No the kill switch is not on
SOURCE: Truck wont start.
test starter solinoid wire from harness, with a helper put test light on wire get friend to turn key to start, light should light up, wires at the bottom of engine may (look) fine
SOURCE: van wont start
Just maybe the battery and alt were good. You did test them,before replacing didn't you? How about the starter solenoid,starter or ground connections or cables with too much resistance. Do a voltage drop test, on all grounds, you can get to.
SOURCE: how do i reprogram my ignition switch n my 92
You can't. I just replaced mine on my 92 Camaro and it's a pain in the ***. You can only install the ignition switch one way, then you have to make sure that the rod coming off the tumbler (where your key goes) is in the right spot.
SOURCE: Got power on everything, but no ignition, battery
sounds like a bad chip in your key.
see dealer for new key.
SOURCE: Battery was run dead and
Its in security system...race engine as jumping. Takes about 3 times for comp to relearn idle
