Question about Locks & Locksmithing
Hi I have a kaba 680 and the keypad has twice now said that the keypad is locked. why does this happen?
Posted by Greg on
1 Related Answer
Coaltowner
  • 963 Answers
SOURCE: kaba lock won't open with code
Customer service can be contacted from this link:
http://www.kaba-ilco.com/access_control/support_contacts/service_and_support.aspx
Tech Support from this link:
http://www.kaba-ilco.com/access_control/support_contacts/technical_support.aspx
Posted on Aug 24, 2012
How can i remove a unican lock
You will find installation manuals on this page:
http://www.kaba-ilco.com/kaba-access-control/Documentation-Support/292720/simplex-mechanical-pushbutton-locks.html
You may need to install Adobe reader if you cannot view the documents. There is a "Get Adobe Reader" link found just above the chart if you can't.
Oct 04, 2012 | Simplex Kaba Ilco Unican 1000 keyless...
Kaba lock won't open with code
Aug 18, 2012 | Simplex Kaba Ilco Unican 1011 keyless...
Unican keypad door lock reset?
You will find a link to download the manual for your model on this page:
http://www.kaba-ilco.com/access_control/literature/literature_grid_mechanical_pushbutton_locks.aspx?id=13
Hover your mouse over "PDF" under the "TIPS" column and the two choices of "Changing the Code/Combination" or "How to Reset a Lost or Unknown Combination" will appear--move your mouse over the appropriate one and click to download the info.
These are PDF files, requiring Adobe Reader to open. There is a link on the same page to download Adobe reader, if the file will not display for you.
Good luck--and please provide feedback if this helps!
Oct 24, 2011 | Simplex Kaba Ilco Unican 1011 keyless...
Hi fix is this lock handed or is it reversable
Hi and wlecome to FixYa, I am Kelly The locks are preset left handed but can be changed to RH.
Download this manual
http://www.kaba-ilco.com/access_control/access_download.aspx?File=simplex_1000_installation_instructions_pkg_2280.pdf&Attachment=True
Go to page 14 of the manual and follow the steps.
If the link does not work for you then use this page:
http://www.kaba-ilco.com/access_control/literature/literature_grid_mechanical_pushbutton_locks.aspx?id=13 and click on the MANUAL for your lock.
Thanks for choosing FixYa,
Kelly
Sep 22, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
Hi i have got a Kaba 1000 series but the buttons are loose and not pressing in do you know what the problem is???
It may be that you don't have the installation set up for the proper thickness of the door. But your best bet is to call the customer service for Kaba Ilco and describe the problem. The toll-free number is 800-849-8324. They are located in North Carolina, so the best time to call would be during east coast business hours. Be sure to have your model number, purchase date, etc. handy when you call.
Here is a link to their website:
Aug 18, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
My kaba gun lock will not open i put new batteries in it i have tried 3 different one but nothing will work. i try to punch in my code and it just peeps at me and i can not get into m gun safe.
I don't have a direct answer, but Kaba customer service can be reached here:
Mar 01, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
I was relocating a working Kaba m# LL101126D41 i had happen to turn the outside handle with the small key cylinder removed on the back side top now when all installed it wont lock . what do ineed to do...
Oct 13, 2010 | Simplex Kaba Ilco Unican L1000 keyless...
Zero old key code and enter new key code on KABA electronic keypad
http://www.kaba-ilco.com/access_control/literature/literature_grid_eplex.aspx?id=14
These are PDF files, requiring Adobe Reader to open. There is a link on the same page to download Adobe reader.
Sep 22, 2010 | Simplex Kaba E-Plex 3000 Narrow Stile...
Lost code for keyless unican lock
I just performed this on my lock and it's quite simple. The instructions are in the attached manual.
http://www.kaba-ilco.com/access_control/access_download.aspx?File=simplex_1000_installation_instructions_d8_pkg_2280.pdf&Attachment=True
Cheers.
May 16, 2009 | Simplex Kaba Ilco Unican 1000 keyless...
Locks & Locksmithing Logo
256 people viewed this question
Top Locks & Locksmithing Experts
ray gallant
Andrew Taylor
Andrew Taylor
Tom Chichester
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
