Computers & Internet Logo
K
Kirt Cutler Posted on Apr 29, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Just installed the OptiCover Range Extender and now my speeds to connected devices is slower that going directly to my WIFI modem. What is wrong?
Joseph Wright
Level 3:
  • The Master 1,729 Answers
  • Posted on Apr 29, 2018
Joseph Wright
The Master
Level 3:
Answers
1729
Questions
Helped
454654
Points
5127
Did you connect to the new device? It should have a different ID.
4 Related Answers
Anonymous
  • Posted on Dec 20, 2008
SOURCE: no internet connection via DWL-G710
Your extender may not be able to talk to the router. Make sure you have set default gateway in extender to IP of the router. Turn off encryption first. Check the router if extender shows up in active client list or active mac address list.
Anonymous
  • 10 Answers
  • Posted on Sep 13, 2009
SOURCE: sitecom WL-330 range extender with dlink dir-615- unable to use
I am guessing you have XP or vista. here are the instructions for both.
XP 1. Click ‘Start’ button (it should be located at lower-left corner of your computer), then click control panel. Double-click Network and Dial-up Connections icon, double click Local Area Connection, and Local Area Connection Properties window will appear. Select ‘Internet Protocol (TCP/IP)’, then click ‘Properties’ 2. Select ‘Use the following IP address’, then input the following settings in respective field: IP address: 192.168.0.2 Subnet Mask: 255.255.255.0 Click ‘OK’ when finish.
Vista 1. Click the ‘Start’ button (it should be located at lower-left corner of your computer), then click control panel. Click View Network Status and Tasks, then click Manage Network Connections. Right-click Local Area Network, then select ‘Properties’. The Local Area Connection Properties window will appear, select ‘Internet Protocol Version 4 (TCP / IPv4)’, and then click ‘Properties’ 2. Select ‘Use the following IP address’, then input the following settings in respective field: IP address: 192.168.0.2 Subnet Mask: 255.255.255.0 Click ‘OK’ when finish.
Next step for both All functions and settings of this access point must be configured via the web management interface. Please start your web browser, and input ‘192.168.0.234’ in the address bar, and press the ‘Enter’ key. The following dialog should be shown: Please input user name and password in the field respectively. The default user name is ‘admin’, and the default password is ‘admin’. Press the ‘OK’ button to see the web management interface of this access point: NOTE: If you can’t see the web management interface, and you’re being prompted to input user name and password again, it means you didn’t input username and password correctly. Please retype user name and password again. After you connected to the access point by web browser, the first thing you see is ‘Status and Information’ page. All system and network related information of this access point will be displayed here. The information is very helpful when you want to know the detailed information of your access point, and when you try to fix the communication problem between this access point and other wired / wireless computer / devices. You can click ‘Home’ on the left, This access point can be operated in different modes; you can click ‘Basic Setting’ to select an operating mode you want to meet for different needs: You can click ‘Mode’ dropdown menu to select operating mode, and there are 3 operating modes available: AP Access point mode, allows wireless clients to connect to access point and exchange data with the devices connected to the wired network. Station- Infrastructure Enable the Ethernet device such us TV and Game player connected to the access point to a wireless client. Universal Repeater This product can act as a wireless range extender that will help you to extend the networking wirelessly. The access point can act as Station and AP at the same time. It can use Station function to connect to a Root AP and use AP function to service all wireless clients within its coverage. You can hopefully figure it out from there.
Testimonial: "tanks v. much for answer, i'll try it right away"
LaptopNomad
LaptopNomad
  • 12 Answers
  • Posted on Oct 01, 2009
SOURCE: Sitecom WL-130 Wireless Network Range Extender
For extending / repeating WIFI signals there's quite a bit of details to know about.
Read about repeating a WIFI signal with a sitecome WL-130 WIFI repeater here.
Anonymous
  • 1637 Answers
  • Posted on Jan 13, 2011
SOURCE: I have a Netgear Universal
What is the last thing that happened before you noticed there was a problem?
How to connect PC to netgear WIFI extender
By connecting to your existing WiFi network and enhancing coverage, the NETGEAR range extender enhances your home WiFi network. The steps below will assist you in setting up your extender.
We recommend using the Nighthawk app to set up your extension on our latest devices. See the following articles for more information:
https://pnews.org/boost-your-speed-with-netgear-nighthawk-r7000/
I purchased a ac 1200 Opticover range extender. It is calling for a password when i try to connect my ROCU TV. I do not have a password that works. Can you help me?
There should be a way to convince the extender to use the router's password. I had one at one time, but don't remember the details. I now use the type that plugs into the router, into the 110 wall outlet with another device at the receiving device.
2answers
How to set up netgear ex6100 wifi range extender
  1. Plugin your extender in electrical outlet.
  2. Place your extender near your router when first time your are setting new extender.
  3. Launch any web browser and enter mywifiext.net. The New Extender Setup page displays.
  4. In the Password section, type the existing WiFi network password. Default user name is admin and password is password.
5. Click continue and a message box displays saying that your extender is connected to the new extender WiFi network
6.
Now, you can connect your device to the extender network, go to the WIFI settings and connect to the extender's new network.
7.
Netgear EX6100 Setup is successfully completed now place the extender at the desired location and enjoy seamless Connectivity.
Internet connection speeds much slower when LAN is routed through a router as opposed to directly linked to the modem?
Depending on the Wireless device, speeds differ with the protocol a bit. A cable/hardwire connection will always be a faster. I would not get to hung up on speed test software, there are many factors when using different one's , your speed will vary wildly, form one to another. Your dealing with ALL the outside ISP equipment you have no control over. If you go to 10 different "Speed Test" software websites, you will get 10 different Uploads speeds, and 10 different Download speeds. Most of this is due to Outside equipment. You just may be Obsessing over something you can't control, but I could be wrong. Maybe your ISP is "throttling" your signal? http://www.pcworld.com/article/158552/check_ISP_speeds.html
Top The Computers & Internet Experts
Alexander
vince
Steve Sweetleaf
Steve Sweetleaf
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
