That will have knackered the main power output device(s) located on the big heatsink. If they are transistors you should be able to tell which are faulty as a meter on the pins will give a full scale deflection, just like it was a piece of wire. There could also be physical signs of damage such as parts blown apart or burning.
SOURCE: Fuses blow afer power surge
These are switch mode power supplies and very difficult to
repair. If you don't find all the blown components, they just
blow up again when you try it. If that model has a separate
module for the supply, you can try and order a replacement, but they
usually are too expensive.
What model is it? Maybe I have a junker I can take the supply from for you?
SOURCE: logitech z680 blows fuses
http://www.readycomponents.com/1/1/436876-fuse-tlag-160a-250v-ul-tr5-37411600410.html
heres one place to buy it
somewhere else theres wires touching too
http://messages.crutchfield.com/S-ik2rksX50QP/App/Product/Group/ProductMenu.aspx?g=717&tp=1124
fuse suppliers
radio shack
fry's electronics
any electronic stores
SOURCE: kawasai z750, keeps blowing main fuse
To my knowledge, there are no onboard electrical/electronic components capable of shorting and blowing the fuse with out blowing any of the secondary fuse. The main fuse could possibly blow due to a short in the wiring or an exposed/frayed wire touching the body. The three most likely areas would be:
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
SOURCE: b300 speaker blowing mains fuse as soon as power
The power transformers in these and some other behringer speakers have a habit of short circuiting.
Good luck trying to get any details from behringer about spares or tech info..they act like they have something to hide...and maybe they do ;).
You can unscrew the amplifier part from the speaker and disconnect all leads except those 2 going to the power transformer..if it still blows the fuse then the transformer is history.
SOURCE: Connecting Speakers to Marantz NR1402
HI,
You can use banana plugs to connect speakers to the speaker post. Connect the wire to the banana plug then insert the banana plug in the speaker post.
If you serch in google with the name speaker banana plug then you will get picture of different types.
You can buy this banana plugs in any nearby electronic spare part shop. They all stock this item. Normally comes in pair ( red, black)
Ajin
