Question about HP Audio Players & Recorders
My HP computer does not play sounds from the built in speakers. It plays audio only through the phones jack.
It produces a cracking audio sound occasionally when I disconnect the jack but it's not sustained.
Posted by Henry Mwansa on
5 Related Answers
Anonymous
SOURCE: 2 Dell 5650 have no sound
the surround sound speakers plug into the rear of the computer with three plugs. an adapter comes with it to plug those three into one green plug. if you plug that green plug in, the rear and center speakers should work, although i don't know if the surround sound will work correctly but you should get sound
Posted on May 06, 2009
Anonymous
  • 108 Answers
SOURCE: my computer doesnot produce sound when iam playing music
ok change ur setting at contorl panel ,here it is step by step click start > settings>control panel > and click sound and audio devices and change or ur settings as u like and check whether all the sound devices are working properly or not if not install all sound devies ok rate me please
Posted on May 24, 2009
Anonymous
  • 7 Answers
SOURCE: headphone jack does not work, audio still plays from speakers
sound like the hardware supporting your headphones may have disconnected from its solder.This could have happened from dropping the notebook with the headphones plugged in and landing badly, or a strong or constant tug on the input. Otherwise, it could be a software configuration like you've tried
Posted on Jun 08, 2009
Anonymous
  • 32 Answers
SOURCE: Realtek sound card does not work w/hp monitor w/built in speakers
Download Realtek AC97 driver or the realtek AC97 HD if u have a hd card
Posted on Sep 03, 2009
Anonymous
  • 57 Answers
SOURCE: I have acer al1715 that wont play sound from its
Plug jack carefull betwen monitor and pc and must work ok, put jacks to monitor on Audio In! If this help's you, rate me. Thanks
Posted on Sep 14, 2009
HOW DO I GET SOUND ???
Your HP Pavilion F1903 monitor does not have built-in speakers. Your desktop computer probably did not come with speakers. You will have to plug computer speakers into the audio-out jack (green) on the back of your computer to play through external speakers.
There are also a number of USB speaker systems available that use USB both for power and for the audio signal.
Alternatively, there is probably an earphone jack on the front panel of your computer. If you plug headphones into that you should be able to listen on your headphones.
Amazon com AmazonBasics USB Powered Computer Speakers A100 Computers... Amazon com Joylive White 3 5mm In Ear Earpiece Earbud Headphone Earphone...
Jun 27, 2016 | HP Pavilion F1903 19" LCD Monitor
Audio static
That's pretty normal with built in connectors. For a workaround grab a cheap USB sound card from eBay or somewhere else. It worked for me.
High Quality External USB 2 0 3D Virtual 7 1 Channel Audio Sound Card...
Apr 08, 2017 | Lenovo IdeaPad Yoga 11S Touch - 59370514 -...
Hp pavilion dv2046 sound problem
hi,1. first of all please check whether the mute options is checked or unchecked.2. After that go to device manager and check whether audio drivers are there or not. - Try to plug in the headphone and check whether the sound is coming or notIf there is no sound coming out of your speakers, but the headphone jack plays sound, there may be something wrong with your speakers. If this is the case, you can either use headphones or external speakers, or attempt to use the laptop's warranty to get HP to fix the speakers. Plugging and unplugging a headphone from the jack several times has supposedly caused some users' speakers to start playing sound again.
3. If the drivers are not there then go ahead install the drivers from the hp website by using the product of your computer.4. If the problem still exists then try to update the bios of your computer with the l latest version.5. Try to run the recovery of the computer and check after that.
Nov 16, 2011 | HP Computers & Internet
How can i get the computer sounds to play thru the built-in speakers of polaroid flm-1507
You need a cable with mini-phone plug at both ends (Radio Shack), one end is plugged into the monitor audio input jack (Green), the other end will be plugged into the PC audio line out jack (Green).
Dec 16, 2010 | Polaroid 15'' HDTV Monitor FLM-1511
No sound from built in speakers HP VS 17. Device is working properly when i checked the device manager and i can see the speaker icon in the taskbard. was working before i shifted the desktop to a new...
Try using MP3 player feeding the monitor to see if you get the sound OK first. Are you using stereo male to male mini jack for connection from PC audio line out (Green jack) to Monitor audio line in (Green jack)?
Feb 27, 2010 | HP Vs17 17" LCD Flat Panel Monitor
It does seem to be getting a power sound from my computer. When I plug in the jack to my laptop it does not make any sound to the logitech speakers and the sound continues to play from my laptop speakers.
You need to change the default audio output device in the audio control panel and restart the application (e.g. Media Player) you use to produce the sound.
Feb 07, 2010 | Logitech X-240 Computer Speakers
Windows 7 cant hear 5.1 surround sound through laptop audio jack
Are you sure that the soundcard supports 5.1 on your laptop?
Dec 13, 2009 | Computers & Internet
Audio problems
To use the integrated speakers on this monitor you will need the audio cable. Most monitors with built in speakers has a single cable with a green jack on both ends. It would plug into the audio jack on the back of your monitor and connect the monitor to your soundcard jack on the back of your pc. Cable should be able to be purchased at any electronics/computer store. Hope this helps.
Jul 08, 2009 | AOpen F75PS 17" Flat Panel LCD Monitor
Built in speakers will not play any sound
going to seem a dumb Q,
but is the audio cable plugged in, next to vga hp have a separate audio socket, the cable(supplied- 1/8 inch stereo plugs each end) fits between sound card speaker out, and monitor.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00307478&lc=en&cc=us&product=459838&dlc=
Jun 24, 2008 | HP vs15 15"LCD Flat Panel Monitor
Top HP Audio Players & Recorders Experts
Marvin
Marvin
Lawrence Oravetz
rfredey
Are you a HP Audio Player and Recorder Expert? Answer questions, earn points and help others
