Question about Prima Televison & Video
The AIm Prima tv screen says USB and cannot get it off
Posted by Lionel Kretzmann on
I NEED THE REMOTE CODES FOR A PRIMA L2617 HDTV
Prima 4101 4138, 030,032,036,039,047,054,056,060,091,016,415
466,092,166,251,017,281
BIG SCREEN=166,019,035,154,451,037,068
Oct 07, 2009 | Prima C2012 TV
Black screen prima ph42t7
Hi and welcome to fixya, it is the colour wheel problem,,,,,,,,,this is common problem please check it ...it may be also cathode ray tube... thank u.........
Jun 03, 2009 | Televison & Video
Bottom of screen flickers, and eventually the screen 'freezes'
they have problem lines in tv screen harizontall lines how i can fixed in HDTV prima 29inch.2008 model .give me ANSWER .
Jan 17, 2009 | Prima CV2011 TV
Prima 27in. hd flat screen
50% trouble of tv is lose connection,first thing you will do is to re solder your tv. must specially the vertical section and the jungle
Oct 29, 2008 | Prima CV2011 TV
Prima HDTV has a black screen on TV, but works fine while Playing DVD
try turning the channel up or down with the tv remote to input 1 or 2 depending on which one is being used for the dvd player. tv should use input 1. dvd should be on input 2.
when turning the channel set it to show the dvd screen, then go up 1. if it doesn't show, return and go down 1.
Oct 22, 2008 | Prima C2012 TV
I have a HT3061P Prima TV. The screen is gray color with horizontal lines,the audo is very good.
check the RGB supply it is 180volts or the capacitor value 10/250volts (4.7/250v, 2.2/250v)
Oct 16, 2008 | Prima CV2011 TV
My HT3061P Prima tv, has the black screen, but the audio is very good.
adjust first the screen. it is a knob at the back of plyback.(lower knob),if the has vertical line ,then the section had a problem.try to resolder the vertical IC or else change the IC.
Oct 15, 2008 | Prima CV2011 TV
No sound or picture on my prima plasma tv
I HAVE A NICE PICTURE BUT NO SOUND
Sep 30, 2008 | Prima CV2011 TV
Prima TS2733
i have a prima ttv2131 which locked as above and holding down the display button for five seconds unlocked it (as well as locks it)
Mar 26, 2008 | Prima CV1311 TV
Prima plasma
sell it and buy real tv
Aug 29, 2007 | Prima CV1311 TV
Televison & Video Logo
Top Prima Televison & Video Experts
Todd Hill
Todd Hill
matt martin
matt martin
Are you a Prima Televison and Video Expert? Answer questions, earn points and help others
