Question about Panasonic Lands Phones
How to setup outgoing(to mobile phone and external landlines) calls on extension line on panasonic kx-t7730 hybrid phone
Posted by Kabya Subedi on
5 Related Answers
Anonymous
SOURCE: I cant make calls on my Kx-t7730 but i can recieve calls
sounds like you need to call a qualified tech
Posted on May 11, 2008
Anonymous
SOURCE: panasonic KX-T7730 CORDED PHONE
my telephone is lock forget pasword
Posted on Nov 05, 2008
Anonymous
  • 4 Answers
SOURCE: We have KX-T7730, want to stop incoming calls going to a different extension, so that the main calls just go through reception phone
try 408
Posted on Feb 26, 2009
cnavarro
Carl Navarro
  • 2460 Answers
SOURCE: lock extension with my Panasonic KX T7730
Do you need the default lock code because you already did this, or is it locked and you can't unlock it?
This is probably close, but in the American version it's 77 lock lock # to set and 77 lock # to release, where lock is a 4 digit number.
The System manager can release all locks from their phone. You'll have to make arrangements with an "engineer" to get those codes.
Carl (working on Br terms)
Posted on Jul 18, 2009
Anonymous
  • 113 Answers
SOURCE: panasonic kx-t7730
Hello, if you are using this phone with a 308 or 824 system, while the handset is still on the cradle / hook press PROGRAM and then the one touch button you want to assign a CO line to. Now press 0 followed by the line port number ( example 1 ). Press AUTO DIAL / STORE to save the changes. Press PROGRAM to exit program mode.
PLEASE vote if this was helpful
Posted on Mar 24, 2010
How to set welcome greeting to panasonic KX-T7730
The 7730 is a smartphone (PT) that connects to a Panasonic Hybrid exchange such as the KTES824 as an EXTENSION not a CO.
When you say greeting do you mean a recorded greeting when calling the extension?
In the 824 switch you will need to activate the Automatic Attendant (AA) that is built-in
Oct 28, 2013 | Panasonic KX-T7730 Corded Phone
Panasonic KX-T7730, we have a 824 phone system and cordless handsets (kx-tg1711) we cannot make outgoing calls on these handests but can take incoming calls and can transfer calls. how do we programme
  • Locate the program and auto-store button on your telephone. You will be using these to customize many of the features on your KX-T7730. The program button is used to enter or exit programming.
  • 2
    Program your outgoing line preference, i.e., the line you prefer to seize when you go off hook. Press "Program" "1" "1" "store" for no line. Press "Program" "1" "2" "Store" for an idle outside line. Press "Program" "1" "3" "Outside Line Number" "Store" for an assigned outside line. The outside line number will be a single or double-digit number that is set through your phone system.
  • 3
    Program your incoming line preference, i.e., the line you prefer to answer when you go off hook. Press "Program" "2" "1 "Store" for no line. Press "Program "2" "2" "Store" for ringing line. Press "Program" "3" "Outside Line Number" "Store" for an assigned outside line.
  • 4
    Program your flexible CO buttons. These are the inner row of 12 lighted buttons. Your outside lines need to be programmed to these--you can choose any of these 12 buttons in any order. Press "Program" "CO Button" "0" "Outside Line Number" "Store." The outside line number will be a single or double-digit number that is set through your phone system.
  • 5
    Program any other unused flexible CO buttons for an extension number or any frequently dialed phone number. Press "Program" "CO button" "1" "Extension Number" "Store" or "Program" "CO Button" "2" "9 + Phone Number" "Store". A "9" must be entered at the beginning of a phone number to tell your phone system to seize an outside line before dialing, e.g., "9-1-212-555-1234."
  • 6
    Locate the programmable feature buttons (the row of 12 solid buttons on the right). These buttons are basically one-touch buttons that can be set for extension numbers or phone numbers. Press "Program" "(PF) Button" "Extension Number" "Store" or "Program" "(PF) Button" "9 + Phone Number" "Store." Remember to press "Program" again to exit programming.
