Dryers Logo
I have a Hunter fan. The fan works but when I try to put the light on it won’t go on at all. Is this a watt governor issue also. Thanks
5 Related Answers
Anonymous
  • 70 Answers
  • Posted on Jun 29, 2009
SOURCE: Hunter Fan not working...light fades out then
Capacitor may be bad on motor. try powering and spin with broom handle to see if it will try and run. Motor could be bad.
Anonymous
  • Posted on Mar 09, 2010
SOURCE: Hunter ceiling fan remote 85095-01 stopped working
it also could be one of the the jumpers fell out of the remote
they are located just above the battery. you will need to match the placement of the jumpers with the receiver mounted in the fan.
Anonymous
  • 1998 Answers
  • Posted on Dec 15, 2010
SOURCE: I would like to use 60 watt bulbs in my new
I did a little research on the part in fan, and its a watt governor! the government put this into effect in 2008. bush and obama did this. i read an article on the watt governors. and one person said his lights were flickering on and off. he just disconnected the governor and reatached the wires and the lights work great. they did this to keep the cost down thats why the watt governors. this was from a fan rep. part # on watt governor--98480-02 remove governor and reattach the wires for the light if you have any further questions please message me back and please remember to rank how this opinion has helped in your appliance situation Thanks again
Rick
Anonymous
  • 670 Answers
  • Posted on Jun 12, 2011
SOURCE: My Hunter Remote FCC IN2TX01
hi there,
Maybe you can try doing these steps:
1. Adjusting the dip switches:
Each fan/remote combination is set to work on a specific frequency, much like tuning in a specifc radio station. Some fans allow you to set this frequency by means of a set of small switches called "dip switches". There is one set located inside the remote, and the other set would be position on the fan, with the remote receiver electronics. This would be either on top of the motor, or inside the switch housing or ceiling canopy. These switches "tune" the remote and fan (received) to the same "station" and therefore must be set to the same setting. If a fan is not responding to the remote you can check to make sure that the switches are set to the same setting in both locations, and/or try a different setting. They are also useful if you have two remote fans, you will want to be sure each fan is set different so the remotes do not interfere. Lastly, if some other wireless device is interfering with the fan (causing it to turn on and off seemingly at random) such as a garage door opener or cordless phone, you can try a different setting on the dip switches.
2. Universal remotes:
If your fan remote is lost or broken, many suppliers, offer a universal remote designed to work with the majority of different remote operated ceiling fans. Many are also universal for operating televions etc so you can control all your leisure and comfort devices from one unit.
3. Replacement parts:
Unfortunately, outside of Universal remotes, general replacement parts are not available for remote control systems. Your best bet is to contact the manufacturer.
3a. Repair:
Also unforunately, most problems with remote controls cannot be repaired outside of what is suggested above. If you have problems, contact the manufacturer, perhaps the fan is under warranty, or parts are available. Otherwise chances are the fan will stay broken.
4. Add-on remote kits
Some fan remote systems are not built into the fan, they were an option added by the installer at an additional cost. Usually they consist of a remote receiver wired to the fan inside the ceiling canopy, and the fan will still have a pullchain that is not used. If this is the case then the receiver can be removed and replaced with another remote/receiver kit, or the fan can be operated as standard with the 3 speed pullchain.
If all else fails:
contact hunter and see if a replacement remote is available:
here's the website:
http://www.huntershoponline.com/cc_contactus.asp
here's the phone number and office hours:
1-800-893-9330 Monday - Friday
8am - 8pm ES
Anonymous
  • 10 Answers
  • Posted on May 25, 2012
SOURCE: hunter fan light switch won't turn off light
by looking at the sw. it looks like u can only put it to a low dim and not off and the button at the bottom is all off including the fan if this is correct u should be able to change to a different kind of fan sw. combo or even a remote style that comes with a receiver ,also your fan should have three wires at the box a light wire "blue" a fan wire "black" and a neutral "white" oh and a ground "green" in order to switch these separate u need those 3 wires at the sw. also . but with a remote u only need the hot and neutral it hooks up in the box or canopy of the fan to the receiver all wires are marked for easy installation turn power off to be safe u can install a regular sw. to over ride the remote and turn power off at the fan .......its alot i know but hit me up if u need more help.
Mercedes Parts
Hunter royal oak blinking lights
It sounds like there is a dimmer circuit involved and the low current of the LED and the electronics in the CFL do not work with standard dimmer circuits. The governor is actually a run capacitor for the motor. Removing that causes it to burn more energy and opperate an a much lower efficiency.
Hunter Fan. Lights blinking on and off. I have read that it is the light governor and I should remove it and wire direct. I need more detail. Where is the light governor and how do I wire it...
the watt governor is inside of light assembly. it is a square black box. take this out and hook it direct, white wire to white wire, black wire to red wire. and this should solve the blinking lights. good-day!
1helpful
We had the Hunter fan installed in April and have been very pleased with its performance. About a week ago whenever you turn on the fan light it flickers nonstop. Can you help me?
this is caused by the watt governor or the black box in fan to the lights. remove the watt governor and wire the lights directly. when removed, hook white wire to white wire, and black wire to red wire. black and red wires are always the hot wires. governor part number- 98480-02, have a good day !!
13helpful
2answers
The light on my hunter ceiling fan flashes on and off when I turn it on. I have a model 21421-530 Type 2. Any ideas what might cause this? Ceiling fan works fine on all 3 settings, so I don't think it's...
remove watt governor for lights. ( little black box). and wire lights direct. this is your problem.watt governors are used to reduce light output or energy. just remove it.
11helpful
What is a watt governor and what does it look like?
it is a small black box for the lights. if lights blink on and off, it is the watt governor causing this. just remove governor and wire lights direct. part # 98480-02. have a good day !!
9helpful
Hunter 'lodge' ceiling fan w/light: all switches 'on' and light blinks???? what do I do to correct problem?
if problems with the light blinking, remove watt governor inside fan, for lights. and wire the lghts directly. this should fix problem. the watt governor is a small black box to reduce wattage on the lghts. just remove it and wire lights directly. have a good one !!
21helpful
I have a fairly new hunter ceiling fan/light. Often when we turn the light on it continuously blinks on and off. To remedy this problem we need to cycle the switch (sometimes many times). I am assuming...
on most of the hunter fans there is a watt governor in it. if problems with lights blinking, remove watt govrnor, then wire it direct without governor. governor part # 98480-02, have a good day !!
2helpful
Light keeps blinking on and off just put in new bulbs that is not it how do i fix fan works fine
there is a watt governor on inside for lights. remove this governor , and rewire lights direct. this should fix problem. part #-- 98480-02 ).
15helpful
I have 2 of the same Hunter Douglass ceiling fans with double light kits in my living room. Yesterday one of them started blinking the lights constantly when I tried to turn on just the lower bowl light....
if problems with blinking lights, remove watt governor on inside of fan for the lights.its a black box,white to white wire and black to red wire. and wire it direct without watt governor or black box. this should fix the problem. the part # 98480-02 for watt governor. they installed watt governors on ceiling fans to reduce light wattage.
Top Hunter Dryers Experts
ZJ Limited
ZJ Limited
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
