPC Gamer Ultra 2150 Desktop PC...
Driver side door switches are not working. Dome
My power locks, windows didn't work and the dome lights would not turn off after closing the door. I removed the black boot that was attached to the drivers door by lifting upward and pulling away from the door. A heavy gauge black wire was broken. I removed about 3/16" of insulation from both ends of the broken wire and connected them by using a connector that both ends are placed in to and then "crimped" both ends so the broken wire made contact with each other and everything worked perfectly! The hardest part was replacing the boot. Total cost to fix is $0.50.
Jan 14, 2010 | 2004 Jeep Grand Cherokee
Gateway notebook goes BLACK when connecting new lcd tv to laptop
try setting the frequency down to 60hz and the resolution before you connect. then if it works you can set it up again with a setting the TV likes
Jan 08, 2010 | Gateway MT3705 Notebook
Screen goes black. the power light is on, but the picture goes out. if i turn the power off, then on again it comes back for about 5 seconds, then goes black again.
Check to see if this problem follows in safe mode. Reboot and when the Dell splash screen comes up tap F8 until you see the multiboot options. Scroll to "safe Mode with Networking" let the machine boot up and see if you have a screen. If you do, right click on the desktop and set the resolution to 800 X600 and reboot normally. Usually when a screen goes blank in normal mode but shows up in safe mode means you have an incompatible resolution for the monitor or graphics adapter. This may be a driver issue or hardware. If the screen boots up in normal mode at the lower resolution, then try and go to properties again and bump the resolution up a bit, if it blanks again, try to go online and update the driver for the graphics chip.
Sep 08, 2009 | Dell Dimension E510 PC Desktop
I have a 2004 Jeep Grand Cherokee limited edition and the drivers door control panel doesnt work at all(power windows, locks,mirrors) The controls on the other doors for the windows dont work either but...
I had same problem it is a ground wire broken in the harness rubber boot between dthe driver door. Peel back the rubber that protects wires and you will find broken ground wire(black) add a piece of wire solder and wrap with electrical tape put rubber boot back into door everything should work.
Mar 15, 2009 | 2004 Jeep Grand Cherokee
Usb power issues
Some systems will try to boot up on a usb device such as an IPod or a external hard drive.
It should be unplugged to get it to boot properly.
Oct 31, 2008 | HP Compaq Business d530 Ultra-Slim PC...
Computers & Internet Logo
Top Ultra Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Marvin
Marvin
Vebble
Are you an Ultra Computer and Internet Expert? Answer questions, earn points and help others