  • 7
    Locate your "FWD/DND" button. This button is used for setting "Call Forward" or "Do Not Disturb" on your telephone. To set call forwarding, go "off-hook" either by lifting the receiver or pressing speakerphone. Make sure you go to intercom and not an outside line. To forward all calls, go off-hook, press "FWD/DND" "1" "extension number" (the extension number that you wish to forward all your calls to) "#". After you hear a confirmation tone, place the receiver on-hook. The steps to set call forwarding for busy/no answer are the same as above, except you will press "2" in place of "1". To cancel call forwarding, press "0" in place of "1".
  • 8
    Program "Do Not Disturb," which stops your phone from ringing--any callers will just hear a DND tone. To program, go off-hook, press "Program" "4" "#" on-hook, to set. Press "0" instead of "4" to cancel.
  • 9
    Locate the message button--this works in coordination with your message light at the top right of your telephone. If the light is lit, press "message" to hear a message left to you either by another extension or a voice mail system. The message button can only be programmed as a message or one-touch button. To program as a message, press "Program" "Message" "3" "Store." To program as a one-touch, press "Program" "Message" "1" "Extension Number" or "Program" "Message: "2" "9 + phone number."
  • 10
    Return your KX-T7730 to its default settings by pressing "Program" "#" "*" "Store."
  • Read more: How to Program a Panasonic KX T7730 ' eHow.com http://www.ehow.com/how_7159736_program-panasonic-kx-t7730.html#ixzz1eYPzbevZ
    Nov 23, 2011 | Panasonic KX-T7730 Corded Phone
    I'm using Panasonic KX-T7730. and Panasonic Advanced Hybrid System KX-TES824BX . Please help me.I need to make security lock for outgoing calls ...
    In programming you can set up Forced account codes for Local, Toll, or All calls. The extension is flagged in program 605 or 2.1 of the system and the codes are put in 310 or 1.5. It's one of 2 ways you can do it, you can also change Class of Service on each phone to deny them access to certain numbers.
    Keep in mind that this is programming for a TA-824 release 3.0. We know loop start CO lines and no ISDN or BRI. Your system may be different.
    Carl
    Nov 23, 2010 | Panasonic KX-T7730 Corded Phone
    KX-T7730 - Used to have 3 incoming/outgoing lines. Have cut this down to 2(lines 1 and 3). Outgoing calls are automatically selected by line 3, 2, 1. When calling out the second person can't get an outside...
    If you are using the KX-T7730 phone on a Panasonic KX-Txx 308 or 824 system.
    From the Switchboard / Main telephone ( usually ext 101, 10 or 9 ) with the handset on the cradle/hook :
    1. Press PROGRAM * # followed by the system password ( default is 1234).
    2. Now press 400 and then SP-PHONE. Enter the line number you wish to change. ( In your case 2)
    3. Press AUTO ANS / MUTE to change between Connect and Not Connect.
    4. Press AUTO DIAL / STORE to save your changes.
    5. Press PROGRAM to exit program mode and you are done.
    Mar 17, 2010 | Panasonic KX-T7730 Corded Phone
    Panasonic KX-T7730 CORDED PHONE
    Oct 14, 2008 | Panasonic KX-T7730 Corded Phone
    Panasonic Adv Hybride System KX-T7730
    If you are using the KX-T7730 phone on a Panasonic KX-Txx 308 or 824 system. From the Switchboard / Main telephone ( usually ext 101, 10 or 9 ) with the handset on the cradle press PROGRAM * # followed by the system password ( default is 1234). Now press 604 and then SP-PHONE. Enter the jack number you wish to change ( 01 is extension 101, 02 is extension 102 etc. ). Enter the name ( basically the same as texting on a cellphone ). Press AUTO DIAL / STORE to save your change. To go to the next extension press SP-PHONE. Don’t forget to press AUTO DIAL / STORE to save your change after each name entered. Press PROGRAM to exit program mode and you are done.
    PLEASE rate / vote this answer if it was helpful.
    Thank you.
    Sep 18, 2008 | Panasonic KX-T7730 Corded Phone
    Calling out
    Here is the link to the user manual if you need it; http://service.us.panasonic.com/OPERMANPDF/KXT7720.PDF Page 7 - locking your extension should help you out Please ask again if you need more help :)
    Feb 23, 2007 | Panasonic KX-T7730 Corded Phone
    Lands Phones Logo
    306 people viewed this question
    Top Panasonic Lands Phones Experts
    Muntejaya Ginting
    Muntejaya Ginting
    Henk de Ruiter
    Henk de Ruiter
    Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
